Prius plus engine problem
Discussion in 'Gen 3 Prius Technical Discussion' started by Adam.hu, Nov 26, 2019.
  1. Adam.hu
    Adam.hu New Member
    Budapest
    Hello Everyone!
    I have a Prius Plus and I'have been struggling with the next problem.
    The engine jerks and the igniton jingles.
    No error code ind ECU system, but we made a live data monitoring test (enroute) and the computer signed
    ignition problem in changing piston. Once piston 1 and then piston 4 then piston 2 etc. but not continously neverthless the engine jerked all on the test way.
    What we did for fixing the problem:
    - EGR valve pipe and cooling system cleaned
    - Repleaced spark plug and coil
    - Repleaced air mass sensor
    - Engine cooling water level ok
    - oil consuption 0,5liter(0,13gal)-1liter(0,26gal) / 15.000km (9500mi) so its ok
    Has enyone have idea?
    Thanks Adam!
    52,819
    blown head gasket?
    how many km on her?
