Prius Prime--Expected Longevity
Discussion in 'Prime Main Forum (2017-2022)' started by ClemsonSteve, Apr 18, 2018.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Probably was not a regular scheduled maintenance item for Honda either. Spark plugs/valve adjustment is just like water pump/timing belt for my other Toyota. They like to tack on additional items.:(
  2. GustoGuy
    GustoGuy Member
    82
    57
    I just bought a 2018 prius Prime. Hopefully if you charge you battery each and evey night you can do most of your driving on electric only. No engine wear in electric only. I have a 2010 Prius level 5 trim that just popped it's headgasket on its second engine at 431,000 miles. Rather than installing another JDM engine in a car with that many miles I replaced it with a Gen 4 Prius Prime. The EGR was redesigned in the Gen 4 and the EGR gas enters the intake manifold behind the throttle body instead of a tube with 4 rather tiny passages on each cylinder which tend to clog up and overheat cylinder 1 especially and lead to headgasket failure. I say hopefully it will last longer than the infamous headgasket blowing Gen 3. Other improvements in gen 4 1.8 liter are higher tension piston rings which reduces blow by which clogs up the intake manifold and blowby causes oil burning so hopefully your Prius Prime will longer than the Gen 3 Prius which is now not recommended to buy because known headgasket issues by several mechanics
    #22 GustoGuy, Jun 27, 2026
    52,855
    congrats! how many miles on her?
  4. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    4th gen should last 400k miles unless u damage it somehow
  5. Andy2
    Andy2 Member
    79
    51
    Victoria, B.C.
    2022 Prius Prime
    Technology
    Any sense of how long the Prime traction battery may last even if overall driving miles remain low? Can a PHEV last 20 or 25 years without replacing traction battery? Or is it more likely to last only 15 years or so even if miles are low? If so, this would seem a significant downside to the vehicle, in my view.
  6. GustoGuy
    GustoGuy Member
    82
    57
    Only 32500 miles on my 2018 Gen 4 Prius Prime. I am a Pharmacist and I get paid to drive. It's been just under 1 month since I bought my car and it had 29600 miles when I bought it. I only have about 7 more years before I plan to retire and my 2010 Gen 3 Prius had 130,000 miles on it when I bought it in November of 2017 and last month I noticed it started idling a bit rough at times (Death rattle) then it smooths out. I removed and cleaned the intake manifold and cleaned the EGR valve and EGR cooler at first and it didn't seem to help so I brought it in and it was diagnosis with a head gasket failure and Techstream detected a historic sporadic missfire on cylinder 1. They didn't do a bore-scope camera inspection and since the car had 431,000 miles on it and it was already on it's second engine ( replaced original engine in 2021 with JDM engine) so I decided to retire it. The coolant level reservoir was also a bit low too so it was diagnosis as failed head gasket cylinder 1. Ironically the engine was still at full on oil and since the engine swap I never needed to add oil between oil changes. I was hoping it would make 500,000 miles but Gen 3 Prius tend to blow headgaskets after 200,000 thousand + miles
    #26 GustoGuy, Jun 28, 2026
  7. GustoGuy
    GustoGuy Member
    82
    57
    The 8.8 KWhr battery is only good for a maximum of 25 miles of EV driving. I heard that some high mileage Gen 4 Prius Primes still are still functional albeit with a few miles less driving range in EV mode. I plug in every day so first 20+ miles are electric. Electricity is cheaper than gasoline plus hopefully the 175 miles max per week of EV driving will help the gasoline engine last longer. I live in North central Minnesota and I average 35,000 miles per yer so EV mode could take at most 9000 miles off the engine running could buy a few extra years of engine life. 15 years if well maintained should not be a problem
    #27 GustoGuy, Jun 28, 2026
  8. Andy2
    Andy2 Member
    79
    51
    Victoria, B.C.
    2022 Prius Prime
    Technology
    I’m still getting 40 miles (64kms) as my estimated EV range when fully charged in my ‘22 Prime, so no significant degradation yet. I wonder how degraded the traction battery must become before the car is inoperable and requires a new battery.
    #28 Andy2, Jun 28, 2026
  9. GustoGuy
    GustoGuy Member
    82
    57
    Unfortunately I recently replaced my 2010 Prius Traction battery this January. at the time it was running great. I spoke to the woman interested in buying my old car. Her mechanic is a real prick and says she should only pay me $200 and I put in a new 12 volts battery and a $850 reconditioned traction battery from MN Hybrids so $500 is actually a really good price. Plus the body on the car is straight and there is no rust through at all on the body. Her car has front end damage plus a bad hybrid system which would cost way more than $500 to fix. Plus my car is a level 5 trim with the 17 inch alloy wheels which I will sell on Facebook marketplace to minimize my loss of replacing the traction battery
  10. BiomedO1
    BiomedO1 Senior Member
    4,600
    2,414
    Left Coast
    Ummm; you've got 430K miles on it with a blown head gasket and it's a 16 year old car. While I agree with you that $200 is a low-ball offer, the new owner is going to have to replace the head gasket on a 430K mile car with a "rebuilt traction battery". If that lady doesn't wrench, she's just going to pay for that mechanic's kids college tuition. I mean that's why your retiring that car, RIGHT?????? At this point in it's life cycle, it's going to nickle and dime you to death - and it's going to be unreliable.
    Reality Bites....... A car isn't an appreciating asset, it's a tool. Unless it's a rare collectable; which you'll need to find a buyer. In most cases, a house would be an appreciating asset; but that requires basic maintenance too.
  11. bisco
    52,855
    the original plug in prius is 14 years old and most are still going strong and the prime is much better. I suspect 20-25 years is not going to be a problem for most.
  12. GustoGuy
    GustoGuy Member
    82
    57
    Yeah I am very aware that cars are depreciating things. I have never purchased a new car even though I can easily afford to do so. I like to buy 3 to 5 year old cars with more options since depreciation is greater during the first 5 years especially if you sell to a dealer as a trade in. I paid just under $24,000 for my loaded Prius Prime Plug-in with advance trim and 29,600 miles. I hope that it has several more years of life on it. It's the most I ever spent on a car and used car prices have really gone up since the last time I replaced my car
    I agree. I like to usually buy 3 to 5 year old cars just because of depreciation. I paid just under $24,000 for my loaded Prius Prime Advance with 29,600 miles on it. You can't buy a decent new car today for that amount especially a new Gen 5 Prius plugin with all the nice options. Decent used car prices have really gone up since 2017 when I bought my Gen 3 with the level 5 trim. $200 is a bad low ball offer especially on a level 5 trim Gen 3 with the nice JBL stereo system with a reconditioned hybrid battery $850 and a new 12 volt battery too. I do most of my own maintenance and within the last year I redid the front brakes new rotors and pads and new rear wheel bearing in the last 2 years. How much is a fair price $500? Or $450?. I will sell those nice 17 inch alloys on Facebook marketplace for an easy $500 with 2 year old tires. I run Blizzacks on black 15 inch in the winter so they have plenty of tread on them
  13. sylvaing
    sylvaing Senior Member
    1,221
    517
    Lucky you, being in SC, you don't have to worry about the body falling apart before the mechanic does, like for us up North.
  14. BiomedO1
    4,600
    2,414
    Left Coast
    Yes; $500 would be fair - especially if it's still drivable and doesn't miss too badly. The bottom line is it's a car with 430K miles on the clock and almost everything you've stated above is maintenance that needed to be done, to keep the car on the road. Sunk-cost.
    A high school kids first car and a wrench. I bought my first car as junior in high school, similar condition 40 years ago. Body and seats in great condition, but neglected mechanically for $250. Just be up-front on what it needs, because they are high demand, safe cars for high school kid and not enough power to get them into trouble. Any mechanic would see that as a fair price for a car, for their kid as long as the interior and body is in good shape.
    Good Luck.....
  15. GustoGuy
    GustoGuy Member
    82
    57
    $250 in 1986 would be equivalent to $765 in today dollars. I will sell the 17 inch wheels with the 2 year old tires separately from the car for $500. Maybe if I am lucky I can recoup most of the $850 I spent on the reconditioned hybrid battery in January
    BiomedO1 likes this.
