Prius Plug-in and Volt Pros and Cons
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Norton, May 9, 2014.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yeah, had to make sure to add a little flavor to the photo!:p
  2. El Dobro
    El Dobro A Member
    7,102
    3,282
    Don't taste just like chicken. :p
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    :whistle: (y)
  4. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Zth,
    I'm just asking questions.
    I have six different flashlights that use 18650 Li-Ion (protected) cells.
    They are awesome. One is like a motorcycle headlight. They don't self-discharge when not in use. They are small and light weight. They are the future! I wish I could get more portable electronics that use them.
    But, I would never charge them at "1C, peaking at 1.5C".
    I "Doubt" they would last as long if I did that to them.
    What's wrong with questioning? It's all just talk...
    Only time will tell how well the different BEV and PHEV battery packs last. Correct?
    "When I win the lottery" and can afford an expensive BEV as a second car, You bet I'll be getting a Tesla Roadster.
    What are they going for used? Are there any with 'iffy' battery packs yet?
    I could replace the thousands of individual 18650 cells myself !! It doesn't sound like a hi-tech way to make a battery pack. I have worked with a battery spot welder. I'll just have to get a deal from a Chinese supplier. ( I have an old Lotus in the garage now, and have had a few others. I'm familiar with this brand of 'fine' British engineering, so I can maintain the rest of the car)
  5. Zythryn
    Zythryn Senior Member
    6,410
    4,410
    There is nothing wrong with asking questions.
    What I object to is phrasing your questions, such that they imply a unsupported conclusion.
    For example, in your post about superchargers you stated:
    This wasn't phrased as a question as much as a warning.
    Which, is terribly misleading as there are many options for other charging methods.
    Your headlight lithium a are most likely not the rechargeable kind.
    All rechargeable lithium batteries degrade over time.
    Time will be the final judge over how well the battery packs last, but it is not the only indication.
    Tests can be done to rapidly charge and discharge batteries very quickly.
    1C to 1.5C is actually very gentle. Most fast chargers charge at least 2C.
    The biggest issues with rechargeable batteries is time, number of cycles, depth of cycle and temperature.
    Tesla's packs have some of the best temperature management around as that is what they have the most control over.
    No, you can't replace them yourself. These are specially made automotive class batteries. Not available at Target or Wallmart;)
    Besides, I wouldn't want to try to remove the battery pack, open it up, remove a module, the remove a cell from the module and put it all together again.
  6. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Didn't sound like a road trip to me; sounds like he did what was necessary to get it home, at which point he probably knows that he'll be able to do a huge proportion of his regular driving well within range, and driving a vehicle that is an experience like nothing else available right now. Also, knowing that Tesla generally delivers their vehicle to the buyer, he likely chose to make that trip as part of the receiving experience. You know, like people who order European delivery and have to go all the way to Europe and maybe even drive their new cars a bit before taking them home. You might have learned something if you hadn't assumed you knew everything of importance and walked away.
    Just like the Tesla isn't the ideal vehicle for every situation, your Volt certainly isn't ideal for those long road trips where the engine drones on endlessly while consuming premium fuel at a relatively high rate. A diesel would be far more pleasant for that kind of driving, yet who are we to question your preference?
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We have a 2014 Volt we purchased in Oct. 2013. We have well over 8,000 miles and a 165 mpg lifetime average. The electricity cost to drive 100 miles is less than $4.00. We just took a ride, my wife and stepson, to
    Astoria and then Costco. 41 mile round trip and we still had 9 miles of battery range left when we returned home.
    The PIP just doesn't have the electric range, and requires engine power at times even when fully charged this is the main reason I purchased the Volt. We still have our 2010 Prius which is now my car, my wife has the Volt...
  8. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    18650. Look it up. Protected or non-protected. Li-Ion. Rechargeable. Available, easily, but not at Wally's.
    I've watched a few modules get swapped out from a Prius pack. I've worked on airliner emergency power supplies swapping out bad cells. I can rebuild a Tesla Roadster pack. Or do they say "Just recycle it and buy a new one?
    Way back when Æon Flux got the idea to make a Lotus into an EV sports car there were not a lot of big Li-Ion cells to choose from. So he decided to use 18650 cells. The most common laptop computer cell. Thousands of them made into bricks. Lots of series/parallel connections.
    To this day Tesla is spot welding thousand of little metal cylinders together to make up their packs.
    Does any other manufacturer build a pack this way?
    Sure a big heavy powerful rear wheel drive car can be fun to drive!
    But can it be your only car? A Volt can. The Volt at 36-43 MPG on the highway using Regular fuel is still better than all but a few.
    alfon likes this.
  9. Zythryn
    6,410
    4,410
    Yes, it can.
    And for other people, the shorter range Leaf, Miev, etc are their only car.
    Listen, I'm glad the Volt meets all your needs. Why do you insist that other vehicles, such as the Model S can't meet all of my needs.
    markabele likes this.
  10. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    I'm glad the model S meets all your driving needs.
    I guess I'm stuck on the idea of 'Going anywhere at anytime'.
    Like a superhero or something,, "Duty calls! I'm off !!"
    Other people with only a BEV don't have these needs, or have a workaround plan , should duty call. (booty calls) {" Baby, I can't come over right now. My batteries are down." " Well mine aren't.". click }
    I really want a Tesla Roadster, someday, if they become affordable. It will be for my fast local duty needs.
  11. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    And again, when "anywhere" is further than 40 miles, enjoy that significantly sub-Prius fuel efficiency using premium fuel.
    DadofHedgehog likes this.
  12. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    My father has epitomized this ethic my entire life - driving 40-50k miles/year for as long as I can remember, preferring driving to flying, and making on average one cross country trip per year. His latest car? A Tesla that he intends to drive cross country, and he is finding that the little range anxiety he may have thought he'd have isn't being realized. Surprising but there is electric most everywhere one looks in this country. Further, changing how one thinks about travel plans isn't necessarily a bad thing; it just forces you into having a different experience.
  13. Zythryn
    6,410
    4,410
    You can't go anywhere anytime with your Volt.
    For example, you can't drive your Volt to Hawaii.
    I am guessing though, that you could care less about driving to Hawaii. Thus, not an issue in your buying decision.
    I am traveling to a larger variety of places with my EV than I have with my Volt or Prius.
  14. Zythryn
    6,410
    4,410
    Serious question for you.
    This is purely hypothetical, as there is no car that does this.
    Would you buy, for the same money, Prius A or B:
    Prius A - The car starts everyday (magically) with 50 miles of free gas, but only has a 6 gallon tank and only gets 35mpg after those free miles.
    Prius B - The car gets 50mpg at all times.
    For me, I would rather have Prius A
  15. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Hawaii? Good example.
    Prius - EPA hiwy= 48
    Volt - EPA hiwy= 40
    Yes this is significant. 20%. What percentage of my travel is burning gas? Only on Road Trips! or airport runs to pick up family and friends.
    The rest of the time who cares about gas fuel economy?
    I never talk about EV travel as free and I always point out when PiP and Volt owners talk about "Lifetime MPG" , those numbers are bogus.
    Although there are free L2's around town. I'm not stopping at the library to read magazines just to suck up $0.40 of free energy.
    Travel "a larger variety of places in your EV"?
    Finding places like this? "there is electric most everywhere one looks in this country"
    Say what? I haven't seen this. Where does an EV owner find L1 or L2 charging in the wild? Pay or 'borrow'?
    I'd like to know.
    BEV owners are pioneers. We all can learn from them and their experiences with this new type of car.
    How many have that gas burner 2nd car?
  16. Zythryn
    6,410
    4,410
    Thank you.
    I wouldn't either, however, if I am going to the library anyways...
    Absolutely! I have recently been to LaCrosse Wi and am preparing to take a driving vacation to Southern California as well as some scenery in Utah, and Arizona. Shorter stops planned at other locations. I haven't been on a vacation outside of the state in a decade. Should be fun.
    I am sure most couples do, although I know of others (such as myself) that only drive electric.
  17. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    Well, there's no such thing as "free" gas or "magic." So I'd rather have a reliable, tangible vehicle that exists. :)
  18. Zythryn
    6,410
    4,410
    Just as a hypothetical.
    I'm not asking you to invest in it or anything.
  19. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    There is a vehicle NOW that is somewhere between the A and B example above that you can buy now.
    EV's aren't free to operate but way less expensive than a gas burner.
    Plus, the EV money stays here and does not go over there....
    Plus you can power it from your rooftop.
    That's a tangible system NOW.
  20. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    But quite unrealistic for the masses.
    COST is still a major obstacle.
