Prius Prime 12v dead, what to do after?
Discussion in 'Prime Main Forum (2017-2022)' started by bb4srv, Apr 27, 2020.
  1. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    So I parked my Prius Prime, and totally forgot to trickle charge the 12v. Of course, law of physics predicts the 12v will run dry and it did.
    I'm putting it back on a trickle charge, currently at 5v.
    So once it reaches 12v, what do I need to do? Do I need to re-program stuff again for the car?
  2. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    First things first, let's see if you can get it back up to ~13 volts.
    Hopefully you can...
    Question: How many days was it parked for when you discovered it was dead ?
    Rob43
  3. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    What do you mean by “trickle charge”? How do you do that in a Prius?
    iPhone ?
  4. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    Trickle charging the 12v.
  5. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    You attach a trickle charger to the 12volt battery under the hood.
  6. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Doesn’t the EVSE charge the 12V as well when plugged in?
    I drive about once a week since the lockdown for essential errands like groceries and pharmacy needs, and I haven’t had problems with my 12V. I try to keep my EV pack charged.
    iPhone ?
  7. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    The traction battery doesn't charge the 12v when parked.
    Unfortunately, I parked the PRIME for about 2 months.
  8. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    This happened to me. I remember I lost my radio presets. I did not loose the clock or charging schedule. I don’t think I let the 12volt go as low as you did. There was enough juice left to display the low battery warning on the MID etc. but not enough to start the car.
    The consensus here is it maintains the 12volt’s level of charge but not much more and only does that while the traction battery is actually being charged. After the traction battery charge completes the 12volt is on its own again.
    #8 schja01, Apr 27, 2020
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    That is too long. As long as you can bring the 12v battery back to life, it should be just re-initializing the car. I haven't done it myself, but similar to what you had to do the first time you bought the car. Following is the re-initialization steps needed after 12v battery reconnection. It is from the 2020 manual, so the page referring may be different for your model's manual.
    If your 12v battery is healthy, once a week drive for ~1hour is enough to keep the 12v battery charged. As said above, the plug-in does maintain 12v while actively charging the traction battery, but will not bring the dead battery back to life.
    Tideland Prius, benagi and bb4srv like this.
  10. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    Perfect thank you. Seems straight forward and found the appropriate pages for MY2018. Will report back if things are outside of the ordinary, fingers crossed.
  11. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    5V??? For a 12V battery???
    That battery might never recover. If you can get it to take a charge, have it load tested before next winter. Depending on where you live, it might let you down some cold winter night.
    Ed
  12. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    Good news. Trickle charged overnight and was able to revive the battery back to 14v. The Prime is back to life. Drove it around the block and the sensor re-calibrated on its own. Haven't tested the auto park or other sonar sensors yet, but I don't expect to be any problems. No error messages except for "low 12v" upon first start but went away after put in Drive - I suspect is message from a state before the battery died.
    So yes, if you park your Prime for around 2 months, it will deplete the 12v even if you plug in the traction battery charger. The Level 2 does NOT charge the 12v.
    Rob43 and Salamander_King like this.
  13. Mendel Leisk
    42,355
    That 14 volts is most certainly read while the car was in ready mode, maybe the dash display? You're not seeing the true voltage of the battery under those conditions; not even a brand-new fully charges battery would read 14 volts.
    Let it sit overnight, with the hood popped if practical (you have secure parking). If not, just pop it in the morning, but do go in through the passenger door, wake the car up as little as possible. Measure the voltage with a digital multi meter, see what you get.
    Tideland Prius likes this.
  14. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    The V reading was NOT in Ready Mode. I left the hood popped overnight and this morning opened the hood to take a reading before doing anything to the car. But it was still on the batter tenderer.
    yes leaving it for 2-3 overnights and take the reading would see the true condition of the battery. At least I’m not stuck at home now!
    Mendel Leisk and benagi like this.
  15. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    What’s interesting about that is that you can’t charge the traction battery if the 12V is dead because the charging system itself can’t start. I find that laughable. Why can’t it start the computers from the AC charger? What this means is that you have to jumpstart the Prime if you want to plug-in to charge the traction battery. LOL!
    iPhone ?
  16. Salamander_King
    11,024
    8,980
    New England
    Yeah, but even if it can charge the traction battery with a dead 12v, what good would it do if you can't start the car without jump starting anyway.
    I have had numerous dead battery incidents with all of my previous cars, but never had it happen on my PRIME yet. Of course, most of the dead battery incidents happened in middle of winter on a car with an old battery, but still, I've had better luck with PRIME to date. That being said, reading on many cases of dead 12v battery in PRIME, I have purchased Li battery jump starter just in case, and now with COVID-19 lock down, I installed BT Battery Monitor on my PRIME, so I know exactly what SOC my 12v battery is at 24/7. I am prepared.
  17. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    It's been stated many times in this forum that while the traction battery is charging from the AC, the 12V gets some recovery juice too until the traction battery finishes charging. Is that assessment incorrect? If you have a borderline dead battery, which is the most common case, completing a traction battery charge should be sufficient to give the 12V some juice to start the vehicle after you finish charging the traction battery.
  18. Salamander_King
    11,024
    8,980
    New England
    Since I have not had my 12v battery depleted low enough to benefit from L1 EVSE when I plug in my car, I don't have good data. My car is almost always driven right before or at most within 6 hours prior to charge start time, the 12v battery is already replenished from the onboard charging system just from driving. From my 12v SOC observation after having PRIME sit for a week, the onboard charge system works much better when the car is driven (or just in READY mode) than when the car is off but plugged in. I am not sure how much of juice it would provide to a dead (or near-dead) battery just from plugging in.
    Humm, that's an interesting question. My car is now parked and sitting at 40% SOC traction battery for the past 3 days. The 12v has gone down to 12.4v 65%. If I just plug-in for a few hours before driving next time, would it replenish 12v SOC up to 100%? I will try that and report here.
  19. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    I had almost the exact scenario a couple of weeks ago and I was very disappointed in the results as the 12 volt didn’t come up to 100%. Someone on here (can’t remember now) told me the EVSE basically only maintains the charge in the 12 volt. But good luck anyway!
  20. Salamander_King
    11,024
    8,980
    New England
    Yeah, that is my understanding. EVSE charge only maintains 12v SOC level but does not replenish it. So, if it is near dead, it will be near dead at the end of charge. Or as mentioned by @mveras1972, if the 12v battery is dead, even if EVSE can be used to charge the traction battery, it would not help bringing the 12v back to operational SOC.
