Prius Prime or Regular Gen 4?
Discussion in 'Gen 4 Prius Main Forum' started by UserError, Jul 30, 2018.
  1. UserError
    UserError Junior Member
    81
    Illinois
    So story time. When the 4th gen came out I bought one immediately because I loved my third gen. I loved my 4th gen. But I traded it for a Mini Cooper and I regret it. I thought the mini would be fun (which it is) but it sucks to daily drive and driving it for more than 30 minutes is almost painful. The seats are terrible and offer little comfort or support.
    So I’m looking to buy a fully loaded Prius 4. I’m not sure what touring adds, can someone tell me? So I noticed that a fully loaded prime advanced is only 1k more than a fully loaded 4 so I was considering it. Were yiu in this situation? Which one did you choose?
    I don’t like that the prime doesn’t have a rear wiper. But I do like the heated steering wheel, fog lights, and the idea of 20 miles of ev range. But I don’t know if once the ev range runs out if it becomes a worse hybrid due to added weight?
    Thanks in advance Prius chat, sorry for the long post.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Work out what sort of range your normal commute is & whether EV mode will save you in the long run. Also - if you can get away with 4 seats (I had all 5 full this afternoon).
    Take them both for a drive - see which you like, and buy it!!
    Rmay635703, RCO and UserError like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Touring adds 17-inch wheels and lower profile tires, so a little stiffer ride (shorter sidewalls --> less flex) Perhaps a different suspension tune for better handling? Some cosmetic touches to the front fog light cluster and black rear "diffuser" below the painted bumper.
    UserError likes this.
  4. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
  5. UserError
    81
    Illinois
    Thanks for clearing that up. Definitely don’t want bigger rims with a worse ride and less mpg. So that narrows it down. Thank you.
    Incredible! Thank you for sharing.
    I don’t for see myself carrying people but that is a good point. As far as my commute goes it isn’t far and could benefit from the ev but I’m concerned once it runs out will it be a worse Prius due to added weight. I’ve been trying to find more owner reviews on YouTube.
    #5 UserError, Jul 30, 2018
  6. Tideland Prius
    16,680
    The Prime is rated at higher than the non-Eco version of the Prius (54mpg combined vs. 52mpg for the non-Eco Prius). The larger battery helps with regenerative braking (greater capacity to hold more regen). Acceleration is slower because of the heavier weight but you have more momentum for P&G.
    The Prime is rated at 25 miles from the EPA. Members here have been beating that in the summer (30-35 typical but you can wander over to the 40 mile thread if you wish) and 20-25 in the winter. The Prime has an efficient A/C and heat pump to reduce electricity consumption in the summer and winter.
    Check out john1701a's videos. He has some winter ones too.
    RCO and alanclarkeau like this.
  7. jaspernuts
    jaspernuts Junior Member
    25
    32
    Madison Lake, MN
    My concern is if I buy a prime and keep it 15 years. What is going to be the cost of a replacement battery in 10-15 years?
  8. Rmay635703
    Rmay635703 Senior Member
    2,701
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Nobody knows, batteries are getting cheaper though, there are three lithium Insights I’m aware of , possible hobbiest upgrades by then
    RCO likes this.
  9. bisco
    52,848
    you could probably find a salvage one by then.
    keep in mind the prime hatch is smaller, and no spare tire.
    #9 bisco, Jul 30, 2018
  10. alanclarkeau
    7,045
    7,593
    Much less than your savings in petrol. There were the detractors with PRIUS batteries - they lasted on average much longer than the 8yr warranty and even then were about 1/3 to ½ the price that they were rumoured to be. But your savings in other maintenance like brakes and a "gearbox" (which it doesn't have) which could well last forever.
    The landscape of cars is changing so rapidly, I'm not sure if we'll be keeping them as long as previously (I think the average USA age is about 10 years - but that includes classic cars which aren't really driven much at all). While PRIME and PRIUS are well equipped by current standards, in 15 years, we'll think back to the '18 models the same as today we think back on 2003 models - antique.
    As @Tideland Prius said, from what I have read, a PHEV (PRIME) should be able to achieve better MPG than an equivalent PRIUS - the same as a PRIUS is much better than a non-hybrid - because of the largest battery's ability to play the hybrid game with more gusto. With the bonus of EV for at least some of your driving.
    Tideland Prius and RCO like this.
  11. UserError
    81
    Illinois
    Thinking I’m leaning towards the regular 4. Just wondering if I pull the trigger now or wait fir the 2019. Wonder if they will add or change anything other than the front and rear taillights?
  12. alanclarkeau
    7,045
    7,593
    Or, you could get a good deal on a 2018 when the 2019 is released, whether it's changed at all.
    Here, nothing has changed since early 2016 - same as in 2018.
    Rmay635703 likes this.
  13. Rmay635703
    2,701
    1,729
    2013 Chevy Volt
    If your buying brand new you will probably find the Prime has a better features VRS cost compared to a Normal 4 (in many areas the Prime is cheaper)
    Unless you need the 5 th seat a lot personally I don’t see a lot of financial reason to buy a non plug in at this point
    Ah well good luck
    RCO likes this.
  14. UserError
    81
    Illinois
    My reasoning for thinking of going 4 over prime advanced is there are almost none in IL and the ones that are here aren’t the magnetic grey. I don’t like the other colors. I also am unsure of how long gas can just sit in a tank like that. I think if I had the prime, there would be extended periods where I wouldn’t use any gas. Is this a problem?
  15. Rmay635703
    2,701
    1,729
    2013 Chevy Volt
    A Volt can go up to a year between gas fills because the tank is sealed and because the car has complex fuel maintenance programming, I have no doubt Toyo can automatically monitor and maintain the gas/engine like GM
    Next,
    Can you order a car?
    In my area there are no Prii plug in or otherwise at any dealer, my solution was to drive 2 states away and get a half price Volt,
    And thinking back,Honestly I’ve never bought a car locally as there has never been a car I would want nearby .
    I guess to each his own.
    RCO likes this.
  16. Mendel Leisk
    42,343
    I'm with you there. Get one with the spare for sure.
    alanclarkeau likes this.
  17. Tideland Prius
    16,680
    Both 3 and 3T have spare tires.
    Mendel Leisk and alanclarkeau like this.
  18. alanclarkeau
    7,045
    7,593
    You can force it to run the ICE occasionally - run out of battery. Not sure if it will start the ICE if you hit the accelerator hard - PRIUS does that, but maybe not PRIME. If it does, it'll keep running at least till the ICE warms up.
    Not sure about Magnetic Grey - I had one car that colour, and it was the hardest to keep clean. Worst still, it was the one which seemed invisible to other drivers as it blended into the grey of streets, shadows etc. I drove with headlights on day and night. My sister bought it from me, and she commented about the invisibility too.
    Whatever you get, enjoy!!
    RCO likes this.
  19. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I wouldn't worry about not using the gasoline, thats true for many Prime owners.
    I don't think lack of Primes in the state is a big deal either.
    I'd be focus on spare tire, cargo space, 4 seats, and commitment to plugging in.
    If you dig that, and can give up 5th seat. spare tire, and cargo space...OK.
    Color is another thing...I like the orig blue though if they still have it.
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Another way to fire up the ICE is to crank up the heater and that will call for engine to heat up.
