Prius PHEV with Aftermarket Brake Rotors and Pads | Regen energy gained while braking rate increased
Discussion in 'Gen 3 Prius Main Forum' started by black_jmyntrn, Feb 15, 2024.
  1. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Sure. Go ahead and be excited. But please post how you are going to run a careful scientific experiment and what you are going to measure before you do it so there is no question that you are really measuring more regen.
    This means multiple runs with and without the proposed new brakes over the same course with round trips to negate the effects of hills, wind, etc.
    I'm looking forward to reading how you are going to run the tests and then seeing the data afterwards.
    Mike
    black_jmyntrn likes this.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,694
    395
    2013 Prius Plug-in
    brake drag, now that has been the most logical rebuttable and explanation so far... hmm.. just... thinking back, I don't recall any pads being over used or not pretty close to evenly worn yet I could be wrong here.
    well, so far, the plan is to record all data and then use logic from the data set, the plan is to search for the same GPS route for the same miles driven and then break it down from there to show the energy generated through braking over time noting the date the parts were changed to see from there any changes. right now grafana is what my brain says I'll use but kibana might be better used. The thought of incorporating AI in this to ensure what I am displaying has been properly captured is also on my mind.
    if interested, I have a OBD2 Dongle with Wifi and Bluetooth but also an SD card slot, so itll log the data without the need for a device to connect via bluetooth to actually record the data.
    the Hybrid Assistant developer has been no help so, I'm slowly moving away from that as my primary data logger.
    #42 black_jmyntrn, Feb 19, 2024
  3. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Great! But what is all the data? What, exactly will you analyze after you've collected it?
    How many runs will you do with old and new brakes?
    How many miles per run?
    Will you do a warm up before each test?
    Will you account for tire wear and pressure?
    Will you be measuring outside air temp, wind, humidity -- I've not seen an OBD that collects this
    You should probably wash the car between runs since this probably has as much effect on regen as the brakes :)
    Mike
  4. black_jmyntrn
    1,694
    395
    2013 Prius Plug-in
    I believe you are Ginuwine in your response and not like the others so I hope any response to you does not come across with any negative sarcastic I think I'm a comedian smarty pants energy like most posters... but I did cover this on page one, this value in the logging data is what I believes should see a spike after brake parts are installed. "Total energy recovered by braking"
  5. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Fair enough, but you failed to answer all the other questions, such as how long is a run?
    10 miles with the new brakes and 1 mile with the old brakes will normally show a much larger kwh value for the new ones.
    I'd like to see a complete description of how you plan to test in a controlled manner.
    And all the "other" things you'll document...air temp, tire pressure, elevation change,etc.
    Using a scientific test allows others to repeat the same ~exact test and see if they get the same results.
    Mike
  6. black_jmyntrn
    1,694
    395
    2013 Prius Plug-in
    For me, at least a solid month after new parts are installed, maybe even one oil change cycle. Between the many months of data before the upgrade and then a month possibly two after, the same routes are driven daily in this particular vehicle so it should be fairly easy to find a cluster of say 5 trips before and 5 trips after that match in route and gas pedal usage that can be used as the data set for proving this theory.
    All the data you mentioned will be logged and available for use in the study.
  7. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    Has anyone else noticed that regen appears to get used faster than charge from the wall, or is that just me.
    Eyeballing gauges in the Prime it appears that going up hill the Prime used 4x the amount of energy as can be gained from regen going down the same hill at approximately the same speed.
    Not that these observations have anything to do with aftermarket slotted rotors and ceramic pads, but I thought I'd offer some regen points that I've noticed, however inaccurate they might be.
  8. bettergolf
    bettergolf Active Member
    476
    359
    Sanford NC
    I believe I read that regen captures about 30% of the energy used to create that speed...so it sounds like if you're going up and then down the same hill...well that sounds about right?
    Mr. F likes this.
  9. Mr. F
    Mr. F Active Member
    386
    253
    Washington
    Genuinely not trying to make things harder for you, but when you're trying to figure out if an intervention (aftermarket rotors/pads) is effective compared to the control (OEM rotors/pads), a critical factor in experiment design is the order in which trials are conducted.
    If your brakes were dragging before, there would be less kinetic energy left over for the regenerative system to recover than a well-lubricated system. In the process of swapping out the rotors you might end up relubing the caliper pins, thereby making a larger fraction of kinetic energy available to be recovered by regen. Since you were not specifically controlling for the effect of lubrication, your readings would seem to indicate greater regen after than before, and you might chalk it up to the slotted rotors when it was actually the lubrication doing the work. Randomizing the order of conditions or matching them (alternating between OEM and aftermarket brakes repeatedly, instead of all OEM followed by all aftermarket) makes it much less likely that confounding, unaccounted-for factors, such as brake drag, will skew your results one way or the other.
    Tideland Prius likes this.
