Prius Prime Lift Kit
Discussion in 'Prime Main Forum (2017-2022)' started by Mikhail Bond, Dec 29, 2019.
Tags:
  1. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Hey guys,
    sorry for lack of any updates.Covid thing in LA and working at two jobs that stayed open made things weird.
    @PriusOffroad that looks awesome!
    I love how you did a through hole to use the existing sized bolts
    I am finally ripping apart my front end today
    Green Giant likes this.
  2. Green Giant
    Green Giant Junior Member
    I'd love to hear the results of this along with any issues. Ride height has been my biggest gripe
    Mambo Dave and PriusOffroad like this.
  3. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I had a heck of a time trying to lift a plug-in Prius. I would have been happy to swap some slight amount of performance for not scraping on things.
    PriusOffroad likes this.
  4. PriusOffroad
    PriusOffroad Active Member
    108
    170
    Chico, CA
    I was in the same boat. The Prius is such a jack of all trades with the one exception of ground clearance. It really sucked the fun out of driving it having to constantly worry about scraping your bumper on driveway approaches and parking blocks, or the underside on speed bumps. Our 33mm lift kit appreciated all of that with zero downsides. Feel free to reach out if you’d like to order one for your Prius!
  5. PriusOffroad
    108
    170
    Chico, CA
    We’ve got a perfect solution for that. ;)
  6. kenmce
    1,552
    525
    NY
    Too late, sold it.
  7. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Just got around to finally doing this. AMAZING. I cannot be happier.
    with the lift kit and new tires I am 2" higher off the ground and took a 1mpg loss.
    kenmce, Minima Domum and SFO like this.
  8. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    just a note to self and anybody else. Do not remove your struts without lifting both left and right side wheels off the ground. accidentally pulled my CV joint out of the tranny.
    Mambo Dave and Minima Domum like this.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    What exact size tire did you buy into ?
    Rob43
  10. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I think you had recommended it a while back.
    My only issue with this tire has been traction so far.
    Not the best for off-road but I’m not treating this like my 4runner
  11. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Yes, I gave you that tire size info.
    Let's see your lifted Prime, can you show the Prime community several good side view pictures ?
    Rob43
    Maxinator117, jerrymildred and AldoON like this.
  12. iregret
    iregret Junior Member
    35
    Oregon
    2018 Prius Prime
    I too would like to see the end result.
    AldoON likes this.
  13. Pollymath
    Pollymath Member
    102
    40
    Flagstaff, AZ
    How different are the 4th gen and 3rd gen mounts?
    As in, could I use these STL files to create a lift kit for my 3rd gen?
  14. PriusOffroad
    108
    170
    Chico, CA
    They are completely different. Wont work between generations. Every generation has a different bolt pattern.
    Mambo Dave likes this.
  15. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Final result, set two.
    First set was meant for a 6.5" wide rim
    This set is a hankook meant for a 5.5" wide rim
    #35 Mikhail Bond, Mar 13, 2021
    Mambo Dave and SFO like this.
  16. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Whopping 6.75" of ground clearance.
    I measured from the ground to the lowest point I could find, which was the rear side of the front control arm lip.
    I haven't checked my tire pressure since I was at the tireshop. I'm assuming they inflated it to 35psi
    What's your height at @PriusOffroad
    #36 Mikhail Bond, Mar 13, 2021
  17. Mendel Leisk
    42,376
    What’s the full description of the tire? Like this example: 195/65R15.
    SFO likes this.
  18. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    205/75/15R
    *Edited my previous post, I meant the rim that the tire was designed for.
    Having an issue linking the Amazon page
    Couple of notes:
    1. Rears will not have enough space for snow chains
    2. Fronts fit snow chains, may rub when snow is attached.
    3. Current MPG hit 49 on a short commute(will update this later on my daily work drives)
    This includes the attached cargo rack
    4. Freeway speed stability is loose...er
    Will provide more feedback when I go out late at night and drive more erratically to test emergency maneuvers.
    It has what I would describe as a floating point. Similar to a boat at speed but not planeing.
    #38 Mikhail Bond, Mar 13, 2021
    Bryce likes this.
  19. Mendel Leisk
    42,376
    I make it a not insignificant radius increase of 27 mm. Maybe some of that will squish out, but at least an inch lift.
  20. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    Well,
    Looks like I should have stayed with the 215/70/r15
    Maybe it's the combination of everything including the tire size increase but I'm hitting about 35mpg.
    I decided to buy another set to compare
    I found out that yokohama's also weigh 24lbs!
    So I just purchased the firestones which come in at 18.95lbs
