Prius Plug-in Versus Volt: Which Costs Less to Drive?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 20, 2011.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Why do you still show the Volt using $0.20 of electricity for the first 5 miles but the PiP only using $0.13?
    If the chart shows the PiP has 10 miles (9.75) of range for a 3.6 kWh charge and the Volt has 35 miles of range for a 12.9 kWh charge then both cars should have the same battery charge operating cost (around 2.7 miles per kWh).
  2. gwmort
    gwmort Active Member
    985
    211
    Delaware
    You're not far off, mostly just the problem with your first two data point for the PiP, which you underestimate by about half. I figured 68 cents for the first 15 miles in the Pip (3 kwh at 33 cents and 0.1 gallons at 35 cents) or 4.5 cents per mile.
    The Volt beats is at about 3.7 cents per mile (12 kwh over 35 miles at 11 cents per kwh).
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Good catch. I was still dividing by 15 instead of 10. Fixed now.
    For graph #1 using today's average prices, the worst case for PiP at 35 miles is $0.76 cents more than the Volt.
    Over 150k miles, assuming you always make 35 miles trip, the cost difference in fuel is $3,257. We know nobody always make 35 miles trip and only charge once. Per GM, Volt owners put 2/3 of the miles on electric and 1/3 on gas. That would mean, we should look at the 52.5 miles mark. That would bring the fuel cost difference to $614 over 150k miles lifetime.
    It will also depend on the price of electricity and gas. If you consider the purchase price difference, Volt will generally cost more to own despite being a compact.
  4. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Fixed. I updated that post. We are now at 60 and 65 miles mark.
  5. gwmort
    985
    211
    Delaware
    Good work, I agree with your conclusions and your graphs as updated (until we get EPA numbers for the PiP).
    Important to note that this is a dollar to dollar comparison where there is no difference between 1 gallon of gas at $3.50 or about 32 kwh of electricity.
    I personally am not as concerned with low cost per mile as I am in using less petroleum. Even at equal cost, the Volt will use less oil until trip distances over 100 miles.
    I am at 10,450 miles traveled and just over 82 gallons of liquid fuel consumed. For the same distance in a conventional prius at 50 mpg I would have consumed 209 gallons of liquid fuel. I charge for free about half the time so I did save a bunch of money, but the important part to me is that 127 gallons of gas (more than 6.5 barrels of crude).
    My understanding is that even with the PiP the Volt will still use less gas (about 80% of the PiP) for most drivers (regardless of electric costs).
    3 people like this.
  6. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I should have clarified a bit. Mine is a 2006 with a Hymotion conversion. It doesn't display the kwh used, I am calculating it with a Kill-A-Watt meter and miles driven on purely electric. This is about a 5 mile round trip at low speeds of 31 mph or less. Yes, 31 mph, or else the engine will start up.
  7. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    I still think the PiP will come out ahead in the long run compared to the Volt.. I just wanted to be able to do my daily drive/errands without using gasoline. I can say personally that if I travel more than 70 miles taking the Volt is NOT an option as its fuel economy dips below what we can attain in our regular 11' Prius. So 50 miles for the PiP to break even seems about right to me. I hope the PiP is like the Volt in which the 15 mile estimate is a "low ball" figure.. GM says the Volt is only supposed to go 35, but 40 is easily attainable. Hopefully the PiP will get somwhere around 20 in EV mode.
    Personally I think my kwh/mile usage is high. On the myvolt.com site it says I use 32kwh/100 mile. I really do not pay much attention to overall consumption on it though unless I am driving from one side of Jacksonville to the other, but compared to other people going 50+ miles per charge I am kind of on the low end of the spectrum. I am going to Lowes to pick up that kwh meter today so I can install it on the line and see exactly what the car is drawing after my daily drives to work and back.
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Agree with gwmort, good numbers with less gas. Cost difference based on trip lengths aside, get at least a 1/3 of the population to either buy a Volt, leaf or PIP or any hybrids, these numbers would add up big.
    2 people like this.
  9. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    That's specifically for you. What if you have PiP instead of the Volt, how many gallons would you use?
    In general, Volt would save 1,650 gallons over a no-plug Prius. However, you need to look at the flip side as well. Volt is going to consume 36,857 kWh of electricity and no-plug Prius will consume no electricity. If we compare Volt to the Prius Plugin, it will save even less gasoline.
    We need to step back and look at the bigger picture. There are bigger fish to fry. If you can replace your wife's 19 MPG SUV with a no-plug Prius, you can save 4,900 gallons of gas without consuming any electricity.
    It seems we are at a point where saving additional gas requires another form of energy to substitute. We are not saving gas, but trading so we need to be careful if the trade is worth it.
  10. Roadburner440
    316
    59
    Hampton, VA
    For me I am really big into hydrogen vehicles.. Especially since you can convert any conventional vehicle to use it without having to build an entire new car (like the electrics). Unfortunately to me I think the infrastructure will never come, and they will villify the volatility of hydrogen so people won't want it. I am unsure what the emissions side comes out to be for a kwh of electricity vs gasoline equivelent. No such thing as free energy though, so we are kind of between a rock and a hard place as far as that goes. People charging with solar at least have made a good trade off as they truly have next to no emissions on EV.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Doesn't this assume you can get the same number of gallons of premium from a barrel of oil as regular unleaded?
  12. gwmort
    985
    211
    Delaware
    I suppose so, I guess I'm off by 6% or so (87 to 93 octane). The exact numbers not really the point its the reduced net consumption.
    My home PV system just got all the permits approved and we're scheduling the install. Once done I'll have no emissions for 70% of my driving. I think its a good trade off from the imported oil.
    John asked above about how much gas I'd have saved with the PiP. I'd say more would be saved than in a conventional prius but less saved than the Volt. My commute is about 20 miles each way with 16 of it at 70 mph or above, even with a full charge at home and work I'd be burning gas everyday in a PiP, where I normally don't in a Volt.
  13. Trollbait
    12,822
    Since premium gas does have slightly less energy content than regular, and non petroleum sourced additives, such as ethanol, might be use to increase the octane rating. It's a safe assumption. Burning premium in an engine that can take advantage of the octane rating will likely lead less total petroleum use over regular.
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Which costs less in Carbon footprint I wonder?
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    3.6 kWh is taken from the prototype vehicle but it had 5.2 kWh battery. This leads me to believe that the 10-15 miles of the PiP will use less than 3.6 kWh.
    We should wait to the full specs and EPA official numbers before jumping to conclusions.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The mercury output from coal burning is pretty horrendous so a big thumbs up for you plugin and EV owners who are running your own solar or using a better mix of energy. :)
  17. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I could be churlish and ask why you hadn't already installed PV. ;)
    I know that PV economics can be significantly improved by running an EV as it can increase the value of a larger array. Do you have a TOU tariff?
  18. gwmort
    985
    211
    Delaware
    I don't think its called a tariff but we are going to a TOU plan with the smart meter going in as part of the system. It'll allow me to sell power to the grid at peak rates during the day (when the extra generation is most needed) and then charge on lower rates at night for a net gain.
  19. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    I must admit, I am quite amazed that you can do that! Very cool!
  20. Rest
    Rest Active Member
    1,210
    CA
    Everything I've seen points to the PIP as being less expensive in the long run than the Volt. However, the PIP still looks like a Jetson's car and the Volt has a more traditional look. I prefer the traditional car look.
    I'm also not pleased that the energy drive display is such a terrible screen with a lower resolution than the NAV display. At least on the 2nd generation Prius it was much crisper with the LCD display. And this is where the Volt really pulls ahead with its displays.
