Prius plug in fog light grill
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bzyrice, May 8, 2014.
  1. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    Do you know which wire/color/where to tap in to get the foglight indicator light up where fog light is on? I installed aftermarket projector with HID kit also, but my dash does not illuminated that nice green fog light when foglight is on.
    Khawailad likes this.
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I haven't had a chance to figure it out, but its possible, for sure, because, through tech-stream you can switch them on and off, even if the car isn't equipped with it, and you see it illuminate the fog light indicator.
  3. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    actually I figured that since there is a relay present, if we give power or ground to just the right one of these, we can have it illuminate it. We would be able remove the relay all in all, and just have one wire going into the fuse box, so its easy to take take it to the dealer, just pull the wire tab and put the relay back, and it should act as if the system was turned on, i will go through my all data database tomorrow and figure out which one it is and weather its power or ground, most likely power.
  4. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
  5. Khawailad
    Khawailad Junior Member
    Galt, CA
    2014 Prius Plug-in
    Hi everyone, my first post ever. I got the grill but want to integrate with factory options.
    Don’t know what to do.
    Any help.
  6. Mendel Leisk
    42,345
    Where’s your “Galt” location; I see several on google maps. Good to nail it down, for responders.
  7. Khawailad
    Galt, CA
    2014 Prius Plug-in
    Where is this located on 2014 Plug-in Prius with JBL+navigation, without factory fog lights?
    Sorry, my bad. Galt in California
    #47 Khawailad, Jan 11, 2021
