Prius Prime brakes.
Discussion in 'Prime Main Forum (2017-2022)' started by ed4271, Feb 5, 2019.
  1. ed4271
    ed4271 Member
    107
    64
    US
    I only used to be when I'm an EV mode. And is amazing it's like double the amount of regenerative braking that I get when I just normally just pressing the brake slowly and lessen pressing hard.
  2. Tideland Prius
    16,683
    That was updated with Gen 3. Gen 3 allowed wheel spin.
    Not much experience with the Prime yet but it does seem more sophisticated (and yes it does have an OFF switch). VSC seems to react faster (around corners) and so does TRAC (off the line) in the snow.
  3. RonMc5
    RonMc5 Member
    89
    73
    Santee
    The mechanical brakes _are_ used when almost stopped* gradually blending with the regen braking, irrespective of braking pedal pressure.
    * Possibly fuzzy memory says under 9 MPH.
    As long as you are driving your car, the friction brakes will be used at least some of the time. Certainly enough to keep the rust under control.
  4. Trollbait
    12,832
    Except for panic stops. Push the pedal hard enough, and it goes right to friction.
  5. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    The service writers in the dealership are paid only on commission. If they don't write up work, they don't get paid. If they don't write up enough work, they get fired. It's a terrible system. Knowing this, it's shields up! when in every service department.
    Brake parts are mainly cast iron. Regions that use a great amount of salt on the winter roads may result in serious brake corrosion. The thin paint or plating on the parts is some help but not perfect. Some lightly used rotors have rusted through from the interior cooling channels from the salt. Brake inspections are important, but they need to be honest. If the service writer can't show why the car needs a $1000 brake job, can't actually defend his report, he's a crook.
    When they do inspections require that they list the actual measurements, not just some percentage. Does anyone really think the mechanic measures the pad then divides that by the thickness of a new pad to get the percentage? Or just writes down a quick estimate skewed to give him or his buddies more paid-by-the-job work?
    When you bring in a problem, require that the service writer write the problem on the repair order. No fix, no pay. You will pay for the problem to be fixed, not for the service writer's guess of a job that might not fix your problem.
    Probably not off a Prime....
    #25 PT Guy, Mar 19, 2020
