Prius Prime A/C and heater not working
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by BigPete, Aug 29, 2020.
  1. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    My Prius is 2years old and needed the heater on as was a bit cold this evening here in the U.K., but it would only blow cold air.
    when it was hot a few days ago I wanted the AC on but was only blowing hot air.
    Any idea what the issue could be, a fuse?
  2. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    It could be a fuse, I suppose. Only takes a couple minutes to find out. But unless you drive a lot more than most people, a two year old car should still be under warranty.
    49,691
    manual or auto?
    what temp did you set it to?
    what was the outside temp?
  4. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    manual, 24oC, was 12oC out
  5. bisco
    49,691
    what model and model year?
    how many miles on her?
  6. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    2018 Prius Plug-In, or Prime as called in USA
  7. bisco
    49,691
    thanks. can't think of a fuse that controls anything except the blwer motor. sounds like your ecu is confused.
    try disconnecting the 12v negative for a minute to reset the computers
  8. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Ok sounds like a plan I’ll pop out and do now.
    thanks.
  9. hill
    8,250
    does the plug-in loose radio setting & such when you dump 12v?
  10. bisco
    49,691
    sometimes, not sure why
  11. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    No it didn’t
  12. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Still doesn’t heat in Auto or manual or the AC, blower works but no hot or cold, just seems to be whatever temp outside is blown in.
    #12 BigPete, Aug 30, 2020
  13. jerrymildred
    11,518
    14,124
    Tampa, FL
    You didn't answer @bisco's 2nd question. How many miles on it? It's very likely under warranty at that age.
  14. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    30,000, yeah I’ll contact the dealer
    bisco, Raytheeagle and jerrymildred like this.
  15. jerrymildred
    11,518
    14,124
    Tampa, FL
    Absolutely. The dealer should fix that for free if the UK warranty is anything like here. In fact, if you try fixing it, that might cause some issues with warranty coverage.
  16. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    It’s 5year, 100,000mile
    jerrymildred and bisco like this.
