Prius Prime harsh ride quality?
Discussion in 'Prime Main Forum (2017-2022)' started by xacto1, Dec 6, 2021.
  1. xacto1
    xacto1 New Member
    Los Angeles
    I test drove a used 2019 Prius Prime (Plus trim) yesterday, and was shocked by how stiff and bumpy the ride was. The whole car seemed to rattle over every little bump, and the road noise was quite loud as well. It seems from browsing this forum that the majority of Prius Prime owners feel that the car actually delivers quite a smooth, comfortable, and quiet ride. Thus, I'm just wondering if I test-drove a dud, or if my expectations are just unrealistically high when it comes to ride comfort and cabin noise?
    As some background, my currently daily driver is a 2005 Lexus RX330. Even though this car is old and slowly becoming bumpier and louder as time goes on, it still offers a FAR more comfortable, plush, and quiet ride compared to the Prius Prime I test drove.
    I also recently test drove a Tesla Model 3, and despite this car having a reputation for a harsh ride, I still found it to be significantly more comfortable and quiet than the Prius Prime.
    I'm really bummed out, since I was so excited to buy a Prius Prime, up until the test drive. It seems amazing on paper and I love the idea of using electric for my daily drive, while still having incredible gas range when going on long road trips. However, I wouldn't be able to live with the jarring / bumpy ride every day, no matter how good the rest of the car is.
    I'm just wondering if I test drove a dud Prius Prime, and should test drive another one (maybe a 2022 Prius Prime Limited trim that my dealer will be getting next week), or if my expectations for the ride quality of a Prius Prime are just too high, and I should be looking for another car entirely, like a Lexus?
    Thanks for your consideration.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Not having reference points of Lexus or Tesla in my experience, I may not be able to compere but I know PP is not the quietest car I have driven before. As far as comfort goes, again our 7 years old Pathfinder Hybrid is far more comfortable to drive. That being said, PP is better than my previous HCH and Gen3 in overall ride quality. But the tires contribute a large portion of noise and comfort on any car. I would suggest you try test driving a brand new 2022 PP and see if that is any better. If so, then yeah, the used PP you drove could be a dud (or maybe just had very bad tires).
    #2 Salamander_King, Dec 6, 2021
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Ride comfort is completely subjective. Go drive a different one, or a new one, as a comparison.
    52,803
    definitely going to feel rough compared to many cars. if this would be your first prius, you'll have to resign yourself to it.
    for those that came from previous generations, it's much improved, believe it or not. :p
    the only thing you can check is the tires and pressures. maybe they have the wrong tires or the pressures are too high.
    triggerhappy007 and Mendel Leisk like this.
  5. xacto1
    xacto1 New Member
    Los Angeles
    Ok thanks for the replies all! It sounds like possibly I just drove a particularly uncomfortable Prime, and perhaps my expectations are too high as well. I’ll test drive the 2022 Limited trim when my dealer gets in in 1-2 weeks and report back.
  6. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Recommend you drive another Prime, as others have suggested.
  7. Trollbait
    12,814
    Cars make use of sound insulation to quiet the cabin. You'll find more of it in a luxury car on average. It can add a bit of weight, and is an easy thing to cut for weight reduction. The Prius very likely has a lot less of that insulation than the Lexus.
    A used car can have non-OEM tires on it. Which can be noisier and rougher, or the tire pressure is set higher. That can have the same results, but it does help with efficiency.
    If you try another Prius, take a tire gauge with you to check pressures.
  8. Merkey
    Merkey Active Member
    328
    301
    Birmingham, Michigan
    I rented a new PP for a weekend trip. Ride was very harsh. It turns out the dealer never adjusted the shipping tire pressure. It was at 50 psi.
    Db17 likes this.
  9. Trollbait
    12,814
    In the case of a used car, the previous owner may have the pressures high for better fuel economy.
    Merkey likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Our other vehicle is a 2017 RX450h:).
    I just drove that down to Southern California and back which was about 1200 miles. That is a much quieter and comfortable ride than our 2019 Prime I drive everyday ;).
    Hard to compare a RX to a base model Prime without finding what you found in my experience(y).
  11. Tideland Prius
    16,674
    A 2005 RX330 has soft suspension for cruising (drove an ‘06 around a mini autocross at a test drive event),. The Prime’s suspension is better than the old Prii but it’s not the smoothest. I find it comfortable enough (and nowadays, most cars are being tuned for a firmer ride, even cars like the Camry and Avalon. I wouldn’t be surprised if the current RX is firmer than the old ones, while still maintaining that Lexus ride quality).
    That said, a “harsh” ride is unbecoming of the Prime and my first guess is that the tire pressure is incorrectly set. I would try another one (or a new Prime) to see if you get different results.
    Raytheeagle likes this.
  12. Mendel Leisk
    42,293
    Yeah, as a lot of responders have said, could be the test-drive car had grossly over-inflated tires.
    Merkey likes this.
  13. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    I suspect ( since I'm not from your area ) there are a lot of prius there and a lot of motorheads too, (unless I'm misinformed). So given, neither you nor I have specific details concerning the car, it's hard to know what or why you got a bad feeling during your time in the Prime. Although, I'd think it might be possible the Prime had some suspension work done on it. Tanabe makes custom suspension exact fit parts that are undetectable to the casual viewer. https://www.tanabe-usa.com/
  14. Froglegs
    Froglegs Junior Member
    29
    Ny
    2020 Prius Prime
    I concur with the over-inflated tire theory. My previous vehicle was a 2018 Mercedes E400 with air suspension, and believe it or not, my PP compares favorably for comfort. Handling? No. Not even close. But very comfortable.
  15. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Absolutely! Our Prime sees a lot more use than our other vehicles and, while not as nimble, it is reasonably comfortable (third Prime in as many years... love 'em)!
  16. xacto1
    xacto1 New Member
    Los Angeles
    Just wanted to post an update on my Prius Prime purchasing journey since I stated I would a few weeks ago.
    Well, it turns out none of the dealers in my area have had any new Prius Primes to test drive since I started this thread about a month ago. Any vehicles listed as “available” on the website turn out to already have been reserved. My local dealerships also wouldn’t let me put down a deposit to reserve a vehicle for a test drive, since they only wanted “serious buyers” to put down a reservation. Well how can I know if I want to buy the vehicle if I can’t test drive it???
    In any case, this has been a rather painful and frustrating experience dealing with my local Toyota dealers. So I ended up just buying a Lexus ES 300h (hybrid) that was immediately available, and couldn’t be happier. Super comfortable, quiet, luxurious. It doesn’t have the plug-in capability of the Prius Prime that I was looking forward to, but with about 40mpg in real world driving, I haven’t had to go to the pump too much anyway.
  17. Tideland Prius
    16,674
    Congrats! That's a great car. I test drove the ES350 (they didn't have the ESh because they were all pre-sold back when it was launched in Jan 2019). Love the current generation.
    Merkey likes this.
