Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Interesting...
    What app are you snapshotting from here?
  2. bwilson4web
    16,535
    mr88cet likes this.
  3. bwilson4web
    16,535
    Plug-In Plug-Out Energy (kWh) Charging Time Amps (limit)
    1 9:33 PM 7/17/2018 3:33 AM 7/18/2018 5.91 01:54:34 16
    2 10:46 AM 7/16/2018 6:56 PM 7/16/2018 6.06 04:27:07 6
    3 10:15 AM 7/15/2018 6:50 PM 7/15/2018 5.92 01:49:28 16
    • 5.92 kWh, 6.06 kWh, 5.91 kWh.
      • 97.7%, 100.0%, 97.5%.
    • The 6.06 kWh is equal to the charge rate of the L1 charger at 12 A.
    • Switching power supplies lose efficiency at lower power settings.
      • We have no way to separate AC and fan loads from charging current.
    • In subsequent drives, all three max charges delivered over 25 miles EV.
    I need to run a full charge at 4 A which would be the equivalent of the L1 at 8 A. I might set the current to 2 A and charge over night to see what metric comes up.
    FYI:
  4. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    Please explain "rebooting" here...
  5. bisco
    52,855
    disconnecting the 12v for at least 30 minutes to reset all the computers.
  6. bwilson4web
    16,535
    OLD
    "Skin in the game" we own(ed) and operate(d) these cars:
    199-58 MPG - Prius Prime (11k mi / 11k total) 2018-05
    180-40 MPG - i3-REx (27k mi / 33k mi total)
    (sold) 52 MPG - ZVW30 (73k mi / 73k mi total)
    (sold) 52 MPG - NHW11 (122k mi / 172k mi total)
    NEW
    199-58 MPG - Prius Prime (12k mi / 12k total) 2018-05, 08
    Also, with temperatures in the low 70F (22 C), I was happy to see:
    Home_base finished charging.
    Charging added 6.155 kWh in 1h 54m 59s.​
    #566 bwilson4web, Aug 4, 2018
    Prodigyplace likes this.
  7. bwilson4web
    16,535
    During hot weather charging, the capacity drops below 6 kWh. But charging in the coolest part of the night seems to bring capacity above 6 kWh. So I set the EVSE to charge only between 3-9 AM. This should ensure full charging during the coolest part of the day. However this requires testing.
    For the next week or so, I will run the car in EV with HV picking up operation once the battery is depleted. I will have to put some gas in but this is from a tank filled eight months ago. I'll wait for the gas-low light, ~1 gal., and only add 2-3 gallons to sustain HV operation.
    The one challenge is pre-conditioning the car in the middle of the day. I may have to override the timer to get the cabin cooled.
    #567 bwilson4web, Aug 4, 2018
  8. markabele
    5,084
    1,782
    Nebraska
    Got me excited when I saw this at first glance. Thought you might have found your used Model 3. :)
  9. Prodigyplace
    12,713
    11,848
    Central Virginia
    You & me both. ;)
    The only thing that gives me hope is that he appeared miserable the last time he was without a Prius. (after he sold his Gen 2 & before he got the Prime)
  10. bwilson4web
    16,535
    My study of hot weather charging requires draining the battery and using HV mode to get home. A day or so ago, the low fuel light came on so this morning, I topped off with 10.5 gallons. Then this evening:
    Talk about poor ad placement and timing.
    Since2002 likes this.
  11. DavidA
    2,349
    1,825
    Chicago western burbs
    I was only thinking about replacing our old and cracked Brita water pitcher this week, and low and behold, ads by Google started popping up in my browser for Brita! Yes, really. How far will they go? They're reading my mind now!
    So now that I've typed the above, and The Google bots have read that, I'll bet The Google will order one for me automatically and will bill my credit card for it. And hopefully, that will stop the ads, or, maybe, begin the ads in my browser for the filter refill 10-packs.
    markabele and bwilson4web like this.
  12. Prodigyplace
    12,713
    11,848
    Central Virginia
    You have Google Home and talked about it?
    They are spying devices.
    mjoo and bwilson4web like this.
  13. bwilson4web
    16,535
    I suspected something was wrong when my cell phone announced, "Mandatory Entune update." The Prius Prime, Plus trim, has to link via my cell phone but like a sheeple, I took the bait. Now the only way I can play iPhone audio is via bluetooth, not the USB-lightning cable.
    When I tried to connect, a message came up that it failed and I needed to read the Owner's Manual. My breakfast had not arrived so I went to the car to fetch it and lookup the problem. The Owner's Manual said see the Navigation Manual. Another trip to the car but breakfast soon arrived and I looked it up.
    The instruction said to push the "AUDIO" button which gave me options. Attempts to select USB failed but Bluetooth worked. So now it is permanent Bluetooth to play iPhone audio. Nothing like replacing hardwired with another wireless link. <GERRRRRR!>
    #573 bwilson4web, Aug 11, 2018
  14. DavidA
    2,349
    1,825
    We don't have any electronic home assistants. Don't have a smart TV. Heck, we don't even have smartphones. I have suspected my wife's Ipad is listening to everything we say. I don't think it is ever really "off."
  15. bwilson4web
    16,535
    Measuring battery capacity has turned out to be complex as there are two parts:
    • EV level - tricky to measure
    • HV level - even trickier to measure
    BACKGROUND
    I started with driving home and recording how much charge was put in the car when charged in the 70-75 F (21-24 C), very early in the morning. I adjusted the time of charge so it ended at sunrise:
    • decreasing capacity at 16 A - this really bothered me because it suggested I was losing capacity. More about this later.
    • funny 7 A capacity - insights, I figured out the problem,
    The last two metrics are here:
    During the 16 A series, I had been learning how to arrive at home with 0% SOC. In the beginning, I was driving further in hybrid mode (HV) which digs into the lower part of the traction battery. The earlier charge session included what it took to fill the empty HV part. As an experiment, I left the car parked with the A/C on for ~1 hr which dives deep into the HV part.
    The best approach is to drive home with the car in low, unit, % SOC (1-3%.) Continue to drive around the neighborhood, laps around the block, until the SOC reaches 0%. Then measure the charge. This is the only reproducible way to measure the EV traction battery capacity outside of pulling it from the car and using lab instruments.
    Now I can measure the 16 A and 7 A battery capacity, again holding fairly constant the charging temperature of very early morning hours. I'll probably add an 11 A sample since three points should give enough to calculate the effective charge as a function of charge current.
  16. bwilson4web
    16,535
    Ok, we have a methodology and it appears to give reproducible results:
    1. Drive in EV toward the charger and do loops until the SOC reads "__" and the car kicks into HV mode. Minimize HV driving so the HV battery range does not have to be charged.
    2. If sunny and over 85F (30C), configure to charge between 2 AM and sunrise. This avoids A/C trying to keep the battery cool enough to accept the charge. You can drive in HV mode if you need to go out earlier.
    3. Cutting the charging current in half had little effect on measured, EV battery capacity, 5.89-5.91 kWh.
    JeffFromNE likes this.
  17. bwilson4web
    16,535
    Charging added 5.636 kWh in 1h 44m 42s.​
  18. bwilson4web
    16,535
    Charging added 5.812 kWh in 1h 49m 17s.​
    Second metric with temperatures in the 70F range.
  19. bwilson4web
    16,535
    Charging added 5.667 kWh in 1h 45m 40s.​
    I'm seeing a consistent +27 miles on the trip meter for the past three, full charging sessions.
    1. Charging added 5.636 kWh in 1h 44m 42s.
    2. Charging added 5.812 kWh in 1h 49m 17s.
    3. Charging added 5.667 kWh in 1h 45m 40s.
    Bought in December 2016 and approaching 2 years, the range is still within the EPA 25 miles. But I switched to the BMW i3-REx when the temperatures exceeded 80-85F (27-30C).
    #579 bwilson4web, Oct 14, 2018
    mr88cet likes this.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    OK, those numbers are interesting, and are very comparable with what I’m seeing after it dropped off and then recovered a bit: Charging about 5.7KWh, estimating 27-28 miles, and actually getting around 25ish. Also for comparison, I purchased mine in May of 2017. Thanks, Bob!
    bwilson4web likes this.
