Prius phv HV battery Life
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by LAHIRU GUNASEKARA, Jun 7, 2020.
Tags:
  1. LAHIRU GUNASEKARA
    LAHIRU GUNASEKARA Junior Member
    Srilanka
    Hey guys I just want to know about Prius plug in HV battery?? Is that battery how long can last? Also how is the brand new hv battery price ?
    Some people’s are saying that phv hv battery can long last as life time is that true? Please help me about these matters to getting a good idea to plug in car Prius 2012.
  2. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Mine, like many others, is coming up to 8 years old and still works fine. There may have been some loss in battery capacity, but I still get around 16-18 km range on a full charge (range varies on many conditions).
    LAHIRU GUNASEKARA likes this.
  3. LAHIRU GUNASEKARA
    Srilanka
    What is the cost of new hv battery? Any idea about it
    52,857
    welcome!
    they are probably good for 10-15 years, or 150,000 250,000 miles, depending on many conditions.
    new batteries are probably worth more than the car, and i would check in your country for pricing and availability.
    all the best!(y)
  5. LAHIRU GUNASEKARA
    Srilanka
    Thanks :) which means regular Prius is better than the phv because the hv battery is much much cheaper than the phv
  6. bisco
    52,857
    that's one way to look at it. the regular prius is a great car, and battery replacement options are relatively cheap, easy and plentiful compared to the plug in.
    if you don't want the 10-15 miles of ev, i can't think of a reason to buy one.
  7. LAHIRU GUNASEKARA
    Srilanka
    Is there any possibility to convert plug in to normal Prius I mean the hv battery if I don’t need plug in option, only used as a regular Prius???
  8. Desertdeals69
    Desertdeals69 Junior Member
    44
    23
    Lk Havasu City Az 86403
    All of my daily driving to the stores and my shop are within the 10 miles range so I rarely use any gas. I love my 2014 plug in. On a long trip I usually get about 52 mpg. My other Prius which is a 09 gets around 46 mpg on the highway.
    bisco and LAHIRU GUNASEKARA like this.
  9. LAHIRU GUNASEKARA
    Srilanka
    Is anyone plug in convert to normal Prius I mean hv battery because plug in hv battery is very very expensive???
  10. QuantumFireball
    420
    269
    Ireland
    Well I haven't had to replace the battery yet, so right now for me the PHV is cheaper because I'm using about 35-40% less fuel overall (electricity is dirt cheap in comparison). In Ireland, the battery is covered by an extended warranty up to 15 years. It's unlikely I will own the car that long anyway.
  11. bisco
    52,857
    when you say convert, if you mean, do i need to plug it in? the answer is no, it always behaves like a regular prius when it has no wall charge.
    if you mean, can i replace the hybrid battery with a standard battery if it goes bad? the answer is no. the plug in battery is lithium, the standard gen 3 battery is nimh. the software doesn't play nice.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    What @bisco said. If the battery gets so low in capacity that it's not worth plugging in, it'll still be a great hybrid car. If the battery fails, then I don't think it can be converted although it might be fun to experiment with the battery ECU and a battery from a regular hatchback.
  13. LAHIRU GUNASEKARA
    Srilanka
    Can you guys tell me the Prius plug in 4.4kwh Li ion battery prices in your countries???
  14. bisco
    52,857
    iirc, around 5k here, plus labor. it's a heavy sucker
  15. Desertdeals69
    44
    23
    I bought a single battery pack (it takes 4) on ebay for $225. Hasn't been on a charger for over a year and the voltage is still up. I figure if the pack fails it won't be all 4 at the same time so I can just replace to bad one. It came with the harnesses and sensors complete.
    LAHIRU GUNASEKARA and bisco like this.
  16. bisco
    52,857
    please tell us more, do you have a pip?
  17. Desertdeals69
    44
    23
    I have a 14 plug in.
    bisco and jerrymildred like this.
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    Ah! The confusion was probably because your info says you have a 2008. ;)
  19. bisco
    52,857
    what charger do you keep on it? what does a quarter of a battery look like, can you post a pic? this is very helpful information.
  20. dony71
    dony71 Junior Member
    16
    californica, usa
    How do you recognize which battery pack is bad? Any suggested phone apps?
