Prius Plugin's lack of spare tire.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Cherazi, Mar 23, 2013.
Poll closed Mar 30, 2013.
  1. I was informed by the sales person
    46.7%
  2. I do not care
    73.3%
Multiple votes are allowed.
  1. lensovet
    2,615
    496
    Burlington, NJ
    since i know nothing about how to read jack capacities…is it okay to use this jack even though the curb weight of the car is 3100+ lbs?
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . Your probably not applying the correct amount of finess.
    . What the dealers want is outright highway robbery, but, they may say that of thier suppliers. As I have said, I picked up a never used doughnut for $50.00. No jelly tho.".....................................Jellydoughnut. Boy you are slow.
    51,950
    slow and dim. :) unfortunately, we don't have any wrecking/junk yards around here. if i can find one, i'll either have to drive a long way or trust them to ship it.
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Well, the 1.5ton capacity jack is not adequate for lifting the whole Prius off the ground- in most cases we're only lifting the front, or the rear, or just one corner- which is way less than the jack's rated capacity of 1.5 ton.
    I have one of those Harbor Freight 1.5 ton Aluminum Racing Jacks- I use it when rotating the tires- so I do pick up the whole front end (then place it on jackstands) then I go and lift the whole rear end- that jack has no problem with those tasks.
    lensovet likes this.
  5. Mendel Leisk
    41,466
    Yeah, I researched and got plug repair kit, after discovering a finishing nail near the tread edge. And I'm in a regular Prius, LOL. My dealership, and assume other pro's would as well, deemed it to close to tread edge for patching. I plug repaired it and it's held fine, for 1000 kms or so. Knock on wood...
    But, regarding "there just isn't room for a spare...":
    They could make room. It would mean they'd have to actually do some engineering, adjust the battery size/location, and maybe shift the spare tire location. As long as sales numbers for the the Plug-In version as-is hold up, there's not that much incentive. They can trot out the statistics about the growing "trend" to not provide a spare tire, and early adopters are enthusiastic enough to go along with it.
    Another example was the Honda Fit: manual transmission version got a temporary spare. But the automatic got only a compressor and tire sealant kit, purely to lower the car's weight a bit, get them into some more fuel efficient category. In that case there was no physical reason for omitting the spare, and it was actually available as an "accessory".
    Rebound likes this.
  6. Andyprius1
    2,327
    859
    Cool CA
    One can put the doughnut flat in the trunk, and then put a thin but sturdy board on top, customizing the shape of the board to the trunk. You then have a second story in the trunk which will also make room for two small suitcases. I also glued a rug to the board so stuff wouldn't shift.
  7. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    What keeps this setup from flying around the car in an accident?
    jdonalds likes this.
  8. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Use of straps connected to the hooks that are provided for holding down the flat tire all Prius models.
    Mike
    Andyprius1 likes this.
  9. Andyprius1
    2,327
    859
    Cool CA
    . I did do that.
  10. hb06
    hb06 Member
    550
    Huntington Beach, CA
    I now put the Slime 12V Digital Tire Inflator in the rear left cubby, fits with plenty of extra room. If the tire isn't shredded, the Slime should fill it up enough to get to somewhere. Tested it and filled up an extra 1-2 lbs on Prius tires on 2 cars. Seems to work OK, and gives some peace of mind.
  11. Chris11
    Chris11 Member
    220
    Washington
    HumoUr? You must be one of them thar teenagers that spell "you" as "U" since you seem to have spares. :p
    And where is young Prius Feline lately.
  12. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Wouldn't that take all the fun out of it?
  13. Chris11
    Chris11 Member
    220
    Washington
    I just finally accepted that it's possible I could get a flat and be stuck on some road millions of miles from nowhere. So I bought a doughnut off of Ebay. $65 with freight included .. came off a Corolla . I received it and tried it on the car yesterday. Seems to fit ... at least on the driver's side rear. (I'm assuming the others have the same bolt pattern. :) )
    I'll leave it in the garage until we go on our next long trip four weeks from now.
  14. Mendel Leisk
    41,466
    ^ I'm using Corolla steel rims for snow tires on ours. I believe they're for 2007+. Part number was 42611-02471.
  15. fuzzy1
    10,455
    Maybe he just has some connections to the other English speaking peoples of the world, such as those who invented English.
    As close as you live to Canada, this ought to be a somewhat familiar spelling.
  16. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    fuzzy1,
    Thanks for coming to bisco's defence. It saved me the labour of going through a British/American dictionary to show how our spelling of words with the same meaning can differ from that of people in England, Canada, etc. While adding colour and flavour to the written word, it should not cause one to harbour a grudge against one's neighbour.:ROFLMAO:
    BTW, IIRC, priuskitty is a tomcat.:p
  17. bisco
    51,950
    i spells it like colour.:cool:
  18. Mendel Leisk
    41,466
    We use English English spelling up here, but I'm on the fence. For example, to me "centre" looks kind of weird.
  19. rogerv
    1,639
    317
    As in "We chose to sit in the centre of the theatre"? ;)
  20. bisco
    51,950
    exactly!(y)
