Prius Plug in Gen1 relability
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Lovec1990, Aug 10, 2019.
  1. Karl Goh
    Karl Goh Junior Member
    31
    New Zealand
    i-Tech
    I've many questions about this car regarding
    an interior trim that i want to remove to install an additional 12v socket
    swapping oem 15" for a bridgestone japan made 15" light weight wheel model se-10
    buying a spare wheel off gen2 or normal gen3 and secure it in the car
    a screen shot of Dr. Prius app that shows my #3 cell seems much lower than others, should i be worried?
    52,858
    congrats on your new pip!
    not sure i've read anyone using doc prius on the pip yet, but if you're not getting a code, its still within parameters.
    i know a gen 3 wheel will work, not sure about gen2. check the sticky threads.
    all the best (y)
  3. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    Enjoy your new PIP. I just upgraded from an '07 to a '12 PIP. I believe that the Gen 2 spare wheels will work on your new car. I haven't tried to fit mine yet but everything 'looks' the same. I took my spare out of my '07 when trading it in (along with the jack :) ) I haven't found a way to secure it yet but wanted a spare since we use the car as our towed car on our RV trips and want to have a spare for it just in case.
  4. Karl Goh
    31
    New Zealand
    i-Tech
    i thought 2012 pip jack is right under the front seat. covered by a rectangle plastic
  5. bisco
    52,858
    correct
  6. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    You are probably correct. I just assumed since there was no spare, there was no jack either. Oh well, I've got an extra scissor jack to add more clutter to the garage now. lol Now, not only is the poor person who buys my car at auction going to need a spare tire, he/she'll need a jack also. Oops! I'll have to check on the jack when I go outside late to unplug the car.
  7. bisco
    52,858
    they still provide a jack because you have to take the weight off the tire to use the goop
    Hokie-Dave likes this.
  8. Karl Goh
    31
    New Zealand
    i-Tech
    i found it by accident.. wondering why the fk would u put a cover here... tugged it a little and it came off showing the jack, tyre iron and the jack handle..
