Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. bwilson4web
    16,537
    Yet curiously they have a battery and power electronics in the Prime that easily achieves enough power. Since I've got my Prime, I see it as the prototype for a true, Gen-5 Prius that only lacks the expense of a plug-in port and AC-to-DC charger. If the Japanese Prius can have the 18 kW rear wheel motors, the traction battery and power electronics may already be there.
    Until Toyota comes out with their next 'standard frame', I can see the Prius c, Liftback, and v as being the payload versions and the plug-in Prime as the one that has reduced payload because of the increased battery and charging electronics weight. In the meanwhile, I'll growl in the corner about the missing: (1) tow package; (2) built-in house voltage inverter, and; (3) rear wheel motors.
    Now is the Prime perfect? No, as I would like a faster charge option, 30-32A versus the current 16A. Fast DC charging would be nice but the 40 kW one we have in Huntsville is pretty well matched to the 72 mi range BMW I3-REx and would be 'Godzilla meets Bambi' if applied to the Prime.
    There is a version of the J1772 that also has a lower DC charging capability and that might be a better fit to the Prime. But of course that is all we need, another J1772 variant 'in the field' . . . NOT!
    #361 bwilson4web, Mar 13, 2017
  2. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    The Model 3 should do considerably better, with its anticipated 0.21 Cd
    This graph is courtesy is Tesla
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Gen-0 (note that real programmers start at 0, not 1, ) was only only available in Japan. It had very different battery pack. Power output was lower too.
    Prodigyplace likes this.
  4. Trollbait
    12,831
    To get below 150 miles of range at a steady 70mph in a S60 with 21" wheels, the HVAC needs to be on, and the temps outside the 0F to 110F range. With the smaller wheels and pleasant weather, getting 150 miles at 75mph shouldn't be an issue.
    Model S | Tesla
    Driving Range for the Model S Family | Tesla
    The larger battery alone will improve the fuel economy. It was reported with DIY plug in conversions, and the PiP had a better EPA rating than the gen3 with a pack half the size of the Prime's. I see the introduction of the clutch along the lines of using more robust clutch packs and other hardier parts in an automatic transmission for a more powerful engine. Both extend the application range of component, but aren't a new design of a next generation. Plus, the transaxle development of the Gen4 and the Prime were concurrent.
    But like software, it comes down to what the party that created it wants to label it.
    I thought the Prius rear motors were lower power than that. Car makers sell sell cars to the general public, and Toyota might have felt E-four was too low power for the US one. I don't recall if anyone outside of Japan gets it. Perhaps we'll see it as an option in the next Prius v if they decide on trying to save it.
    Cars don't get tow ratings in the US because our trailer regulations are stricter. At best, a car will have a rating half that of what is in other markets. Apply the SAE standard for determining tow ratings, and it will be even lower.
    Not even the Japanese Prime has a built in house voltage inverter. That is built into an EVSE/power station that works through the CHAdeMO outlet of the car. I do think an inverter suitable and powerful enough for home emergency power would be an excellent feature on a PHEV, or even a BEV, but I suspect the manufacturers are leery of liability issues.
    Volt fans wanted faster charging in the gen2, but the majority of gen1 owners were only using level 1 charging at home.
    A slower charger means lower cost for the base price, and a PHEV does have that ICE and all its trappings that you paid for, might as well use it.
    Which standard is that? I know what many think of as Level 3 has been divided into DC Level 1 and DC Level 2. The Level 2 is the fast charging people think when using the level 3 label. DC Level 1 is a lower current like AC Level 1, but I thought it still worked over the DC cable, either CHAdeMO or CCS, not over the AC one.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    A little over 5kW, IIRC.
    bwilson4web likes this.
  6. NeilPeart
    NeilPeart Hybrid & PiP Convert
    75
    69
    Bay Area, CA (USA)
    This is true. While my wife and I still had our Gen 1 we rode in a Gen 0 NHW10 (I believe it was a 2000) and it definitely felt a bit gutless even compared to our Gen 1 (2003). Strangely I find the 2009 Gen 2 (we owned one) to feel a bit more powerful than the 2004 Gen 2; likewise the Gen 3 2015 (non-PiP) feels "faster" than our 2010 Gen 3. Placebo? Older car syndrome? The c and v both feel somewhat under-powered to me as well. Sorry for the digression...
    #366 NeilPeart, Mar 13, 2017
    Since2002 and bwilson4web like this.
  7. bwilson4web
    16,537
    A schematic labeled "FIGURE 6.3 - DC LEVEL 1 SYSTEM CONFIGURATION" shows using the J1772 pins 1 and 2 for "(Core pins for AC & DC Charging)". Later they differentiate between "DC Level 1 200-500 VDC 80A" and "DC Level 2 200-500 VDC 200A".
    I don't know of anyone in the USA market who implemented the DC L1 charging that uses just the J1772.
    Source: SAE J1772â„¢ OCT2012
    Trollbait likes this.
  8. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Congrats, Bob! I'm loving my Gen.IV! I'm trying to talk my friend Victoria (who currently has both a 2013 regular and plug-in Prius) to get into a Prime!
  9. bisco
    52,862
    unless she is fairly wealthy, it maybe more helpful to your friend to recommend staying with her current cars.(y)
    That_Prius_Car likes this.
  10. bwilson4web
    16,537
    I prefer to drive using dynamic cruise control all the time but noticed a difference between ECO, Normal, and Power. So tonight I did a short hill-climb:
    1. Holmes & Fairway climb to Holmes & 14th St.
    2. Preset cruise control to 65 mph
    3. Start at 28 mph and hit resume
    4. ECO ended 53 mph
    5. Power ended 58-59 mph
    This suggests these two modes may also have power limits. Also, this confirms a coupling between cruise control and driving mode.
    The BMW 3i-REx has three, power limited modes that also moderate the climate control.
    #370 bwilson4web, Mar 13, 2017
  11. bwilson4web
    16,537
    Tonight, I did some practice runs:
    • 3.5 mi @30 mph HV mode, 107.1 MPG 44F, 0% SOC - 0.0327 gal
    • 3.5 mi @30 mph CHARGE mode, 32.4 MPG 44F, +10% SOC - 0.108 gal
    ANALYSIS
    Due to the digital nature and small values, I'm automatically adding half the least significant digit as more likely true for the linear increasing values. For example, 3.5 mi could be 3.599 mi, it could have been just shy of rolling over. So I'll use 3.55 mi as a synthetic but more likely distance. I'll also do the same for the SOC, using 10.5% instead of the indicated 10%.
    metric 1st pass 2nd pass
    1 miles 3.55 3.55
    2 mph 30 30
    3 mm.m 7.1 7.1
    4 MPG 107.1 32.4
    5 gal 0.0331 0.1096
    6 SOC 0% 10.5%
    7 SOC gal n/a 0.0765
    8 SOC%/gal n/a 137.5% / gal
    9 SOC 80% gal n/a 0.592 gal
    10 gal/SOC% n/a 0.00727 gal / %
    Test route
    • start - 34.595042 -86.545609 W 563 ft
    • end - 34.646224 -86.540009 W 607 ft
    • Google Map shows it as 3.7 miles which is consistent with the known tire diameter based error
    #371 bwilson4web, Mar 14, 2017
    iplug and That_Prius_Car like this.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Why not extending the second drive in EV until returning to 0% usable SOC to complete the picture?
    If this adds ~3 miles (quite possible @ 30 mph) then the 6.5 miles second drive would have shown 60.2 mpg. The first drive for 6.5 miles @107.1 mpg would have used 6.5/107.1=0.061 gal.
    0.108-0.061=0.047 gal devoted to charging 10% or 0.378 gal for 80%.
  13. bwilson4web
    16,537
    I'm not sure we gain much by converting the SOC% back into miles. My primary interest is the impact on the remaining gallon when putting a 'safety' charge on the traction battery AFTER the tank warming light comes on. Also, double checking my numbers. I have been known to make math errors.
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The gain is finding out the amount of gasoline devoted to charge in each speed (thermal efficiency) and the 'sweet spot' of charging mode at constant speed flat ground.
  15. Prodigyplace
    12,715
    11,848
    Central Virginia
  16. Lee Jay
    5,850
    4,036
    I think you did here - by a factor of 10 (.007 should be .07).
  17. bwilson4web
    16,537
    Thank YOU!
    I knew something wasn't right but I was too tired to figure it out. Should be good now.
  18. Lee Jay
    5,850
    4,036
    I suspect you were just channeling your inner Bond.
    Since2002 likes this.
  19. bwilson4web
    16,537
    I wanted to summarize the "CHARGE" mode data from my initial experiments:
    The practice test driving at 30 mph suggests (37.7 - 32.4) / 37.7 ~= 14% loss of predicted MPG. Comparing the efficiency of "CHARGE" mode when parked versus 30 mph:
    • parked -> 0.0094 gal / % SOC
    • 30 mph -> 0.00727 gal / % SOC
    There is an inconsistency that the predicted MPG using the parking rate, 37.7 MPG, was significantly better than the measured, 32.4 MPG. There has been speculation that under road load, the engine will operate at a higher efficiency point. But when calculated by itself, the 30 mph test revealed a significantly lower rate of gasoline burned per SOC%, 0.00727 gal / %SOC, versus the parked rate, 0.0094 gal / % SOC. I can not rule out a math mistake but these numbers are inconsistent.
    What this means is I need to replicate both tests, in Standard day temperatures, scaled for a larger change in SOC. The 18 minute, parking test went to 16% and the 7 minute, 30 mph test went to 10%. But now I have enough data to estimate what it will take to reach a 50% SOC increase:
    • Parked -> ~60 minutes
    • 30 mph -> ~35 minutes, ~18 miles
    Now this suggests a potential mechanism for the discrepancy, vehicle overhead and rate of charge. The parking test was just a single metric. In reality I should have measured the parked fuel burn and then enable "CHARGE" mode. Then calculate the effect of "CHARGE" mode on fuel burn. But now I know to run each for 60 minutes.
    EV-ish and iplug like this.
  20. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    On parking with charge mode on
    Engine RPM is 1280 exactly......
