Prius Prime as 2nd car?
Discussion in 'Prime Main Forum (2017-2022)' started by docboy, Mar 20, 2018.
  1. docboy
    docboy Junior Member
    58
    Washington
    Seems we are not alone :) Like the Tundra, the LX570 is great in the snow. Uphill and downhill, foot of snow, and heavy rain are no problems during the winter months. It's also a Toyota at heart, and aside from some maintenance stuff (water pump, front/rear/transfer case/power steering fluids) it's reliable and rock steady. Only real negatives I didn't think of when I bought it 1.5 years ago is the 11mpg and the somewhat spendy maintenance stuff that occurs every 30k miles....
    I recall passing by many Prius', FWD cars, and other smaller SUVs stuck on the street during snow days here... so (no offense to the Primer owners here) I unfortunately don't see the Prime as being an inclement weather car which I need during the winter months here as my area is quite hilly.
    I'm drawn to the Prime due to the possibility of using no gas for my commute. My wife has a NX300H, and I like driving her car whenever I can. I try to hyper mill it and maximize mpg :) I also suspect the Prime is very low maintenance. Regen braking would mean brake pads would literally last probably 150k+ miles easily, with just oil change, tires, wiper fluids/blade, cabin/air filter as maintenance stuff?
    Mark57, Dudley1030 and pilotgrrl like this.
    52,807
    correct.
    Dudley1030 likes this.
  3. Trollbait
    12,817
    With a BEV, there would be even less maintenance. If I were going to be keeping a traditional car or hybrid as back up, I would skip the PHEV and go for the BEV for the daily driver. Why bother dealing with two engines when you don't need too?
  4. docboy
    58
    Washington
    True... however I looked at one BEV, Tesla Model S CPO. In checking out online forums and Consumer Reports fwiw, Tesla is far from maintenance free. Reports of multiple visits to the dealership or having a "ranger" come for repairs are common; a couple of my friends have a CPO Model S, and they reported multiple repair visits. I just don't have the patience or the time for repair visits.
    I may take a look at a used Leaf as well (~$9k) but I suspect depreciation on the Leaf is going to be killer, esp with the new higher range Leafs coming; the 1st gen Leaf may very well be worthless in a few years. I'll also see how things are with the Bolt.
    If Toyota made an AWD BEV with 200 mile range, I would easily trade in my LX570 for one.
  5. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Yep, as an example my Fiat 500e basically only listed inspections, tire rotations and cabin air filter replacement prior to 10 years / 10,000 miles.
    I’m not really complaining about the scheduled maintenance in the Prime because it is currently my only car. It does seem a bit wasteful when I take it into the service department early next month with an estimated 700 miles out of 2700 miles in hybrid mode.
  6. docboy
    58
    Washington
    Did you trade in the Fiat for the Prime?
    I wonder what would happen if I trade in my SUV for the Prime. That would leave me without an AWD vehicle and my precious cargo space.
  7. CraigM
    208
    208
    Portland, Oregon
    The Fiat 500e was a lease. Turned it in just after getting the Prime.
    Agree the cargo space in the Prime is a little tight because of the slope of the rear window.
  8. Nancy S
    Nancy S Member
    53
    60
    Chandler, AZ
    Yikes where to start? In our driveway is a Prime,Model 3 and a Leaf. I vote thumbs down on older Leafs. Range on ours on a good day is 85. Commute is 20 miles each way. Charge time to recoup those 40 miles is 12 hrs on 110v. It takes a lot of thought before you jump in and go run errands, kids, shopping etc. Gotta plan on making it there and back with a cushion for side stops and traffic and recharging for the next day. Range anxiety isn’t a problem with either the Tesla or the Prime.
    Quality of the three vehicles is comparable. None of these vehicles have been trouble free. We have had the Prime for a year. It has had the AC compressor replaced, the driver and the passenger seats replaced. The 2015 Leaf has had recalls for airbag problems and ongoing front suspension issues. The Tesla’s charging port door has a mind of its own and is to be repaired soon and the trunk lid needs adjusting, otherwise the fit and finish on the Tesla are fine. I expected issues with both the Prime and Tesla as they are first year models.
    Funny you should mention insurance....the Prime is $50 more per year than both the Tesla or the Leaf.
  9. Trollbait
    12,817
    Tesla should probably be compared to BMW and Mercedes in terms of issues.
    Used, most of the depreciation already happened, and with the various incentives out there for new, all plug ins will have steep depreciation for the near future without even accounting for technical improvements.
    Your location opens up other options for used, shorter range BEVs. The 500e was mentioned already, but there is also the Spark EV, Soul BEV, Focus EV, smart ED, iMiEV, plus some I likely missed. The smart is the only one I'd be wary off, and that is because it is the only one in the US that had a battery leasing option, so you'll have to ask if any you look at are under that program.
  10. docboy
    58
    Washington
    Any here own the Bolt EV by chance?
  11. bwilson4web
    16,520
    docboy likes this.
  12. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    Adding a prime to the Lexus IS only a 30% increase. The advance has all the same features as the Lexus except the bottle cooler.
    Also you well look more conservative at work driving a prime.
  13. docboy
    58
    Washington
    Can you elaborate "adding a prime to the Lexus IS only a 30% increase?" Do you have a IS?
  14. fneil
    fneil Member
    71
    52
    Carrboro, NC
    What were the symptoms of the AC compressor failing?
    And were the seat problems fabric or mechanical?
    Inquiring minds want to know!
  15. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    A PHEV would be great for you. I have a very similar situation and use an OutBack for family hauling, long trips etc. while I only use about 2-3 tanks per year in my plug-in Energi. The Prime's hatch design will also work great for the costco trips. Do it. (y)
  16. docboy
    58
    Washington
    2-3 tanks per year is awesome, the Energi is your daily?
    I had to look up the CMax Energi and it seems comparable to the Prime. How would you compare the Energi vs the VOLT you sold?
    #36 docboy, Mar 25, 2018
  17. fotomoto
    5,639
    3,815
    So. Texas
    Yes, it's my daily driver. The energi has much more room and at the time of purchase more features. The volt has, of course, way more range and stronger EV performance so I think of it as more of a sporty GT 2+2 type car. Great for a single commuter but cramped because it's a smaller platform than the Energi and the larger battery intrudes on space. I traded it for the Energi specifically because of room.
    The Prime and Energi are very similar in EV performance and range but the newer gen. Prime has better space/management and fuel economy but only 4 seats. Give and take. The good news is we (you) now have many more choices today! (y)
  18. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Are you asking if an additional car purchase will save you money on 70 miles a week of commuting ?
    This should not be toooo hard:
    70*52 = 3640 miles a year
    = 3640/12 = 300 gallons a year
    = ~ $800 a year for fuel.
    I would be embarrassed to consume so much fuel a year, but the cost is trivial compared to another car.
    I´m curious,
    How much did you spend to buy your land barge ?
    #38 Oniki, Mar 25, 2018
  19. Nancy S
    Nancy S Member
    53
    60
    Chandler, AZ
    Sorry, been offline for some time...(enjoying the M3)
    The AC issue was an overly robust noise when starting the car. Kind of like winding up sound under the hood..I’m not sure that has solved the issue but have not revisited it lately.
    The driver seat recline was either off track or stripped. It was replaced.
    The passenger seat side bolster was broken and replaced.
    Other than those issues, it a fabulous vehicle especially fun to drive on electric. It’s getting a full front self healing film protector next week.
  20. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Here is the spreadsheet you are looking for. It was posted by someone here on one of Prime thread, but I can't remember where I got it from. It is located on shared Google Drive. I made copy of the link so I can reference to it time to time. If anyone knows where I found this spreadsheet, please let me know so I can give proper credit to the person who created it.
    docboy likes this.
