Prius Prime 2017 - Comparing Electric vs Gas cost
Discussion in 'Prime Main Forum (2017-2022)' started by Komsan, Apr 25, 2018.
  1. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Electric
    electric bill total= $100.34
    Total kWh used = 706.47
    cents per 1 kWh
    car full charge = 27.7 miles
    car battery uses = 6.3kWh
    89 cents per charge
    0.03 cents per mile
    ________________________________
    Gasoline
    $3.10 per gallon
    car gets about 50-64 mpg with no charge
    0.06 - 0.04 cents per mile on pure gas
    BUUUUT I can only charge at home since Pittsburgh doesn't really do the whole plug in scene and work doesn't allow it. Also I drive 38 miles round-trip between work and home.
  2. Oniki
    Oniki Active Member
    652
    500
    Colorado
    I'm pretty sure he was talking about usable, although I figure it to be ~ 5.5 kWh
    Tideland Prius likes this.
  3. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Don't include fixed charges
  4. SaraBBrown94
    234
    263
    Pittsburgh PA
    Not including the flat rate it would be 2.7 cents per mile. Rounding up that's still pretty much 3 cents.
    HPrimeAdvanced and Oniki like this.
  5. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    $/mile really does make comparisons much simpler.
    Gas costs are either very simple, or extremely complicated. Pump price is easy. Costs to society, your kids society, and global politics makes it extremely complicated.
    Electricity is fairly straight forward but can range from under a penny/kWh up to over 40cents/kWh (or even more at some of the worst pay chargers).
    For us, our cost per kWh is $0.05/kWh which translates into 1.25-1.5 cents per mile driven.
    This cost will remain the same for the next 35 years or so.
    Granted, it also required us to pay a fair amount up front.
    HPrimeAdvanced likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Sure would! On my PiP, I usually pay about 3 cents per mile for gas and electricity combined. But I never pay to charge except at home.
    Oniki likes this.
  7. Oniki
    Oniki Active Member
    652
    500
    Colorado
    The stuff is cheap when you can ignore a 10% difference.
    Ask the ICErs how they feel about a 10% price jump
  8. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Flipped numbers ?
  9. Zythryn
    6,412
    4,415
    I don't believe so. 5cents/kWh divided by 4miles/kWh = 1.25 cents/mile.
    I noted 1.25-1.5 cents because the model 3 is new and I am not sure if I will get 4 miles/kWh or slightly less.
    Oniki likes this.
  10. Oniki
    Oniki Active Member
    652
    500
    Colorado
    You are right, the combined petrol + electricity should be calculated.
    My work commute of 90 miles takes 0.9 gallons and one full charge from home:
    0.9*270 + 2.77*6.3 = 260 cents per 90 miles = 2.9 cents a mile
    HPrimeAdvanced and jerrymildred like this.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I admit that I pine for a Prime sometimes. It would be even better for my typical drives than the PiP. Still, I just filled up today for the first time this month thanks to fewer trips beyond EV range. Went 1134 miles on 8.002 gallons and 85 kWh that I paid 11.2 cents per kWh for. Plus the free electricity I get at work and church. That's a new record by almost 200 miles, btw. Cost per mile was 2.68 cents. Also a record, which was remarkable because it was also the most I've ever spent on gas for this car. With a Prime, I might only fill up twice a year aside from big trips.
  12. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    $ per km/mile doesn’t make a good comparison bc gas prices fluctuates. So $/km today will be different tmr.
    I just got a chargepoint record of a full charge at approx 6kw. I will adjust the table based on this.
  13. Oniki
    Oniki Active Member
    652
    500
    Colorado
    True, but I'm not sure why you mention it. Any cost comparison between electricity and petrol will be affected by changing prices for the energy.
    #33 Oniki, Apr 28, 2018
    HPrimeAdvanced and Zythryn like this.
  14. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    Yes, that's why I have a reference comparison table between electricity rates and the equivalent fuel cost. This way if you're in a high electricity rate region, you can compare with your local gas prices and know what type of savings or costs when running in EV.
    Also I just checked my model. Yes, the original table is correct at 6kw for the EV range about 40 kms for rated disance. The 17 kw is to convert it to 100kms so I can properly compare with gas price metrics at L/100kms.
    Net Electricity is $ per kwh
    The 3 columns to the right is equivalency in gas prices in $ per Litre
    The variables are:
    6 kw for 40 kms rated; 35 kms for low eff; 43 kms for high eff
    4.5 L/100km rated; 5.5L for low eff; 4.2L for high eff
    10% charging efficiency loss built-in
    Net Elec Rate; Rated Eff; Low Eff; High Eff;
    $ 0.129 $ 0.50 $ 0.47 $ 0.50
    $ 0.150 $ 0.58 $ 0.55 $ 0.58
    $ 0.200 $ 0.78 $ 0.73 $ 0.78
    $ 0.250 $ 0.97 $ 0.91 $ 0.97
    $ 0.300 $ 1.17 $ 1.09 $ 1.16
    $ 0.350 $ 1.36 $ 1.27 $ 1.36
    $ 0.400 $ 1.56 $ 1.45 $ 1.55
    $ 0.450 $ 1.75 $ 1.64 $ 1.74
    $ 0.500 $ 1.94 $ 1.82 $ 1.94
    $ 0.550 $ 2.14 $ 2.00 $ 2.13
    $ 0.600 $ 2.33 $ 2.18 $ 2.33
    $ 0.650 $ 2.53 $ 2.36 $ 2.52
    $ 0.700 $ 2.72 $ 2.55 $ 2.71
    $ 0.750 $ 2.92 $ 2.73 $ 2.91
    Since electricity rate doesn't fluctuate as much, then one can just glance at the gas prices columns (the 2-4 columns) and reference to the equivalent electricity charge.
    Or, if you're at public chargers that charges by kw, then you can also compare using the equivalent gas prices. For instance, there's a public charger here that charges $0.33/kwh.........that means to use that charger the equivalent gas price (for Prius Prime only) is around $1.35/L of gas. Current gas prices is $1.55/L, so the savings is merely $0.20 per litre by using this public charger.
    #34 bb4srv, Apr 28, 2018
  15. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Do you mean 17 kWh per 100 Km ?
    That would be more consumption than EPA, which measured 25 miles per 6.2 kwh charge *
    Since 25 miles is ~ 40 Km, 100 Km is 6.2*2.5 = 15.5 kWh
    Actually, EPA measured 133 MPGe in combined driving from the meter which is
    133 miles per 33.7 kWh,
    133/33.7 = 3.94658 miles per kWh
    3.946587537 miles = 6.365463769 Km
    So 100 Km uses 100/6.365463769 = 15.71 kWh
    That is the arithmetic. Which I suppose is of some interest but choosing EV has these advantages:
    • Much nicer driving experience
    • Much less pollution in areas that rely on renewables or natural gas for electricity
    • Keeps money in the domestic economy
    • Keeps money out of the hands of oil rich despotic regimes
    These are high value advantages. They should be considered. Certainly at price parity or close to it, EV miles are a no brainer.
  16. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    that's the built in efficiency loss. The table only models pricing based on the distance, not the actual battery capacity to distance. So to charge 15kw you need to draw approx 17kw from the grid.
    (100kms/40kms)*6.2kw*1.1 = 17kw for 100 kms, with efficiency loss
  17. Oniki
    Oniki Active Member
    652
    500
    Colorado
    NOT KW. The correct unit here is kWh.
    Watt is a unit of power
    watt*hour is a unit of energy
    6.2 kWh per 25 miles already has the charging losses included for 240v EVSE charging.
    #37 Oniki, Apr 28, 2018
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Is L2 charging more efficient than L1 charge? I have anywhere from 6.4kWh to 6.8kWh of charge reading from 0 mile EV range to full charge on L1 at wall using KillAWatt meter. After measuring a couple of months, I decided to use 6.7kWh average as my daily full charge. 6.2kWh seems to be low to me. Just curious.
  19. Oniki
    Oniki Active Member
    652
    500
    Colorado
    yup
  20. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    How are you guys calculating your cost of electricity?
    I just got my utility bill for the past month and it's $58 for 260 kWH of electricity. That's with all the taxes and crap added in.
    That works out to $0.22 / kWH.
    If it takes 6.3 kWH to charge my batteries, that's $1.40 / charge (L1, not L2)
    I typically get about 28 miles per charge. If we double that, it's 56 miles for $2.80.
    My ICE mileage is right about that as well (~56 MPG), and gas right now is hovering around $2.80 / gal in my area.
    So it looks like I'm breaking even as far as cost of EV vs. gas.
    If gas prices continue to rise, I'll be saving money with my EV.
    How in the world are there people getting electricity at 4 cents / kWH ?
    Or are we folks here in AZ just getting royally screwed by APS and SRP?
    breakfast and HPrimeAdvanced like this.
