Prius Plug-in Versus Volt: Which Costs Less to Drive?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 20, 2011.
  1. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Looks really are a matter of taste. I MUCH prefer the PiP to the Volt in looks. The 2012 dash display on the Prius (including the PiP) has been improved and may please you more.
    But the long run consideration which is most compelling for me is the size of the traction battery. I expect a car with a traction battery which is Li Ion to need at least one replacement in a typical car. Replacing the PiP traction battery will be far less expensive than replacing the Volt traction battery since it is only a little more than a quarter the size of the Volt traction battery. In the lifetime cost of the car, this will be a substantial factor. It is always possible that the warranty will cover this, but it is as possible that it will not. It is a "crap shoot" at this stage because no one really knows for sure.
    I am betting on the PiP (quite literally).
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The PIP warranty is 150k miles, while the Volt's IIRC is 100k.
  4. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    In texas the PIP will be 100K but won't be available until 2013.
  5. Sergiospl
    3,938
    1,351
    28
    You mean as traditional as the Cruze?
  6. Rest
    Rest Active Member
    1,210
    CA
    Apparently it hasn't improved much. They are still using that low res bluish speedometer type gauge.
    Now I will say that the Prius using Bluetooth connectivity for an iPod is nice. I don't understand why the Volt stuck with wired connectivity. That's pretty lame for such a futuristic car.
  7. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I like that it has the USB connection, this way I never have to worry about charging my ipod, I just keep it plugged in in the console all the time (control it through the touch screen in the dash).
  8. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    This is being fixed in the 2012 model year where they also added Prius-style proximity keyless entry which is the main feature I miss in my 2011 Volt.
    However, the Bluetooth audio streaming can be easily added after the fact for less than $100 dollars by dropping a Bluetooth receiver into the center arm console and hooking it up to the mini-stereo analog audio input there.
  9. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The PiP warranty will be 150k miles (in states that follow CA emissions rules) when the car becomes available for sale next Spring. GM says the Volt will be available in the same states with some emissions tweaks by early Summer and will also carry the same 150K mile battery warranty.
  10. Trollbait
    12,831
    It's 100k in most of the US. The 150k warranty is in Carb states only. Granted that is 14, IIRC, of the most populous states.
  11. Allannde
    874
    138
    Washington State
    I called this warranty thing a "crap shoot" for a reason. I have followed EVs closely for five years including owning two. Lithium Ion batteries are different from NiMH batteries in the Prius in that they deteriorate quite independent of usage. If the car is just parked, they deteriorate. The warranties are a matter of law. If the batteries start failing in large numbers, manufacturers will invoke the clause which exempts coverage when there is abuse of the battery to prevent loosing lots of money. Most people will not be able to afford the litigation to prove that they did not abuse the battery. It will be a "Hobson's choice" for both the car owner and the manufacturer (who is obviously worried about reputation and public image).
    This may work out fine for all it may not. This is the definition of a "crap shoot". The gamble is A LOT bigger with the Volt. Considering the title of this thread, it is easily a potential tipping point.
  12. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    So far GM seems to be honoring the warranty on the Volt.. They have replaced 2 batteries in cars that I am aware, and had to arrange to flat bed the batteries from Michigan to where the owners were. One of the battery replacements actually happened where I am moving to, and after that guys experience that will become my preferred dealer for service.
    Having the keyless entry in the 12' Volt is awesome! I thought our Prius II was amazing with it on the driver door, but having it on all 5 doors is a bonus. I also really like the way GM incorporated it into the Volt vise the way Toyota did it. Push the button once to unlock my door, twice to unlock all doors, and a third time to lock them. Your 11' and my 12' should be getting that new software update as well to incorporate the streaming bluetooth music.. At least that is what I was reading anyway.
  13. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    I recall seeing that one electric utility wanted to have more solar generation capacity, so if you installed solar, they'd pay you a high rate to buy back 100% of your generation (like 25 or 30¢/kWh), and then sell you 100% of your electricity at the regular rate (maybe 12¢/kWh). This was independent of TOU, so even if you were using all the electricity that you were generating at any given moment, you still profited.
  14. gwmort
    985
    211
    Delaware
    I also get some sort of transferable credit for the solar generation we sell to industry that is required to have lower emissions or something and get some money that way as well.
    The main thing I like about it though is knowing that for the next 15 years (finance period) my electric costs are more or less fixed (unless my demand exceeds the generation in the future) which gives me some insulation from cost increases for energy in general.
  15. Rest
    Rest Active Member
    1,210
    CA
    While this is true, you'd think it would be standard equipment, not like it's recently new technology.
  16. Sergiospl
    3,938
    1,351
    28
    Plug-in Prius Wins the 2011 Rallye International Vert de Montreal | Inhabitat - Green Design Will Save the World
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Does Volt's keyless system has a touch sensor in the door handle?
    Nissan and Infiniti systems don't. They require you to press the button on the handle to unlock.
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    GM's warranty information said Volt's battery pack could have 70% of the original capacity after 8 years. Industry standard (including Toyota hybrids) for the end of battery life is 80%.
    This doesn't mean the range would be reduced to 24.5 EV miles (from 35 original). Volt will actually use wider depth of discharge to maintain close to 35 miles. That would actually accelerate the end of life. It is a trade-off between consistent EV miles vs. prolonging the battery life.
  19. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Did GM really say they were going to ignore the SOC and DOD and continue to provide a high average range with low capacity cells? That to me screams exponential death curve.
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Right, so it was engineered to last at least 10 years / 150k miles.
