Prius plug-in bugs
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by stackcheese, Sep 8, 2012.
  1. stackcheese
    stackcheese Junior Member
    50
    Pasadena, CA
    is anyone seeing this? while switching between ev, while going below 62 mph and not going beyond the EV bar to POWR bar display, the MPG consumption lights stay at 50 mpg instead of 100/999
    also while driving in a parking garage after switching to D from R, the backup camera stayed on. BTW THIS IS MORE LIKE A FEATURE THAN BUG BUT I can't seem to reproduce...
    52,743
    no, i'll have to look at the mpg, but the camera has never stayed on. how long did it stay on for?
  3. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I don't completely understand what you mean by "switching between ev", but if you switched from HV mode to EV mode then the engine could still be running to finish the warmup cycle. Alternatively, it's possible to get the ICE started, then drop below the 62mph/PWR threshold (or the midway point of the HSI indicator in HV mode) with the engine still running. To get the engine to turn off, you have to let off the accelerator a bit more before gently reapplying the accelerator.
  4. stackcheese
    50
    Pasadena, CA
    i don't remember trying to depress, but ill give it a try when it happens again.
    as far as the camera being left on, maybe about 2 floors worth of driving? 3-4 minutes
  5. bisco
    52,743
    i wonder if the camera switch (wherever it is, in the shifter assy?) got stuck?
  6. tpilkington
    tpilkington Junior Member
    No I don't see either of these things happen to me.
  7. bisco
    52,743
    tpilkington, you should change your car to the plug in and pkg.
  8. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    When you first kick over the the HV mode, it will start the engine. While the engine is warming up, the MPG won't max out at the 100 until the engine is warmed - usually stops at about 50. Usually takes about 1-2 minutes, and then it will hit the max.
