Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    As it is, your patience astonishes me.
    Perhaps starting from a couple different SoC points and then counting up to 10 (SoC pts more) would be less annoying.
  2. bwilson4web
    16,514
    It was also practice with lessons learned. I need to figure out how to get the time stamps too.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    A lot worse? What did you guess?
    0.75 gal to 80%.
    Edited.
    #323 giora, Mar 10, 2017
  4. EV-ish
    602
    278
    SW US
    This is Bob's method: "
    My next test is to find out how much gas does it take to bring the EV from 0% to 80%:
    • Drive car in EV mode to bring SOC to 0%
    • Drive car in HV mode to burn 0.5 gal on a reset, tripmeter A
    • Park car and photo A and SOC
    • Put car in 'charge mode' with time lapse video
    • Wait 2 hours
    • Calculate fuel burn per 10% SOC change
    He used the change in MPG on the display to calculate fuel burned while stationary and force charging.
    I think one valid criticism of the method would be that the fixed costs of having the vehicle on and the ICE turning are folded into the forced charge efficiency test, while in practical use they are part of driving down the road.
    Perhaps the net liquid fuel consumption for charging is Bob's results minus that used to idle the car ?
    Bob will have to chime in, but I think I prefer to see a dynamic test: consumption at steady speed, then consumption at the same speed PLUS force charging.
    iplug likes this.
  5. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Can't you just climb out the window like those NASCAR guys do? :cool:
    HPrimeAdvanced likes this.
  6. bwilson4web
    16,514
    Thanks, I have more details about this first test. FYI, anyone with a reasonable video/smart phone can run the same protocol and share their results:
    • temperature ~63F, estimated right-quarter wind 6-9 mph wind
    • cabin fan was on until seconds 4, no heat or A/C, just fresh air
    • car was in "D" against a curb so it would not 'creep'
    • parking brake was set, redundant to the curb
    • duration ~18 minutes
    67 MB, mp4, source.
    If I had a "Buster" crash dummy in the driver seat, I could set everything up from the passenger side and take a break. Just it isn't clear how much more accuracy is needed as this gives a rule of thumb for Prime charging the traction battery to 80%:
    • $2.00/gal * 0.75 gal ~= $1.50 for 80% charge
    • 6.4 kWh * 80% ~= 5.12 kWh, ~ $0.56 at $0.11/kWhr residential HSV rate
    • ChargePoint L2, rated 6.6 kWh @$0.85/hr in Nashville, TN
    #326 bwilson4web, Mar 10, 2017
    Insirt likes this.
  7. bisco
    52,789
    great price, but is it more efficient as just driving with the depleted battery?
  8. bwilson4web
    16,514
    Perhaps inartfully posed, there is a valid question here:
    What is the frugal and safe way to run a fully fueled and charged Prime tank dry:
    • Use EV mode until the SOC reaches ~12% (about 3 miles) or ~25% (about 6 miles.) This is the cheapest motive power assuming Huntsville $0.11/kWh rates.
    • Switch to HV mode to preserve the charge.
    • If by design or accident, the charge falls below your 'safe margin' range, use 'Charge' mode to bring it up before the gas runs out. Then resume HV mode
    • When the SOC % decreases because the engine is finally out of gas, use the EV safety charge to find a safe place to park and refuel.
    So what sort of 1,000 mile tank challenge might this be used for?
  9. EV-ish
    602
    278
    SW US
    You probably have a point. In the past people have posted that idling uses 0.25 - 0.33 G/hour; so even at the higher rate only ~ 0.1 G can be attributed to the 18 minutes of idling during the test, leaving 0.65 G for an 80% charge.
    Using 25 miles per full charge, the forced charging works out to 20/0.65 = 30.7 MPG
    I understand your use of FC, and I can understand it's place in the mountains for people who just have to pass other vehicles on two-lane roads, but for me it is almost certainly going to be a very rare use, if ever.
    bwilson4web likes this.
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Thanks.
    yesterday, late at night and at the first glance I did not realize the car was stationary during CM. Caught it later and edited my post.
    Your 16% in 18 minutes while stationary indicates 80% charge in ~90 minutes while others have reported zero to 80% in 30-40 minutes of constant highway speed.
    #330 giora, Mar 11, 2017
  11. bwilson4web
    16,514
    When dealing with a small sample set, 17 points 0%-16%, there are not enough data points to trust a gross number like an average. In those cases, I like to graph the data because we often see patterns to determine if there might be problems:
    • 0%-1% - this is an edge condition because we have very little, no control, over the initial state of the engine and specific HV part of the traction battery charge.
    • 4% - noticed the fan was on and temperature set to 62F, seeking outside air flow, so I turned it off. There may be some unknown, heat-pump load up to this point.
    Due to the statistically small sample set, we have to use other heuristics to decide if the data points can be trusted or used. So I tossed out the early points because we can't control the initial conditions and part of the observations overlapped my failed attempt to exit the car and continue recording metrics. By happy accident, the average I choose seems pretty close to the longest, flat segment of data points. Furthermore, the risk of 'sand bagging' with a too optimistic fuel burn per SOC% could lead to early fuel exhaustion.
    Now there may be more interesting things about charge mode. Like Edison said 'the secret to invention is to have lots of ideas.' My curiosity about it is satisfied but happily, I've shown how to use a video recording to get metrics for their experiment.
  12. bwilson4web
    16,514
    I was not interested in the rate of charge or time but rather the fuel burned to put a charge on the traction battery. Now it is accurate to point out without moving, the engine has to burn vehicle overhead fuel, the power that operates the computers and loads simply because the car is ON. There is also the engine overhead. There is a double-accounting issue of comparing the vehicle overhead when parked vs moving ... the vehicle and engine overhead does not double just because it is running down the road in 'charge mode.'
    Another approach is to use an A-B-A test with one of my benchmark loops:
    • 10 miles @28 mph in HV with no SOC, ~21.43 min - measure MPG
    • 10 miles @28 mph in 'charge mode', ~21.43 min - measure MPG and change in SOC%
    • 10 miles @28 mph in HV, ~21.43 min - measure MPG and report ending SOC%
    This is a little tricky because I need a better video recording technique than iPhone 'time lapse' that generated a 3.4GB file that had to be played back. In an ideal world, a digital camera would take a photo at the same place on the loop. I'll have to think about this.
    #332 bwilson4web, Mar 11, 2017
    iplug and EV-ish like this.
  13. EV-ish
    602
    278
    SW US
    Oops, error here.
    The run lasted 18 minutes for 16% SoC, so about 90 minutes estimated for 80% SoC. That could be up to 0.5 G from idling, so 0.35 G to charge up 80%.
    That is a much more reasonable 20/0.35 = 57 MPG as the upper bound, and
    20/0.42 = 47 MPG for the lower bound
    Very impressive, if true
    Giora's point above that others have posted charge times to 80% of 30-40 minutes is interesting since we don't know how successful the Prime is in picking an efficient power band during FC during different use cases. Bob's test during idle could be anywhere from the best possible case to anything but. There is certainly a lot of anecdotal experience from Prius drivers that FC during a depleted SoC event is not efficient.
    I maintain that FC is designed as a 'mountain mode,' meaning a means to not leaving drivers struggling with ICE only power on extended uphill drives. I'll guess that Toyota prioritized timely charge over efficiency here. One more reason to test at a ~ highway speed rather than stationary.
    #333 EV-ish, Mar 11, 2017
  14. Trollbait
    12,808
    Wouldn't this be easier with a Scangauge or similar that can report gallon per minute, and possibly SOC. The smart phone apps might also data logging.
  15. Since2002
    936
    1,098
    Duluth, GA
    I understand the basic concept of subtracting gas used for idling, since that represents the force needed to move the pistons, crankshaft, valves, etc. under no load, and you want to account just for the extra gas needed for the additional load induced by charging. But then you are comparing it to HV mpg where you are not subtracting gas used for idling. It seems like you would need to subtract idling gas from HV gas used to make an accurate comparison. Unless I am missing something.
  16. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I don't think this method is valid. The car is producing torque against the brake, and that uses energy in the form of losses - probably about 2kW. Plus, it's only charging, not driving at the same time which is going to put all the losses on charge mode and not bring the engine to a high enough power level to get it to maximum thermal efficiency.
    I think a better method would be to do another constant-speed driving cycle in charge mode and compare to your measured curve without charge mode.
  17. bwilson4web
    16,514
    Do I understand you're thinking:
    • 0.40 gal - idling engine and vehicle overhead over ~80 minutes?
    • 0.35 gal - charge mode cost to run SOC 0% to 80%?
    • 0.75 gal - for 80% charge?
    What is the basis of estimate for "0.40 gal"?
  18. EV-ish
    602
    278
    SW US
    I plucked a number out the range from the reported idling of 0.25 - 0.33 G/hour
    Since it would presumably take ~ 1.5 hours to reach 80% SoC,
    0.25 G/hr*1.5 hours = 0.375 G
    0.33 G/hr*1.5 hours = 0.495 G
  19. bwilson4web
    16,514
    Part of the problem is I don't know of a way that keeps the Prime in "D" gear and "HV" mode, and running the engine. During the setup, the car was in "D" gear and "HV" mode and the engine was stopped. I suppose I could have started the windshield defrost or possibly A/C with the windows down and set to a min or max value but now we're introducing an additional load that we don't know if it is constant.
    One Prius trick is to get the engine running and shift into "N" that will keep the engine running BUT disables transmission power flow. That would give an engine overhead but significantly change the vehicle overhead.
    That is why I proposed the benchmark loop in an A-B-A mode. We are way out of standard day configuration today but I can still practice the method and try the ear-bud, remote, iPhone camera operation.
  20. Lee Jay
    5,850
    4,036
    Why do you need it in D mode at all?
