Prius Plug-In Production Car to be Revealed On Press Day 13 Sept
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jbrad4, Sep 1, 2011.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    OK now, some data to play with :)
    4.4 kwh nominal capacity
    1.5 hours to full charge at 240 V mains
    ? 10 amps ?
    That would mean 3.6 kwh useable, for 14.3 miles. And 80% DoD. Sounds reasonable
    CD efficiency is 3600/14.3 = 251 wh/mile
    If charge losses are 15%, then wall-wheel is 251/.85 = 295.3 wh/mile
    If EV range is also 14.3 miles by EPA testing, mpg(e) will be 33,400/295.3 = 113.
    These calcs compare nicely with the Euro stated 134.5 Uk miles/gallon, or 112 US MPG.
  2. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I can't believe Toyota would base their estimate on the EPA. I'm sure LEAF owners would tell you that they definitely don't need 340Wh/mi.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ I hope not. MS -- blech
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    Oh, I'm pretty confident in my guess that Toyota is basing EV range on either the EPA or NDEC cycle. Use of an easier cycle like Nissan and GM did just sets the company up for charges of hype. Particularly so in GM's case, since they were not forthright in saying what drive cycle was used. Since Toyota has not specified a drive cycle either, I reason that a more demanding cycle underlies the press release.
  6. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    It won't be 14.3 in EPA testing.
    BTW, there is a problem with EPA testing of Prius PHV. Unlike Volt, Prius will not run in pure EV mode at highway speeds. That means EPA can only use urban cycle to test PHV and not the highway cycle. So, they won't be able to give a combined rating ...
  7. gwmort
    gwmort Active Member
    985
    211
    Delaware
    Ouch! no tax credit for < 5kwh
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ You had that error corrected already in another post. Are you reduced to trolling ?
    A drop of common sense should tell you that Toyota would not skimp on 0.5 kwh of battery capacity if it meant $2500 in subsidy lost.
  9. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    incorrect, its 4KW or more, it qualifies for $2500 credit
    State & Federal Incentives | Plug In America
    "For Cars
    $2,500 to $7,500 tax credit, depending on size of battery (4 kWh to 16 kWh), for electric-drive vehicles (EVs and PHEVs) sold after December 31, 2008. This is the best and biggest new incentive brought on by the American Recovery and Reinvestment Act of 2009 (stimulus bill), and applies to at least 200,000 units per auto manufacturer before it phases out."
  10. hill
    8,752
    maybe not Montana highway speeds - but here in So Cal on a GOOD day you'd be lucky to do stretches of 55mph-60mph ... and on my test drive, the PHEV was doing just fine in EV mode, at those speeds. You don't have to do 75 - 80 in order to call it highway speed.
  11. ItsNotAboutTheMoney
    2,287
    460
    Maine
    Well, the LEAF gets 109 miles on the NEDC. Nissan said 100 miles.
    So, if Toyota are using the NEDC they must be hyping it.
    I can't believe they'd use the EPA: it's an economy rating based on drivers who don't care about economy.
  12. gwmort
    985
    211
    Delaware
    My error, I posted it quickly in a couple of threads and am trying to go back and correct now. I concur it will qualify for the base $2500 credit.
  13. Zanrok
    Zanrok Casual Prius Lover
    181
    30
    Reno, NV
    Awesome! We have a feature list for the new MYPRIUS 2012. Now we just need a confirmed release date, and pricing....
    Hopefully it will be before the end of the 2011... but with those fleet charts linked on the forums it probably won't be... =(
  14. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Well???? Today is the day, right???
  15. mfennell
    mfennell New Member
    241
    39
    3.6 of a 4.4kWh feels too aggressive for Toyota. My own out-my-nice person numbers:
    ? 12 amps ?
    That's 4.3 into the battery vs. 3.7 testers reported in the preproduction cars. Assuming equivalent charging efficiency, let's call it 3.2 kWh usable. Even 72% of the pack still seems high to me.
    3200/14.3 = 224 Wh.
    No reason to expect charging efficiency to be dramatically better than the tester cars: 224/0.75 = 299 Wh/mi. Nearly the same result, different path but no real idea what it means relative to other cars.
    The light weight is nice to see. Since the city cycle results are essentially a proxy for weight with a well designed EV powertrain (that is, NOT a Smart...), I can believe 30kWh/100mi. Not sure they'll include that info on the EPA sticker though. As evnow says, it can't complete the HWY cycle and the new stickers only show combined numbers.
  16. hill
    8,752
    what ... for price? maybe Toyota meant 'partial reveal'. If Toyota waits long to reveal price, it's likely because they wana see how much more worthless paper money the U.S. Treasury will print between now and first sales. It's just a thought -because a sharp swing in the yen to do dollar values could mean the difference between brisk sales, versus mediocre/GM sales levels.
  17. ItsNotAboutTheMoney
    2,287
    460
    Maine
    For technical details. No price yet.
    14.3 miles good enough for your commute?
    PS Don Meyer drove a Prius and he won lots of, oh never mind ...
  18. austingreen
    austingreen Senior Member
    13,667
    4,209
    Austin, TX, USA
    Toyota is quoting a euro, not an american range number of 23km. I don't think you can read anything from that. Certainly if the prius uses a gas it can use less than 300 Wh/mi, but we don't know that strategy. Certainly driven the same way, if staying all electric the prius phv is going to do worse than the tesla roadster, so any numbers much higher lack reality.
    There should be a city/highway/combined break out for blended mode on the fueleconomy.gov site. I doubt they will do a ev city/blended highway. It will all just read blended. The numbers will be highly dependent on programming there are good reasons to believe the programming with be different than the demo cars. Toyota needs to step up to the plate and give us EPA estimates.
    Well for those that were mad at gm for hyping and not telling epa figures or prices, toyota now has been in this game for years. I don't think that is fair for either car, but maybe the hype mongers can tell us EPA and price.
    I think its just business as usual for a big car company. They do a big press event but don't show the key information. The lack of disclosure of EPA driving cycles may reflect a negotiation to change the way blended mode is measured. The lack of pricing information is likely so they can get people to continue to write how inexpensive the car will be when the reality may not be so good. There are competitive reasons also, as the information may help ford trump toyota on their press release.
    Toyota has already stated 20K units for the first year. They aren't going to be producing nearly as many prius phvs as the ramped up leaf and volt when the car comes out. The sales will be constrained by production as they are by those other cars in the first year.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    50k units the first year by the press release today, although I do not think Toyota specified which markets are included.
