Prius Plugin Handling
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by johnpa, Jul 3, 2013.
  1. johnpa
    johnpa Junior Member
    Bethesda, MD
    Has anyone with a plug in Prius had a problem with the vehicle tracking at highway speeds? I have had mine back to the dealer (DAR Cars 355 Toyota in Rockville MD) 3 times and they are unable to duplicate or identify the problem. A case has been opened with Toyota and basically what I am getting back is "this is the way the car handles" and "the alignment is within spec".
    I was wondering if anyone else has noticed a similar handling problem. The car feels like it is being buffeted by a cross wind and wants to wander back and forth in the lane I am driving.
    I apprieciate any feedback. I am trying to figure out if this is a one off problem or just poor design on the part of Toyota.
    I find a car that wanders at highway speed (where I do most of my driving) is unexceptable.
    Thanks
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It's normal for the Prius. It is not aerodynamically designed to handle side winds at high speeds.
    The only way to solve this condition is to install lowering springs and 17" wheels. At least that's how a lot of us solved it.
    52,773
    welcome to priuschat! why are you asking about plug in prius, do you have one? it is the same as non plug in as far as aerodynamics are concerned. what do you mean by highway speeds? i don't have any problems at 65mph.
  4. John in LB
    John in LB Life is good
    399
    27
    Orange County
    This issue is not limited to the Plug-in version - check the other forums. The car does not track straight easily and needs the driver's constant steering input.... (I had a 2006 and now the plug-in; both did it - however, the 2012 is much better)
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I only notice it when there are water hydroplaning reduction grooves on the highway parallel with the direction of travel. I've heard that is due to the low rolling resistance tires with high pressure.
  6. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I know how you feel about any Japanese car with strut front suspension.
    I drove a Passat in Europe, doing 185 kmph, it will go straight for kms hands off the steering wheel until came to a curve.
  7. johnpa
    Bethesda, MD
    Mine is miserable on the highway. It wants to wander back and forth now matter how minimal the steering wheel response might be. The dealership and Toyota have been no help. I am really at a loss as to what to do.
  8. bisco
    52,773
    how about a quality alignment shoppe and new tyres?
  9. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    The TRD/Prius+ lowering springs and rear sway bar help a lot with the problem, as does an upgraded center chassis brace. Going to fuel wasting 17" wheels and tires is not necessary, and may even exacerbate the problem, since they will probably be heavier, increasing unsprung weight beyond what the factory suspension is designed to control.
  10. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    When mine was new I noticed that it seemed to wander a bit where there were "rain grooves" in the pavement. I now have 17K miles on it, and it has mostly settled in to where I rarely feel the wandering. I wonder if this is what the OP is describing? I asked other new owners who drive the same freeways about it and nobody had noticed it with their cars. A couple of them have the Advanced model, which may have different tires.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    Not noticing any tracking problems here. I've owned so many cars, I'm probably just auto-correcting. :D
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yea! The older I get the less I notice! Makes things seem better! :p
  13. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Why not try borrowing another Prius or asking the dealer to loan you one so you can see if it just yours.
    Mike
  14. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    experiment with PSI in front/rear tires, they need to be different to help reduce some of these characteristics. Just gotta find the sweet spot for front to rear pressure.
    Dan
  15. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    You're in Bethesda - I'm in Arlington. PM me and we can meet over the weekend and you can compare what I've done to solve this and some other issues.
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Mine does not bother me. It drives better than Gen2.
    What tire and psi do you have?
  17. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Have not noticed any handling problems here... easy and fun to drive!
    radio
  18. Boulder27
    Boulder27 New Member
    Silver Spring, MD
    I likely drive the same roads as you and do not notice any problem in mine. (Purchased and pass by that dealership daily).
  19. johnpa
    Bethesda, MD
    Back to the dealer for the 4th time to have the Toyota regional tech look at the car. Of course I got it back tonight and the problem is no better than it was when I took it in. Now (and I realize this is a function of them telling me there isn't a problem and they all handle this way) I have noticed that the car will drift to the left when the wheel is held in the centered position. This occurs with the car in the right lane so it isn't a road crown issue.
    The puzzlement is that each time they "check" the alignment the print out comes back with different numbers.
    The car has the stock Yokohama tires and the tire pressures are set to spec.
    I really don't think the problem is going to be resolved by the crack technicians at 355 Toyota.
    What a disappointment. I guess sometimes you just get a lemon. Unfortunately I will just get rid of the car and eat the difference. I can't drive a car that is that squirrely on the road.
    Hopefully whatever I get won't be as much of a problem.
    Thanks for all the input.
  20. El Dobro
    El Dobro A Member
    7,102
    3,282
    Try bringing the car to an independent alignment shop and see what they say.
