Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    What does DRCC stand for?
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    Dynamic Radar Cruise Control
    #1 in Easley,SC
  3. bwilson4web
    16,514
    I tried PWR mode with dynamic cruise control and I got the impression of a little more 'figety' controlling the speed. Not excessive so it may be just an impression. Reverted to ECO mode and no real difference. Hard to call this one.
    52,789
    is there normal mode, or has that been deleted?
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    So, it appears the Prime behaves differently. You would need to drive a Gen 4 for comparison to be sure.
  6. bwilson4web
    16,514
    There is but I was trying to find out if there is a difference in cruise control performance between the extremes, ECO and PWR. There may be but I have too little data to tell.
    It is too early to call for the Prime unless someone finds a Toyota reference. My informal test is not definitive.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Try a resume from 30 under and record the time it takes to get back to the setpoint in each mode.
    bwilson4web and jerrymildred like this.
  8. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Did I imagine this, our have I read somewhere that with Chademo in Japan they can get power OUT of the Prime traction batteries as well as put it in?
  9. bisco
    52,789
    correct. pretty sweet in a power outage. it has nothing to do with chademo though, they had power out with the pip as well. we got bupkis.
  10. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Wow! Is that any good to us in the Uk? Will we in rye UK or any other country have Chademo on our Prime, and does the car have to have a special spec to work that way, that we might not get?
  11. bisco
    52,789
    do not know, you might get it. isn't the prime being introduced there now?
    then again, didn't the bard say, 'kill all the lawyers'?
  12. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Yes v v soon. But not all documention available yet.
  13. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    If you are referring to CHAdeMO DC fast charging then no, it will not be offered in Europe to my knowledge.
    If you are referring to AC power output (limited to 1.5kW I think) then no again:cry:
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Owner's manuals can be found here:
    Toyota Europe
    Only one inlet in the car, and it is "Type 2" (Mennekes) not "Type 1" (J1772) that the PiP had.
    It would be nice (at the dealer) to get both cables:
    1. Mode 2 EVSE for charging from a household socket it is 10A (EVSE limited) so takes ~3 hours from empty to full and require 12-13A circuit line.
    2. A Mode 3 cable for using public charging stations (as not all of them have cables) or a Mode 3 charging point installed at home. The on-board charger is rated at 16A so if the station can supply this (all of them should) then it takes ~2 hours.
  15. bwilson4web
    16,514
    Bob Bruninga's paper "Overlooking L1 Charging At-Work in the Rush for Public Charging Speed": http://www.aprs.org/Energy/Charging/IEEEpaper.pdf makes a credible argument for L1 charging at work. He points out there is an EV triangle: (1) to work, long commute, (2) shopping errands, and (3) home. The long time at home and at work makes L1 charging ideal. At shopping and entertainment areas, L2 charging makes sense. I would complement his paper by pointing out what the absence of at work charging does.
    Instead of staying at work through the lunch hour, it makes sense to seek nearby L2 chargers, especially free, for the lunch hour. Instead of taking a sack or snack lunch, the employee leaves their office, phone, and work resources to grab a quick charge and too often over-sized lunches. But the employer loses that labor which typically costs at least 100 times more than the electrical cost.
    At ~$50k per year including benefits, an hour at work would cost the employer about $25 in labor. But the electricity for a typical 10 mile commute would be about $0.25 (Huntsville AL rates and my daily commute.) This varies by region and commuting distance but we're looking at an order of magnitude loss of productivity because an employee is encouraged to leave the office for lunch. In effect, L1 charging at work is a low-cost way to increase employee productivity.
    The irony is there is no equivalent incentive for gassers or diesels. No employer could afford what it takes to install any refueling service at work. Worse, the cost to cover the morning, cold-start commute for something like a 28 MPG, Ford Focus would be at least 1/3 of a gallon, about $0.75 versus $0.25. Commuting in a cheap gasser is its own punishment, a wallet fuel tax every day.
  16. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    I've actually supported a client that had an on-site fuel station... but it was an R&D facility for a major automaker, so they needed road-legal (taxed) gasoline on-site anyway. And, they charged employees and contractors more for it than the gas stations 10 miles down the road, so it was no incentive, it was purely a "grab half a gallon or so, so you can make it into town" situation. (And one time, I didn't do so, and then ran out of gas...)
    In colder climates, providing L1 charging actually does benefit gasser and diesel owners in winter, if the employer provides it in the form of 120 volt outlets, rather than EVSEs - block heaters eliminate the warm-up penalty, and provide cabin heat more quickly.
  17. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Work-place charging makes way too much sense -- that is why it is not being implemented.
    Well, peevishness aside, L2 charging does not have to be expensive. I paid to have it installed it at home for a total cost of $800 but the larger cost for parking lots is bringing the electricity to the EVSE and building a safe island for the equipment. That cost is independent of L1 or L2
  18. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    However, let's say you've got 100 amp, 240 volt service to the parking lot.
    Doing 7.2 kW L2, that 100 amp 240 volt service can provide charging to three parking spaces at full load - 30 amps at 240 volts per space. Granted, Chargepoint's stuff can balance load between EVSEs, and de-rate when there's too much load, but still, that costs more in EVSEs.
    Doing L1, you can provide twelve 15 amp 120 volt circuits, for only the cost of sticking poles with cheap 15 amp outlets and lockboxes (so you can lock your EVSE in). And, the maintenance is far lower - if an outlet fails, you buy a cheap GFCI receptacle, not a whole EVSE.
    bwilson4web likes this.
  19. EV-ish
    602
    278
    SW US
    I follow the arithmetic, but the final answer is going to be a heterogenous L1/L2 build to service the variety of charging needs that crop up in daily life. My point was that the major costs incurred by the owner of the lot are not from choosing L2 over L1 as the author of the paper Bob references implies. I actually wondered if he was confusing L2 with L3.
    The smart-grid aspect is really interesting, but I think it would run into a legal quagmire for now.
    #239 EV-ish, Feb 26, 2017
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Intersting paper. I didn't have time to read every word of it, but I think I got the gist of it. I use level 1 at work and it's perfect. Very few unexpected trips, so I set the timer to finish about an hour before I go home. But at home I often have unplanned departures. So I'm giving serious thought to an L2 at home so I can at least give it a little juice before I go.
    I can also L1 at church if I can get to the right parking spot in our shared parking lot.
    I did take note of the author's comment that L2 isn't all that good for battery life. I had not seen that mentioned before.
