Prius "plug-in" requirements
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PriusPlug, Dec 4, 2012.
  1. lensovet
    2,615
    496
    Burlington, NJ
    yeah, this.
    and actually, you'd be surprised. i have a 2wire DSL modem that I originally got through my AT&T service, and I've had to replace its power supply twice in 4 years. despite the fact that it's always plugged into a UPS!
    Andyprius # 1 likes this.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    was your UPS output pure sine wave? They're the more expensive one's. I had a inexpensive 1375 watt ups connected to my Desktop, my Desktop kept shutting off. Found out it was the active power factor power supply in the Desktop doesn't like "Stepped Wave" (fancy word for square wave) output. Fortunately the power supply was covered under it's warranty (just had to pay for shipping) Since then, I got a relatively inexpensive ($200.99) 900 watt Pure sine wave UPS. Haven't had problems with my Desktop since.:D
  3. lensovet
    2,615
    496
    Burlington, NJ
    yeah, it's a more expensive simulated sine wave unit. the only thing running on it is the DSL router though, and replacing the router's power supply costs $10 every two years, vs. getting a pure sinewave unit of similar capacity for $200. so i'll stick with replacing the power supplies for now lol.
    i do have another UPS driving my mac mini server, and that's a pure sine wave model.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, I learned the hard way, I figured UPS, 1375 watt, pretty cheap, what could go wrong? Then the Power supply guys gave me the bad news. Called the 1375 watt UPS guys, asked what the output was, because it's not spelled out in the spec's.They told me Stepped wave. Oop's sorry, we got pure sine wave for sale $500.00, I said, no thanks. I asked if I could trade in my 1375 watter. Nope.:cry:
  5. PriusPlug
    PriusPlug Junior Member
    32
    I checked my main panel again and found something every interesting. The GFCI outlet in the Garage is on the same breaker with my laundry room outlets for washer and dryer :). So If I were to use the GFCI outlet in the garage then I need to make sure that I don't turn on the washer/dryer at the same as I am charging Prius which is reasonable.
    For those of you who got an outlet installed for the charger, did you put it inside the garage or outside?.
  6. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I have an outlet inthe stage and It is not GFCI. GFCI outlets are inside the house but not in the garage. The house was built new in 2000. Guess I'll have to check Into that when I get closer to trading in my prius for a PIP
  7. John H
    John H Senior Member
    2,208
    558
    adding a 240v outlet is about $15 more than adding a 120V outlet.
    JMD likes this.
  8. JMD
    3,779
    1,282
    That is good to know.
  9. JMD
    3,779
    1,282
    Thanks John.
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yup, forgot to disclaimer to not do what I do. I fully know what I am doing and stubbornly taking the risks. I was just saying I wasn't aware of the situation for awhile and the PiP safely notified me it didn't like it.
  11. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I've had UPSes for ages and none are pure sine wave and almost all of them are APC, yet none of them have caused trouble for my computers or any of my devices. I've run them during power outages. I think my oldest UPS is from at least 10 years ago (it's an APC Back-UPS Pro 1400, I believe Back-UPS Pro 1400VA is right).
    Stepped approximation of sine waves are not equal to pure square waves.
  12. lensovet
    2,615
    496
    Burlington, NJ
    it depends on your equipment. new PFC power supplies are very picky about the waveform that they get. if you're running laptops or a power supply that accepts a range of voltages (i.e. worldwide), then obviously it's not going to be affected.
    these are the two units i'm using:
    Cyberpower CP1500AVRLCD UPS - LCD Display 1500VA/900W AVR 8-Outlet RJ11/RJ45/Coax Tower USB (simulated sine) (used for DSL and wired router)
    CyberPower CP1500PFCLCD UPS 1500VA 900W PFC Compatible Pure Sine Wave (used for mac mini)
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, I got APC 1300 which is 780 watts on my tv, printer, laptop, blu-ray and have had it for five years with no problem. But on my Desktop which I purchased last year along with Powercom KIN-2200AP 2200 VA 1320 Watts. About six months later my Desktop kept shutting off for no reason.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, the CP1500PFCLD is what I replaced the 1320 watter with
  15. fuzzy1
    10,673
    When you know what you are doing and are diligent, it certainly can be done safely. Having a 20 amp circuit, rather than 15, helps considerably. But typical households, containing any family member who is not technically inclined, shouldn't try.
    mmmodem likes this.
  16. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I've never heard of Powercom until now. I don't trust Cyberpower very much as they seem to be a recent name, specializing in budget UPSes. Surprisingly, the latter was founded in 1997, yet I hadn't heard of them until the last 5 years or so.
    The only UPSes I've ever owned were APC, Conext (one of their lower tier brands) and a rebadged as IBM Tripp Lite. The Tripp Lite eventually went wonky and I've had one APC seemingly go bad (or was damaged in a move). Both of those were real cheap though, so no big loss.
  17. lensovet
    2,615
    496
    Burlington, NJ
    I remember my dad buying a CyberPower UPS over a decade ago…had no idea what I was doing, plugged a vacuum into it, and the fuse didn't blow so the thing died. We called up customer service, they sent us a free replacement of an upgraded model, no questions asked. The two units I have here have served me well so far :)
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Just got my handy-dandy Oscilloscope today and checked the outputs of all three of my battery back ups just two pic's b/c the cyberpower has the same output (sine wave) with line disconnected (in battery back up mode) and connected. but the Powercom and the APC have squarewaves in battery backup mode but sine waves when a/c line is connected. I realize this has noting to do with the PIP but is on topic (per Se):whistle: S1240002.JPG S1240001.JPG
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    now I understand how:cry: my desktop power supply failed
    lensovet likes this.
  20. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Not surprising that when you are on AC power, you get a pure sine wave since the UPS is just passing through the utility power. Nice that the cyberpower UPS appears to have a real sine wave waveform.
