Prius Prime in very cold weather
Discussion in 'Prime Main Forum (2017-2022)' started by Nic Steussy, Jan 10, 2019.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    -8°F on the commute this morning. Windows remained clear. The key is to pull in outside air, never using recirculate. Outside air is dry. So while you drive, you must use that. Otherwise, you'll end up collecting humidity from your breath.
    jerrymildred likes this.
  2. Tideland Prius
    16,678
    And also run the A/C compressor to keep the air dry.
  3. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Agreed with others, always keep AC on and fresh air. I am neurotic about making sure I kick as much snow as possible off my boots in winter to minimize this from happening. I use rubber winter mats, and lift them out and dump them whenever I notice any water accumulation. I may get the internal frost a handful of times per winter, but never scrape it off, I prefer to melt it off with heat, or if I am really in a hurry I use a terry cloth I keep in the glove box to help once melt begins (then I really need to clean the windows when temps rise).
    But yeah, do whatever you can to remove humidity.
  4. john1701a
    12,840
    5,312
    58
    Here's the video:
  5. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I bought a mini scrapper a while back... I scrape a bit until I can drive off, and it helps the system as well.
  6. john1701a
    12,840
    5,312
    58
    Here's another video. Totally different route & driving, but also with temperatures below zero F...
  7. Sarge
    Sarge Senior Member
    1,325
    785
    2023 Prius Prime
    XSE Premium
    John, I find these videos interesting, but can you explain the meaning of each of the gauges you have showing on the right side? A few of them are obvious, but others less so, like the colour bubbles under the brake rotor and the “EV”...? I am sure you explained this in one of your very informational posts, if you can point me to it.
    I love having additional data available... I have a ScanGauge II mounted in my PiP to tell me things the car doesn’t, like instantaneous fuel economy, and RPM (lol) and some additional fuel economy gauges.
    m8547 likes this.
