Prius Plug-in and Volt Pros and Cons
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Norton, May 9, 2014.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    There's two ways to look at life...
    1) An eternal battle of "all against all."
    2) A complex community of interlocking interests.
  2. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    John,
    As a consumer I have no idea what a business model is, nor do I care about it.
    I pay Cost-per-Mile. So does everyone else.
    The PiP gets its lame $2500 tax incentive too, because of its lame EV performance. It was designed for that and the Cali HOV sticker.
    Those were the design goals, while you were "waiting" for it to come to market. Look it up.
    We can argue all you want about if a gobmint should help move the country forward to a cleaner future by giving incentives to encourage that future. Come on Nation Wide Net Metering and I'm buying my solar system!!!
    Shall we argue about if the PiP is a proper car to have access to the gobmint appointed HOV privileges?
    All I know is what my blatant actual dollar consumption is. And how that would compare if I owned a PiP instead.
    And where some of my American dollars would end up if I drove a PiP instead of a Volt.
    And, once again, the PiP suits some driver's needs perfectly.
    Greg, thanks for trying to be the voice of reason!
    Buddy, undermine WHAT?
  3. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    And there's the old stalemate breaker... agree to disagree and move on!
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    [Moderator Note]
    This is the infamous "PiP vs. Volt" thread everyone was up in arms about. It was originally deleted because people started losing site of "debating the facts" and started "attacking members." That's a sure-fire way to get the thread removed again. I have attempted to remove some of the offending materials but some of the idiocracy is so interwoven it's difficult to clean.
    I split the original thread into two separate threads because the original intent was resolved within two pages. If you're curious, it's here:
    http://priuschat.com/threads/bought-the-prius-now-considering-the-plug-in.143982/
    My advice, if you want this thread to stay public: stick. to. the. topic.
    Bringing in politics will get it removed. Launching personal attacks will get it removed. Period! So if you want the thread to remain because you feel you've proven the PiP is superior to the Volt, play by the rules. If you want the thread to remain because you feel you've proven the Volt is superior to the PiP, play by the rules. I'm not scrubbing this thread again. It will just go away.
  5. GregP507
    3,002
    481
    Two different vehicles, each with a different fit in the car-ecosystem. One is not better than the other in any over-arching way.
  6. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    I wish I had seen this earlier !
    I personally went through a long analysis of the Volt versus the PIP. A friend of mine wanted to buy either one too. After a long analysis we concluded it was best for him to buy a volt and me a pip.
    Why ? 90% of his driving is less than 30 miles....Most of my driving is greater than 75.
    I needed a better hybid, he need a longer range electric.
    Hope this thread stays open !
  7. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I found some data on the Volt/Prius by the INEL.
    http://avt.inel.gov/pdf/phev/fact2013toyotapriusphev.pdf
    http://avt.inel.gov/pdf/EREV/fact2013chevroletvolt.pdf
    It seems to echo what everyone has memtioned. The PIP is more efficient pretty much across the board in EV/HV mode, but the Volt can go much farther on a charge. Interestingly both cars get ~75mpg@45mph, but any faster/slower and the Volt uses a lot more gas.
  8. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    mostly entertaining thread, maybe even more so before it got cleaned up
    Bill - I did question this when I owned my PiP as I was at 90% EV.
    However after 3 1/2 weeks in my Volt I've used no gas - just 3/100 of a gallon at 500 miles when the Volt ran "maintenance".
    So 900 miles, no gas yet the Volt monitor now says my oil life is 97%. That would imply a need for an oil change sometime during the 2nd year.
    Given I will have to use some gas (before it gets stale) that oil change may come even sooner
    Are you seeing something different ?
  9. inferno
    inferno Senior Member
    1,072
    405
    Does PiP or Volt have different oil change schedules? Is it measured? I wonder because it could ultimately be cheaper to not drain and refill the oil if the life of the oil is still good.
    With my regular Prius I was hoping for less oil change because it's a hybrid. Now while maybe a regular car goes every 5,000 miles it was nice to just have one every 10,000. I assume PiP and Volt may have the same schedule, or do they actually measure EV distance and say "You don't need one yet!"
  10. bisco
    52,789
    pip does not. but i'm not going to change my oil now that the free ones are over, i just don't use the ice much, anymore.
  11. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    my point was the Volt is supposed to measure but given I've used no gas and the "oil life" reading has still been declining I'm not so sure unless there is an age component to it.
    What I'm seeing would imply a minimum oil change interval of a bit under 2 years if you used no gas and of course you do need to use at least 8-9 gallons in that time. So some slight savings over a PiP but nothing notable
  12. GregP507
    3,002
    481
    For those who constantly err on the side of caution, change your oil. But personally, I've never had a problem with engine wear since I switched to synthetic oils, often going up to 20,000 miles between oil changes.
  13. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    You will very likely be changing the oil every 2 years, as recommended by the Volt maintenance schedule. My 2011 Volt is now 3.7 years old with 91,000 miles on the odometer (32,000 of them in hybrid mode) and it has had only 1 oil change. The car computer says the current oil still has 16% oil life remaining.
    Most of my engine use is for highway driving for 20+ mile stretches which is easier on oil life than stop/start city use but since you drive on a higher EV% on fewer miles than me I think you will get the same 2 year end result. This is common for Volt owners.
    Don't worry about stale gas. You noticed the engine maintenance mode that burns about .03 gallons to heat up and lubricate the engine at least evey 6 weeks. There is also a fuel maintenance mode which ensures that the engine runs to use any gas in the tank that has an average life of over 12 months. The fuel mode will end when you put enough fresh gas in the tank to bring the average gasoline age substantially down below a year old.
    I personally have never seen either maintenance mode on my car. Fuel maintenance mode is so uncommon that people celebrate it as an achievement award when it happens.
  14. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    thanks both of you
    I'll take advantage of their freebies getting in at least one right before the 2 yrs expires.
    Jeff - re the gas - are you saying I shouldn't have to intentionally burn any ?
    Two of my 3 fill-ups in the PiP were due to the 6 month rule...
  15. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Right, the Volt will keep track of this for you automatically and, if needed, it will force you to use only hybrid mode until you add enough fresh gas to the tank to lower the average age to be well under 12 months.
    The PiP has an engine maintenance mode which runs the engine every 124 (200 km) miles. The Volt engine maintenance mode requires the engine to run long enough to come up to full operating temperature at least once every 6 weeks regardless of odometer miles.
    I'm not aware of any automatic PiP fuel maintenance mode.
    The PiP maintenance schedule calls for the oil to be changed at least every 12 months or 10,000 miles. If you think that is too frequent because you rarely use the engine then I would at least change it every 2 years. I'm guessing some components of the oil might go "stale" or begin to separate out like they do for gasoline.
    #555 Jeff N, Aug 13, 2014
  16. bisco
    52,789
    that's a good question, i wonder if synthetic can go 'stale'?
  17. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The oil itself should last an extremely long time. Problems come from the impurities it captures through normal use.
  18. bisco
    52,789
    agreed, that's why i see no point to changing it until 2o,ooo on hv, which i probably won't hit before trade in.
  19. GregP507
    3,002
    481
    I don't know if it goes stale or impurities accumulate, but some oils are said to become acidic over time. I'm not sure if it relates to sulfur content reacting with water from condensation, but it's probably a good idea to change it at least once a year, regardless.
  20. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Don't you have the free Toyotacare until 25k miles? So the oil would be changed for free at 10k and 20k miles? Or is it different in differen't parts of the country? It might not be necessary but if it was included in the cost of the car why not take advantage of it.
