Prius plugin test drive
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by uskyrt, Nov 23, 2013.
  1. uskyrt
    uskyrt Junior Member
    Newcastle upon Tyne
    Hello, I'm from UK (well, I'm Italian really) and I'm planning on getting a Prius plugin soon (I hope!)
    Today I've driven one for the first time and, as usual, the salesman wasn't really knowledgeable so we had a few issues.
    The one I'm most worried about has been because of the battery: on the dashboard it said was almost full but the seller (an official Toyota salesman) has not been able to let me drive in EV mode only. Pressing the EV button the dashboard said that the battery wasn't charged enough. Is that a normal behaviour? Are there 2 battery indicators?
    Tomorrow I'll have a second test drive with another Prius but, in case they won't be able to explain me why this has happened do you have any idea?
    We've been driving it for about 3 miles before trying the EV mode and the temperature was around 10 C° (50 F). I've read a previous post about EV mode and low temperatures...
    Thank you for any answer you can give me!
    Uskyrt.
  2. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Whereabouts are you? Perhaps a PiP owner here will let you take an informed ride.
  3. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The cars here in the US seem to ship with no charge in the battery. It just needed to be plugged in to allow EV.
  4. uskyrt
    Newcastle upon Tyne
    I'm around Newcastle upon Tyne and Consett,
    To answer jdk2 the car already had about 4700 mi on it and was sold by an official Toyota salesman.
    Thanks!
    Let me know if I can provide more info!
  5. Biking Maniac
    Biking Maniac Five Prius – have not sold one yet!
    58
    Menomonie Wisconsin
    2001 Prius
    Essentially there are two battery indicators that exist in the same dashboard real estate, but one battery (well, two if you count the 12 volt) One of the battery indicators has a solid appearance and is an indication of how many EV miles you have available. When the EV miles are depleted, the indicator goes to a striped appearance. This is just like the battery indicator in a standard hybrid Prius. That must be what you were seeing, if you try to go to EV at that point, the car will tell you cannot go into EV mode. Have the dealer put the charger in for 30 minutes or so and you should be able to give EV a try! Good luck!
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I just think the car needs to be plugged in or descend a very long and steep hill. And usually the official salesmen know far less than the members here but that's for another discussion :rolleyes:Once you're able to plug in, the battery indicator will turn solid green instead of the bars and you'll have a text indicator of EV miles left.
  7. uskyrt
    Newcastle upon Tyne
    OK that's it then... The battery on the dashboard was similar to this:
    Imagine a battery made out of grey striped horizontal chunks rather than solid fill.
    Hopefully tomorrow they'll make sure the battery it's fully charged. I really want to try it in EV mode only.
    We'll see!
    Thanks a lot for your help, I knew this was the right place to come and ask!
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Salesman giving a test drive to PIP with no EV kms available! How more ignorant can they go?
    telmo744 likes this.
  9. bisco
    52,849
    i had the same experience when i went to test drive mine. i called the salesman and asked that it be plugged in so it would be charged when i got there. when we left for the test drive and it wouldn't allow ev, he said they saw the full battery indicator and didn't think it needed to be charged.:mad:
  10. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    If I didn't know better, I'd say we had the same salesman. :giggle:
  11. bisco
    52,849
    you do, they're all the same!:cool:
    markabele likes this.
  12. Zythryn
    Zythryn Senior Member
    6,412
    4,414
    This happened to me as well in MN. It is unfortunately an easy mistake to make.
  13. Sagitar
    Sagitar Junior Member
    59
    Ampthill
    As others have indicated, you need to ask for the car to be plugged in and charged before you drive it. If the car is charged it will show the "battery only" range (in miles) that is available. If that figure is not showing, the car will not go into the PiP EV mode.
    It's sad that dealer staff do not know how to organise an effective demonstration.
    Good luck.
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    If the screen is on Hybrid System Indicator and the Ready light is on, the graph in the center won't have a split in the center if there's enough EV power in the battery. If there is a line splitting the graph, it won't be in EV mode.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y) :whistle:
  16. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Most Toyota dealers have L2 chargers right now. Plug a PiP in and sit down and have some coffee for 30 minutes. That will get you about 5 miles. Then go for an EV drive. The salesmen are all buffoons. When haven't you met a buffoon of a salesman?
  17. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I explained to my salesman that the car costs extra for a special feature, so they really ought to keep that special feature ready for people to try. He said to call ahead next time and make an appointment, and they'd have someone charge up one of the Pips.
  18. El Dobro
    El Dobro A Member
    7,106
    3,282
    Dealers should have the batteries charged up for spot sales.
  19. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I was told by, of all people, the salesman that they don't charge them up per Toyota. The manual does state that you should leave no charge in the battery when storing it for extended periods.
    I just think the salesmen don't know enough about them to be informed. Or just enough to be dangerous.
  20. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Had exactly the same experience, and exactly the same comment, when I bought mine. Doubt it was the same salesman, as I bought in the Midlands even though I live in the South (so can't really help with offering you a test drive). Maybe the knowledgeable dealers on this forum could pass back to Toyota that this is a mistake their salespeople are making on what appears to be a global scale...
    In the UK, they seem for some reason to be fitting 7kw Mennekes chargers in the dealerships, when the standard Plug-in comes with a 3 pin plug EVSE. So far as I can see from using other such chargers, it doesn't help charge any faster because the car is limited to a 2-3kw draw, which you can get off a standard UK 13 amp 240v plug anyway. I think it's part of the European standard for electric car charging. The result is that the salespeople are stumped when they try to plug it in, and have to go searching for the one Mennekes lead given to them at the time, which is probably in the boot (trunk) of another car which is currently out on the road...
