Prius Plugin Regrets
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by swimsrf, Jul 10, 2015.
  1. lensovet
    2,615
    496
    Burlington, NJ
    my understanding as well
    i drive a B-class, see signature; it has a number of different regen settings, but my point is that the amount of regeneration possible is higher because the motor is more powerful and the battery can support higher currents. Prius, at max, can generate 60 kW; B-class can generate 100 kW. The battery, too, is much more limited in the output it can provide; PiP takes almost 30 seconds to get to 60, while the B-class does it in under 8, despite being an extra 800 lbs heavier. What you see in the output has a corresponding match in the input, i.e. regen.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    My expectations from the Gen2 PIP are that it will still use both power sources to maximize driving efficiency and not EV range, but be "sportier" in EV mode.
  3. ICE
    ICE Junior Member
    Akron, Ohio
    2018 Prius Prime
    Just started to consider a used PiP instead of a used standard Liftback! Even though i won't be able to plug in all the time the Lithium Ion battery and extra standard features are very compelling! Do you think they are as reliable as the non the PiP's or have different longevity issues?
  4. Greg_M
    Greg_M Member
    151
    35
    NC
    Yes they are just as reliable. Of coarse no one knows about the lithium battery but it shouldn't be a problem. The good news is that depending on where you are the used price of a PIP is not much different then a regular Prius if you do some hunting and negotiation.
    ICE likes this.
  5. ICE
    ICE Junior Member
    Akron, Ohio
    2018 Prius Prime
    Thx! I'm even more in the air about what to get now! I like the cost and size of the C but the lift-back is a more mature vehicle and I do more hwy than city and having the extra space is welcome for times i need it like camping etc.. I'm small and could make do with the c, but don't like that it is weaker and made similar to the ultra budget designed yaris.. Im looking at both gen 2 and 3 used or even a new 2015 but even for 20k otd ttl seems like the depreciation would be a disadvantage and negate the fuel savings. I don't want the stress and break-in of new either.. I am holding out for an intelligent owner who needs to sell or is upgrading to gen4 who got a 2 mile one off the truck and did an early oil change, tint, amazing maintenance history etc.. The PiP seems to have very few downsides besides no spare tire and less room in the trunk and the bit of extra weight..
    #105 ICE, Jul 27, 2015
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    You can, 10 to work, then charge, then 10 back home. Don't press the pedal so hard that the engine comes on
  7. bisco
    52,863
    i hope you're disappointed.:p
    ICE likes this.
  8. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    You're going to need a truck to accommodate that backpack of yours... Or is the backpack normal size and you are just very tiny?
    ICE likes this.
  9. Eug
    Eug Swollen Member
    970
    223
    2025 Camry AWD
    XSE
    That's exactly what I do. My workplace is approx. 10 miles from my home, and I can charge at work most days.
    Still, it would be nice to have a 20-25 mile range for other trips in the city. 10 miles is pretty limiting for big North American cities.
    I don't really need a 200 mile range on electric, unless it's a pure EV.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    18.6 miles to work for me. A mix of EV, EV-BOOST (blending), and HV is quite effective for me. This morning, that worked out to 195 MPG.
    I recharge at work using solar, then get similar results on the drive home.
    bisco and ICE like this.
  11. yothere
    yothere Junior Member
    22
    Don't do that. Drive normally. Let the car take care of itself.
    Don't do that.
    Don't do that.
    If it stresses you out, don't do that.
    Do you mean regenerative braking? If it stresses you out, don't do that.
    Don't bother. The car is very smart and can take care of itself. And no, a regular Prius has significantly shorter ev range and lower combined mpg's.
    You've purchased a very fuel efficient car. Enjoy it. Let the car take care of the details. Good luck.
    #111 yothere, Aug 3, 2015
    Tracksyde likes this.
  12. john1701a
    12,840
    5,312
    58
    That's the point.
    You drive like you normally would.
    The electricity is still taken fully advantage of, even when the engine runs. You get outstanding MPG as a result.
