Prius - post 100,000 maintenance suggestions
Discussion in 'Gen 2 Prius Main Forum' started by pbratt, May 7, 2019.
  1. pbratt
    pbratt Junior Member
    32
    Dallas, TX
    Folks - I have always gotten great thoughts and suggestions from folks on this thread regarding the care of my 2008 Prius. I've had this car for 11 years now, and it is just over 100K miles, and I've followed the Toyota recommended Maintenance Schedule to the "t". I'm looking at a possible move (From the southwest to the midwest) this year, and want to do some preventive maintenance to enusre that my prius makes it another 100K in a different part of the US.
    One item that I need to replace is the Hybrid Battery, which has begun to fail. I'm going to get the NewPriusBattery option, and will install it this summer. I've been hearing a bit of squeaking from the rear driver's strut, and I am wondering if I should have all the struts inspected? Anything else worth doing to make sure that I get this prius to last 20 years?
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Yes have them checked
  3. Mendel Leisk
    38,653
    Has the transaxle fluid ever been changed?
    Ditto for brake fluid, though I've heard that has been problematic with second gen.
  4. pbratt
    32
    Dallas, TX
    Thanks for the advice everyone! I replace the ATF every 30,000 miles, so I should be set on that. I have not yet changed the brake fluid, so I'll put that on the list with the struts and shocks for inspection/replacement. Many thanks!
    Mendel Leisk and bisco like this.
  5. Moses Bruh
    Moses Bruh Member
    97
    29
    How did you know or notice your hybrid battery was failing?
