Prius Prime Acceleration
Discussion in 'Prime Main Forum (2017-2022)' started by Prashanta, Oct 21, 2016.
  1. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    The Prius acceleration up to 40 mph is actually really good. It just tapers off as you approach 60 mph.
    If the 2nd motor only comes in in EV mode, that leaves me wondering what the 0-60 numbers would be in EV Auto mode. Suppose two motors are active to say 40 mph then a single motor plus engine for speeds beyond that. That could potentially drop the 0-60 time below 10 seconds.
    Merging onto highways would be easier in hybrid cars that have 0-60 times around 11 seconds than in pure ICE cars with equivalent numbers because they achieve almost-highway speeds more quickly.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I merge onto the highway now with my Prius PHV expecting the engine to start. No big deal, the EV-BOOST performance is nice and the remaining electricity lasts longer. Sometimes, it doesn't start though.
    Discovering I've used up most of my battery from cruising along at 55 mph in EV can be annoying... but it does confirm not as much power is needed as some try to lead is to believe.
    And of course, with the bigger pack, there's more EV range available anyway.
  3. Tideland Prius
    16,683
    EV Auto should yield a similar result as in HV mode. The question is whether it does dual motor for the first bit (Say 0-20 or 0-30mph) then declutch and have the engine assist above that. Now that would be a smart EV Auto mode!
    I agree. Merging onto the QEW with a smart fortwo, I never reach traffic flow speeds (110km/h). I'm usually at 80km/h by the end of the onramp with my foot to the floor. I've tried both manual and automatic (with the foot pass the "click" on the accelerator pedal in automatic mode). I believe the official 0-60 for a 451 fortwo is 11.5 seconds.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    EV Auto is all about efficiency, not acceleration. So naturally it will start dual motors EV and revert to HV at a certain speed.
    I will take the chance here to speculate that even in EV mode, if you are flooring the pedal in the production model it will start the engine (i.e. out of dual motor drive) at a certain speed (my guess - around 40-45 mph) to give you the maximum the car can give, and go back to motors drive when releasing.
    IMO Toyota did not state 0-60 time in EV for a reason.
    Just my speculation...
  5. bisco
    52,883
    i just wasted 15 minutes of my life watching the first video, didn't see anything out of the ordinary. are you going to make me watch the second?(n)
    just drove back from new york city to ma, it doesn't get much worse than that.:eek:
  6. El Dobro
    El Dobro A Member
    7,106
    3,282
    In for a penny, in for a pound. :D
    Mendel Leisk and bisco like this.
  7. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    #47 JamesBurke, Oct 24, 2016
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    That calculator doesn't include the option of either a CVT or an electric drive system. It's for conventional cars.
  9. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    And why would you ?
    Prius has more than enough power for US highways .
    I never have any problems merging on to german Autobahn,and believe me they drive a little faster on German highways than on US highways...
  10. Trollbait
    12,832
    What is natural about using dual motors for efficiency? It helps the Tesla's, but their motors are close in power ratings. MG1 might be too small for that benefit. The battery is much smaller than the Tesla's, and dual motors under acceleration will drain it faster than using the ICE. The dual motors operation is to allow harder acceleration and higher top EV speed than in PiP. When driving for efficiency, MG1 for traction isn't needed. Dual motors outside of EV mode is still an unknown.
    Has the operation specs for EV Auto been released yet? The top speed of EV operation and such? I think all we can say is that EV Auto is a blended mode that works like the PiP's EV mode. It should be the best overall efficiency.
  11. Lee Jay
    5,850
    4,036
    PM motors generally have very low losses from simple running. Most of the losses tend to be i^2*R losses in the windings.
    This means losses are lower when you run them at lower power. Thus, using both motors at lower power is likely more efficient than using one at higher power.
    KrPtNk likes this.
  12. Trollbait
    12,832
    But MG1 is a smaller motor. Will running it at low power reduce the energy consumption of MG2 during for mild to medium acceleration and cruising than in comparison to just leaving it off?
    Then dual motor doesn't seem to be used in Hybrid mode. With MG1 needed for eCVT operation, could accelerating with dual motors, and then switching to using ICE create a gear shift sensation as MG1 goes from traction duty to its hybrid one?
  13. Lee Jay
    5,850
    4,036
    Probably.
    Probably, because of the spool up time for the ice. Getting the ICE started is MG1's job, and then you'd have to wait for it to start and spin up before you could use MG1 to divert the torque from the ICE to the wheels. This is a greater than 1 second operation so it would create a long delay in an emergency acceleration situation.
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The specs were not released so we don't know. Maybe dual operation is only at EV mode. On the other hand, in dual motors the engine is isolated but not the planets' carrier, so, engaging the clutch when running may be more than enough to spin the engine for starting it.
    #54 giora, Oct 24, 2016
  15. Trollbait
    12,832
    It's a one way clutch; not one in which the ICE actually decouples from the PSD. It allows the ICE to spin only one direction. This works for the dual motor use, because MG1 has to spin in reverse of it's normal hybrid duty to provide force for traction at the wheels.
  16. civicdriver06
    797
    324
    Germany
    I don't really care if it takes 10 or 11 sec. to get to 60,but it would really be nice if it had some kind of boost,even just for a few seconds,to speed up overtaking times .
    With each new generation Toyota promises better performance,but 0-60 was never really improved since gen. 2,but with that bigger battery the prime should at least be able to create better 40-60 and 50-75 performance than the liftback.
  17. Lee Jay
    5,850
    4,036
    Why? They have the same MG2 and the same ICE. The bigger battery enables it to maintain full power for longer, not get more power for a short burst since it's motor or power electronics limited.
  18. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Ahh, the wonderful feeling of accelerating hard into a fixed object. ;)
  19. civicdriver06
    797
    324
    Germany
    I was hoping for some kind of software trick .
    Well then let's hope it's not even slower due to the added weight ! :eek:
  20. Prashanta
    292
    242
    Technology
    It is slower due to the added weight. Gen 4 Prius Eco actually does 0-60 in 9.6 seconds (lightest of the bunch). Only thing we can hope for is that EV Auto has some magic in store for us.
