Prius Prime 2017 - Can't find a guide to replace driver window
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by j_mouthhole, Sep 21, 2025 at 8:54 PM.
  1. j_mouthhole
    j_mouthhole New Member
    Yesterday
    US
    Prius Prime Advanced 2017. Broken front left window. I enjoy doing my own repairs when able and thought I could do this on my own. Glass should be here tomorrow. Thought I'd get a head start and remove the broken window. Took off the door panel and found that access to the window was different compared to any other video I had found. No plastic film to remove, just cords and metal. Anyone know of a guide to do this? I worry I bit off more than I could chew.
    Thanks in advance.
  2. BiomedO1
    BiomedO1 Senior Member
    3,114
    1,652
    SacTown, Ca
    Take it to a glass shop if you can't figure it out.
    Remove the front and rear weather stripping to give yourself some extra space and DO NOT put excessive pressure on the glass to fit it in. Slide the weather stripping back in, once the glass is in place.
    Good Luck....
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,195
    781
    Monument, Colorado USA
    Yep I've had great work done by SafeLite to repair windshields and side windows....give them a call, hopefully only charge you half an hour of labor to pop it in...they are wicked fast.
