Prius Prime map update
Discussion in 'Prime Audio, Electronics, and Infotainment' started by IABoy987, Oct 19, 2023.
  1. prius4-me
    prius4-me Member
    58
    29
    Denver, Colorado
    whoops. no problem.
    #21 prius4-me, Feb 19, 2024
  2. mercat68
    mercat68 Active Member
    311
    216
    Mount Airy, MD
    So…maybe I was wrong in my previous post saying the ANSIKE card didn’t work. The car did report a card read error on first power-up, as I said. But I’m thinking now it was a functioning card and I should have just left it. I say this because I ordered another similar card from Amazon (this one), based on reviews and "A" Fakespot score. When I installed it yesterday, I got the same "cannot read SD card" pop-up on initial start-up. But this time, I checked a few map functions before removing it and things seemed to be working as expected, despite the error message.
    Today, I did not get the error on power-up, and I used navigation without a problem for a couple local drives. My maps, which were dated 2017-4-1, are now dated 2022-5-1, and I am seeing local roads for new housing developments I know did not exist in 2017, so it appears to be a newer map.
    I’ll report back after I’ve had more time to play with it, but thinking now that error message is just a one-time hiccup and not a real problem.
    sylvaing likes this.
  3. Mark Marks
    Mark Marks New Member
    CT
    Hi Sorry to break in
    I have a 2017 Prius Prime Advance
    When I go to Toyota parts check the standard monitor show the Nav SD upgrade card for about $200. However when you enter you vehicle info or Vin# it breaks down the parts list and indicates the SD is different for the 11.6" screen and far more costly- cheapest I found was $600 and as much as $900+ ? So I guess I'm asking was the standard SD totally compatible the Prius Advance 11.6" nav system. I having the SD installed this week and they quoted $200 but I concern it might screw something up. I belief it's 86271-GN8PR-23. However every Toyota part selling site indicates to use a another version at a steep price.
    Your feed back will be much appreciated . Did you search and come across the same thing? Search for 86271-GN8PR-20 or 23 and you see what I mean when you check model compatibility. See PDF I attached.
    Thanks Mark
  4. Mark Marks
    CT
    Was you display the 11.6"
    Thanks Mark
  5. Mark Marks
    CT
    Also did it the new SD work the same with all the same features as the old card(Voice guide - Etc.) Thanks Again
  6. Caduceus
    Caduceus Junior Member
    Massachusetts
    Looks like there are 2024 map cards out now. I'm looking to update my 2017 Prime Premium (11.6 display) because they changed all the exit numbers around here a few years ago, but it isn't clear to me what card is supposed to work - they all mention 2017-2018 Primes, but not a specific model, and I see cards labeled as 86271-0E076 and 86271-0E075 - is that just the difference between the 2024 and 2023 cards? I'm leery because I know there are differences between the 11.6 head units and the smaller ones...
  7. Thomaus
    Thomaus Junior Member
    Toronto
    2018 Prius v wagon
    Technology
    I just installed the 2024 edition (86271-0E976) from Amazon Canada into our 2018 Prius V Tech with Nav. All good as it quickly got through the loading maps message and the map date updated to 2023. Our old breadcrumbs and labeled addresses were all there afterwards.
    The first one we ordered wasn’t marked Amazon delivery and never showed up. We got a refund on that and by that time, there were versions available with Amazon delivery. Showed up quickly this time.
    When we bought this used from a Toyota dealer, I asked for a map upgrade with our deal. They gave us $200 off instead.
  8. OptimalPrime
    OptimalPrime Active Member
    172
    100
    Keene/Nashua
    About a week ago I successfully installed the 86271-0E075 into my 2017 Prius Prime Plus with small screen. The Amazon seller was Kimlion. My review of it on Amazon is under username NikonF7. I paid $8.99 after $1 (or 10%?) off coupon. That was about 1/3 of what the 1 year newer 0E076 was going for at the time. So I upgraded to probably 6 years newer than what I had, versus 7.
    I just pulled open the little door at bottom right of screen, and with car off, replaced the chip. After that, I just followed instructions on the screen.
    Turned car on, it gave instructions to turn car off and on. I did that, then the progress bar chugged along for about 10 minutes until done. Once the car was happy, and appearing to have the new maps (May 2022) I turned the car off and on again, all was well. One more time for good measure, all was well. Cleaned dust out from behind the door before replacing it.
    It does find some slightly different and better "shortest route" and "fastest route" results compared to before, and does display the 2022 map date in the car's settings. No new roads around here to test it on, but it sure seems to be updated, to me. I put the old chip in the glove box in case this one dies.
    Nothing went wrong. For $9 it is a no-brainer to do this.
  9. Pamela Cubberly
    Pamela Cubberly New Member
    Clarksburg, WV
    I bought an update online for my 2017 and it doesn't work. Is there a reliable source online? I checked my Toyota dealer and the latest update for my car (17.1) costs more than $1,000!!
  10. BiomedO1
    BiomedO1 Senior Member
    4,625
    2,424
    Left Coast
    IMHO, find a tech savvy, trusted kid. You can download the latest infotainment software and install it yourself (not the maps, but the OS). I don't have the link, but ran across it a few months back, when I was bumming around, in the Toyota website. It even ask for vin number to make sure of compatible hardware. That should get rid of any hic-cups on a maps update.
    You can just tether your phone to the system, your phone maps automatically updates and doesn't cost you anything. If you running an Android phone, there are conversion boxes for less than $100 to talk to your Carplay jack.
    Hope this helps...
    Opps, sorry - car needs to be 2020 or newer to transmit apps to your console. You'll have no choice but to pay for the dealer's files if you want updated maps or run a separate Garmin. For $1K; I think I'd run a Garmin instead or invest in a very nice cell phone holder.
    #30 BiomedO1, Nov 6, 2024
  11. rwb2
    rwb2 Junior Member
    Delaware
    2018 Prius Prime
    2018 Prius Prime Advanced, with the E7052 display - as delivered it still had the 2017 maps, so time to update. I ordered the “2024” map update from Amazon
    , $20; there are several vendors with what looks like the identical card, “86271 0E076.” Ordered from this “Mtmsnh” vendor as the description included instructions.
    The process: Turn the car off. Get the SD card cover off by pressing the right side, the left side pops down. There is a extension on the right side of the cover that it hangs down from; taking the cover completely off makes the next steps easier. Using a small flat screw driver, push the card in; it will pop out 1/8 inch. (i.e. not much!) Grab it with tweezers or needle nose pliers. Note contacts are 'in', on the engine side. A mirror and flashlight help. Insert the new card, and use the screw driver to pop it back fully in - it will look like the original before you removed it. Picture attached, sorry about the focus.
    I started the car, and got a brief message about SD card could not be read, but it disappeared within a second. Per the other notes in this thread, left the car on for ~15 minutes. The was a map display, but none of the navigation buttons worked. Turned the car off, waited a minute for all the lights to go off. Turned it back on ... navigation appears to be working normally. Map date shows "2023." <Happy Mode on>
    The item description notes the date of the card will be behind the maps date, "All cards are technically 6-12 months behind." Also of note, "The SD card can be used only in one car, once it is installed to the navigation system for the first time, it will be locked with cars VIN. Navigation system SD cards cannot be used/switched from one vehicle to another. "
  12. rwb2
    rwb2 Junior Member
    Delaware
    2018 Prius Prime
    UPDATE (The next day) <Happy Mode Off> Navigation does not work while moving. With a route set there are no voice prompts and frequent hangs. Map Date is now blank, it had shown 2023 initially. After selecting a destination, the route is shown and approved; but then hangs on the way. No change in a second try 4 hours later. Returning, obviously not compatible with my car’s configuration. I am reminded of comment #12 above that said it would not work, but others said it would. YMMV.
  13. sylvaing
    sylvaing Senior Member
    1,221
    517
    This is the one I bought.
    https://a.co/d/dyh75zj
    I popped the old original card and installed the new one. That was it.
  14. BiomedO1
    4,625
    2,424
    Left Coast
    Garmin and cell phones has been that way for at least a year now. Unable to make adjustment while moving - not hanging up; freezing. There was a time in cell phones where you make adjustment to your phone's configuration to get around that, Not anymore.
  15. Duprimus
    Duprimus Junior Member
    Pleasant Hill, CA
    2022 Prius Prime
    Some available navigation update may have a compatibility problem with the 11.6 HD screens. I have the 11.6 HD multimedia screen. I already tried 3 sources of map updates from amazon but is running on the same problem. Map loads & shows version 08/01/23. Freezes after entering destination address. Resumes function after a restart only to freeze again while navigating. Froze and restarted 6 times on an 9-mile route. Can only view 1 mile radius on the map while the rest is blank.
  16. BiomedO1
    4,625
    2,424
    Left Coast
    IMHO; If you got a 2022 Prime, just mirror your preferred cell phone map app to the Toyota display - less hassles and you don't have to 'bend-over' for crappy, expensive updates that don't work.
    YMMV
  17. OptimalPrime
    172
    100
    Keene/Nashua
    After running this new version for 5 months, I am overall happy, but not perfectly happy. My only complaint is that it seems to be installed on a slower microSD card than stock. Here are the symptoms which make me suspect it. In my normal driving, the speed of it finding routes to my usual destinations is reasonably comparable to the old Toyota chip, maybe or maybe not a couple of seconds slower to find the route, or a few seconds more to find the shortest and alternate route after hitting the "3 routes" button. But when entering a distant destination several states or several hundred miles away, it can sometimes take maybe an extra 15 seconds to find the recommended fastest route, then maybe an extra 30 seconds to find the 3 routes. For my own purposes, I'm fine with spending an extra minute at the beginning of each day of a road trip, compared to paying an outrageous amount vs $9 for the map upgrade. It is almost always true that I can skip the wait by just heading in the direction I know I'm going, and have it figure out the route while I'm driving. It's only when I'm curious about the other 2 routes it would calculate, to choose between them if a decision point is right at the start, that I bother actually waiting for it. In those cases, I can just start the car and have it do its calculations while I'm rearranging my stuff getting ready for a day on the road.
  18. OptimalPrime
    172
    100
    Keene/Nashua
    Time to update this post, in May 2026. My nav had started getting slow sometimes, flaky sometimes, and the whole infotainment screen was rebooting sometimes. As in, the SiriusXM radio would stop playing, the nav screen would reboot to the Toyota logo before coming back up and the radio coming back on, etc. Sometimes the GPS location would leave the road and be wandering nearby before eventually getting back onto the road I was driving on. Often enough that I started always navigating with the Waze app on my Android phone instead.
    I looked for the old chip in the glove compartment, suspecting I put it there, which is confirmed by my 2024 post quoted above. Well, it wasn't there. Oh well.
    I thoroughly scanned the car with a bi-directional, Toyota-specific Launch Creader scan tool. It didn't come up with any secret internal errors corresponding to what it might be. So, I figured "Time to do a map update, and hope it's just the $9 update chip flaking out." So, I found another $9 update to "2024 maps" 86271-0E075, from Amazon seller Smaxthsen. Only a year newer than what I had, but my goal was diagnosis and/or a functioning infotainment/nav system as cheaply as possible, not necessarily the latest greatest maps at higher cost. No sense spending more for the newest maps, if the system was still unusably flaky.
    Well, I installed the update one morning, before turning the car on at all. The instructions said to have the car off 20 minutes before installing, but I did it with the car off for 15 hours or whatever. Swapped the chip in. Turned the car on, ready to follow instructions for 10 minutes like last time. But what happened instead, is that it instantly just had the update with the "2024 maps" which show as 2023 when you view the version according to the car. So, my maps were instantly a year newer with this $9 chip than the last one. All slowness, flakiness, and rebooting is gone.
    When I just went to find the seller name on Amazon (Smaxthsen) I found that instead of 0E076 being $9, it is gone. But instead of 0E077 being $25-$40 or whatever price I balked at, it is $16, which I would have happily paid. So anyone looking to grab "2025" maps which will say 2024 on the Toyota screen, you are luckier than me.
    The bigger lesson, is that if your infotainment or nav get flaky,
    do a cheap map update before spending much time or any money trying to diagnose it.
    Most likely, it is just the microSD map flash memory dying.
