Prius Prime amperage needs
Discussion in 'Prime Plug-in Charging' started by Rafael Rivera Ramos, Jan 2, 2022.
  1. Rafael Rivera Ramos
    Rafael Rivera Ramos New Member
    PR
    2022 Prius Prime
    Hello, I recently ordered an enphase solar system for my home, it will have a 6 kw solar production and solar 13.5 kw of battery storage. I am planning to acquire a Prius Prime, and to know if the car charger can be inside the solar system or if it needs extra batteries, the installers are asking for the amperage that the Prius Prime uses or draws to charge, either in 110-220 configurations. Thank you,
    Rafael
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    Max of 12A if you use the unit provided with the vehicle (and you can select an 8A draw from the vehicle). 15A if you use a level 2 charger.
    jerrymildred likes this.
  3. Rafael Rivera Ramos
    PR
    2022 Prius Prime
  4. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    15 amp at 220v for the level 2 charger. That's 3.3 kilowatts. That will charge the battery from 0% to 100% in just over 2 hours.
    If it's pulling 3.3 kw for 2.25 hours, that equates to about 7.4 kwh, or 1/2 of your battery capacity. That should not be a big deal, since as long as the sun is shining the solar panels will provide twice the power needed to charge the car.
    It should work well within your solar setup.
  5. Rafael Rivera Ramos
    PR
    2022 Prius Prime
