Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. GLouderback
    GLouderback Member
    Lower Merion PA
    That shows that the manager there doesn't understand who the buyers for this car are.
    pilotgrrl likes this.
  2. Prodigyplace
    12,711
    11,848
    Central Virginia
    You are ignoring the fact that MG1 & MG2 together provide more acceleration than the ICE engine. He obviously did not study the car's capabilities or try it himself.
    GLouderback likes this.
  3. GLouderback
    GLouderback Member
    Lower Merion PA
    In my experience, I find that they would rather sell you one of the 100 Corollas they have on the lot than order you a Prime which they know nothing about.
    Mark57 and Prodigyplace like this.
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    When the 2017s came out I noticed my local dealer seemed to have a glut of 2016 Corolla. This is the dealer that informed me that all Prius trim Two had black interior. there were no other options. :eek:
  5. bwilson4web
    16,520
    As I was planning to retire, I visited the local Toyota dealer thinking my decade of Prius and recent plug-in experience might be useful. Only it turns out their sales goals are Camry. I crossed 'car salesman' off my bucket list.
    #485 bwilson4web, Jul 28, 2017
    bfd and Prodigyplace like this.
  6. Prodigyplace
    12,711
    11,848
    Central Virginia
    The 2018 Camry Hybrid LE has the same 52 MPG rating as the Prius. You could sell that well.
    kenoarto likes this.
  7. Mark57
    2,945
    2,740
    OK
    Besides, I can assure you, the day you retire, your I.Q. doubles.:p Been there did that.
  8. bwilson4web
    16,520
    Ok, now we've got some new data.
    STUNT:
    "Drive Monitor 2" appears to have a latent bug that it only goes to 4.6 miles/kWh. In contrast, there is the true log:
    The Aug. 8 drive was after midnight in a light drizzle. So headlights, intermittent wipers, and fan on to handle the high humidity conditions. Wet streets increase rolling drag along with the water that impacts the car and drips off.
    Here is what happens in charge mode at a constant 35 mph:
    On a standard day, we would expect:
    Now we were already dealing with drizzle, night driving so there is some lose due to weather and time of day. But we have a rough order of magnitude:
    mode miles MPG gallons SOC %
    1 Std. day 11.9 97 0.123 0%
    2 Chg mode 11.9 36.9 0.322 44%
    • 0.322 - 0.123 = 0.199 gal for 44%
    • 0.00452 gal / 1 % SOC
    • 0.362 gal ~= 80% SOC, maximum SOC achieved in CHARGE mode
    • ~20 minutes to get 44% -> ~37 minutes
    #488 bwilson4web, Aug 8, 2017
  9. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    So you can achieve 0->80% SOC with 0.362 gallons - is that roughly 30 mins or so, in how long it takes?
  10. bwilson4web
    16,520
    Thanks, I added "37 minutes" for 80% charge.
  11. Tideland Prius
    16,675
    That's 1.37 litres for metric folks.
    $2.10/litre = $2.88
    $1.90/litre = $2.60
    $1.70/litre = $2.32
    $1.50/litre = $2.05
    $1.30/litre = $1.78
    $1.10/litre = $1.51
    90¢/litre = $1.23
    to fast charge to 80% in 37 minutes.
  12. bwilson4web
    16,520
    I am embarrassed. When I post in the BMW forums, I typically use SAE and Standard Units, but I've grown lazy. So let's add this:
    • 5.1 kWh ~= 80% SOC
    • 1.37 l ~= 80% SOC
    So now we can do some simple maths in Huntsville, AL:
    • $0.10/kWh * 5.1kWh ~= $0.51 for 80% charge
    • $2.00/gal * 0.362 gal ~= $0.72 for 80% charge
    I will try to be better with standard units in the future.
    alexcue and Tideland Prius like this.
  13. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    If those numbers are correct then you are getting from 12 kWh energy in the fuel, 5.1 kWh electricity, that would mean 42% efficiency in which I have my doubts.
  14. Prodigyplace
    12,711
    11,848
    Central Virginia
    I thought the Prius engine was rated as 40% efficient. 42% is close to that.
  15. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    There are other losses and 40% would be an absolute maximum, there is no way you could get 42% out of it... or is it? Bob?
  16. bwilson4web
    16,520
    I try to be accurate but given Toyota claims 40% efficiency for their engine, I'm not too worried about 40% vs 42%. As for the difference, I don't have much control over the SOC level of the HV region SOC and at 35 mph (58 km/h), there can be significant differences. But the SOC % level only measures the reported EV range above the HV, SOC levels. I would expect the ambiguous HV levels to be the most likely source of any error.
    I have thought about variations to the protocol including a longer drive done at a higher speed, say 65 mph (104 km/h):
    • Exhaust the battery SOC
    • Do 10-20 minutes warm-up at 65 mph (104 km/h)
    • Run mileage test, ~40 miles (64 km) at 65 mph (104 km/h) - baseline MPG
    • Re-run mileage test, ~40 miles (64 km) at 65 mph (104 km/h) in CHARGE mode - difference
    At a higher speed, the car has less opportunity to turn off the engine and the HV battery level should be less subject to change. It is also long enough to achieve 80% SOC in CHARGE mode.
    ps. We need to discuss the assumptions used to calculate the gasoline energy. In the USA, we have two gasoline mixes: summer and winter. We also have variations in ethanol that are never accurately described at the retail point of sale. It is an imprecise metric and we probably need to evaluate a range, a minimum and maximum.
    pps. After doing my mph vs MPG chart, I added shims to the rear wheels to adjust the excessive, negative camber. Also, my benchmarks were at Toyota tire pressures but I normally run maximum sidewall. These could also contribute to the higher than expected efficiency. I prefer to share 'as built' data rather than my tuned configuration. I honestly forgot about them.
    There are some who go out of their way to claim exceptional performance which I avoid. So my mph vs MPG chart reflects what anyone who has not 'tuned' their Prius Prime should achieve. But by accident or carelessness, this original chart inflated the performance AFTER tuning when I was trying to measure CHARGE characteristics.
    The updated test protocol should solve that problem because the same test item will be used before and after. Not the 'as built', untuned Prime I drove home from Rhode Island.
    WARNING! - I do not claim my tuning has any quantifiable result. Rather it is an uncontrolled variable in this experiment. I am not done with my tuning and am about 600 miles away from my second transaxle oil change. I also have front wheel camber adjustments pending. I tune my cars for my own enjoyment. I'll share what I do but that is all.
    #496 bwilson4web, Aug 9, 2017
  17. bwilson4web
    16,520
    I checked Wiki and in the USA, we different grades:
    • 33.56 kWh/gal - summer grade
    • 32.97 kWh/gal - winter grade
    • 32.78 kWh/gal - E10
    When I ran the same model with the different grades, I got a range of efficiencies, 42.0%-43.0%. What this suggests is the different grades could have accounted for ~1% difference in the apparent efficiency. The new test procedure uses the same tank of gas so we don't have to compare results separated by eight months.
  18. bwilson4web
    16,520
    More higher speed, 90F (32C) tests:
    charge mph MPG distance gasoline
    1 14% 65 46.0 16.1 0.350
    2 0% 65 58.5 14.2 0.243
    • estimated HV gas - (16.1 / 14.2) * 0.243 ~= 0.276
    • 0.350 - 0.276 = 0.074 gal for 14%
    • ~0.00529 gal / %
    • ~0.423 gal for 80%
  19. bwilson4web
    16,520
    A few quick updates:
    Temporary tag pending final:
    Problem with extension cords, primarily the socket:
    I have already tried a weather-proof plug and socket that did not work. So I'm going with a NEMA 5-20 in a exterior junction box.
    HPrimeAdvanced and Prodigyplace like this.
  20. bwilson4web
    16,520
    The Fall weather arrived a couple of days ago with night time lows of 40F. Sure enough the ~30 mile range returned to just over 25 miles, the EPA spec. With the cool weather, the tire pressure alarm came on. As I filled the tires this morning to 47.5 psi, the initial pressure ranged from 30-34 psi. I run about 10 psi over the door jam pressure so when they inevitably leak, I'll get an alarm at door jam pressure.
