Prius Prime fuel gauge problem
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Hoan, Jan 9, 2023.
  1. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    I was driving the check engine light came on. The fuel gauge was 3/4 full, and the gas mile range. I went to the gas station and filled it up. It only took half a gallon, I went home unplugged the 12 volt battery. After 30 minutes I plugged the 12 volt battery back in. The total gas millage went to 418, and the fuel bar was full. When I bought the car. When I pulled out the dealer, it showed 525 miles total gas mile range. What can be the problem?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    So, is your gas gauge showing a full bars when the tank is full, and empty when it is about 2 gal left in the tank? The number you are citing is not a gas gauge but DTE (Distance To Empty) range, and it is dynamically "estimated" by recent gasoline consumption efficiency (mpg on HV mode only not including the EV mode in the calculation). If you drive your car very efficiently on HV mode, then you will see longer DTE on your next fill-up.
    See this thread:
    What is your DTE after fill-up?
    #2 Salamander_King, Jan 9, 2023
  3. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    What was your reasoning to fill up the fuel tank when the check engine light turned on?
    Getting 418 miles DTE seems pretty low. Do you drive up lots of hills or travel at fairly high speeds? My 45 mile round trip commute has me driving up and over a few hundred foot hill each way and doing ~70 mph on the freeway, and the DTE after a fill-up is around 500 miles.
  4. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    the problem could be related to the check engine light, but since disconnecting the the 12 volt battery that code whatever it was might be harder to impossible to find with a cheap code reader.
    I doubt anyone would be able to give even a best guess what the cars problem is from the description given in the OP.
    If it were me, I'd be much more concerned with why the check engine light came on, than why the cars distance till empty estimation dropped from whatever it was before disconnecting the 12 volt to it's 418 miles till empty estimation showing after the 12 volt battery was reconnected.
  5. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    The DTE change makes sense because you've basically reset it's computer and you did so in winter. All of the available data it's going to estimate with is going to be lower gas mileage winter driving.
    I do wonder if the OP meant to say that the gas light came on way early which explains the stopping for gas and the dealership just going with a reset.
    Is the gas gauge and gas light performing as expected now?
  6. BiomedO1
    BiomedO1 Senior Member
    4,184
    2,187
    SacTown, Ca
    The OP may have read a article about loose gas caps triggering a CEL; but I agree with everyone that just disconnecting the battery to reset everything isn't the correct solution. The error codes should've been read; so you have an idea of what potential problem you may be facing.
    Lots of rain in S. Cal the past few weeks; which requires higher gas/EV consumption to move the car. This equates to lower DTE. Now that the car has been reset; expect some weirdness while the engine systems recalibrates itself.
    #6 BiomedO1, Jan 11, 2023
  7. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    So after I unplugged the 12 volt this time. The gas guage works fine now, I took it to a shop. They said it's the sending unit is bad. And since I unplugged the 12 volt battery. The CEL has not turned back on.
  8. bisco
    52,405
    excellent!
  9. BiomedO1
    4,184
    2,187
    SacTown, Ca
    If the sending unit is actually bad, the CEL will come back on. You should get your battery checked - the one under the hood; it may be low and causing these weird problems and electrical gremlins. Make sure it gets a load tested, not just a voltage check.
    Hoan likes this.
