Prius Prime 2020 still has Carplay software issues
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Eric Nothman, Apr 25, 2021.
  1. Eric Nothman
    Eric Nothman Prius owner
    101
    Washington DC area
    2020 Prius Prime
    I have a 2020 Prius Prime XLE and it had software reboot issues where it frequently rebooted or needed to be rebooted. The dealer updated it November 2020 to Navigation software level R20A2300. After the update there are still several important issues that “feel like” software bugs and very much need to be corrected.
    Does anyone else experience these Prius Prime 2020 electronics issues when using Carplay (see below)?
    When using Carplay:
    1. Audio mode switching frequently does not work. On the Head Unit Console one frequently cannot switch Audio mode (source) from Carplay (default source is Carplay) to FM radio or any other audio source. It may be related to which Audio input is the default as it fails mostly when Carplay is connected and later another Audio input is selected. In other words, switching away from Carplay to another audio mode while the iPhone is plugged into the USB is frequently not possible. Addressed by detaching iPhone from USB. Note: this solution disconnects Carplay. Also, if “Reorder” is displayed below audio sources, then selecting “Reorder” clears this condition.
    2. At times FM volume cannot be turned off (audio off button stops working on the Head Unit Console). Addressed by turning down volume to minimum or detaching iPhone from USB and rebooting Prime Head Unit Console.
    3. At times Siri stops working. Addressed by detaching and rebooting iPhone (model 6S running iPhone software 14.4.2) and rebooting Prime Head Unit Console.
    4. Occasional screen lock up (touch screen on Head Unit Console becomes unresponsive) requiring a reboot of the Head Unit Console to clear.
    The first two issues listed above are frequent and most prevalent causing a lot of frustration.
    Please note: I am using an Apple USB cable to attach an iPhone 6S (software level 14.4.2) to the USB connector in the car.
    I suspect this is software related caused by the DENSO implementation of Carplay. That there might be some software bugs is understandable as this is their first year of implementation on the Prius. It is possible DENSO might benefit by input from real world experience of their Carplay implementation.
    Anyone else experiencing these issues?
  2. Eric Nothman
    101
    Washington DC area
    2020 Prius Prime
    Here is another issue that was experienced (same Prius 2020 Prime XLE as described in original post) every time using the Apple maps App (from Apple):
    Issue: Apple Maps App not working
    Audio would not work after the “navigation lady” would speak a single time.
    Work around is to “Mute” and then “Unmute” within the Apple Maps Navigation App. However, this is needed repeatedly because the “Navigation lady” would speak only one time and then go silent.
    Because this occurs every time the “Navigation lady” speaks once even the work around (i.e. Mute and then unmute) is not sufficient. In short, this issue renders the Apple Maps Navigation App inoperable as it effectively repeatedly renders the Navigation Lady as silent.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,327
    947
    Monument, Colorado USA
    We gave our 2017 Prius 2 to our oldest daughter a few months ago and she's telling me the infotainment system keeps rebootiing on her for no reason.
    I checked on the Toyota Update website to see if there's a patch to upgrade it (you use a thumb drive) but there is not.
    So when I get the car I'll go in and remove all the bluetooth connected phones in there and reconnect hers. This seemed to help fix my Tundra system, years ago, when it would randomly just reboot itself while driving. (Very annoying if you're on a phone call.)
    vvillovv likes this.
  4. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    It could be the earliest, 1st car play implementation in the Gen 4 refresh of 2020.
    Or it could be related to the 6S.
    Keeping in mind that 2017 - 2019 Gen 4 used Entune which didn't support either car play or android auto.
    Both Gen 4 and 5 are showing issues with the Toyota App, Car Play and Android.
    since you are showing 6s iOS version numbers above you already have a head start on digging up info
    about car play for your phones possible connection issue.
    See how much you can find out about what others using your phone have experienced.
    Yeah, I hear you in advance, that's really not to helpful, thanks ! anyway, best luck getting your head unit issues squared away !
  5. BiomedO1
    BiomedO1 Senior Member
    4,482
    2,355
    Left Coast
