Prius Prime Plus in my hands
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jan 19, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Ich. Naps make me feel like I've been run over by a train.
    The math doesn't work for me, since the nearest restaurant to my office is 7 miles away. That's a 2+ hour walk each way, with 700 feet of altitude difference between the ends.
    52,927
    i'm using an L2 at home, perhaps that is the difference. you're putting a 40% charge in 40% of the full charge time, i'm putting approximately 75% charge in 50% of the full charge time.
    also, i see a slowdown when my a/c is running in the house.
    #142 bisco, Feb 3, 2017
  3. bwilson4web
    16,554
    Not to walk to work but go there for lunch or a nap in the car. But 7 miles is outside the practical range. My options are:
    • 0.25 mi - 16A UAH campus with on campus Dunkin Donuts, Chick Filet, and dorm cafeteria.
    • 0.5 mi - Toyota dealer near Pizza Hut, Denny's, Chick Filet (untested)
    • 1.0 mi - mega shopping center, full L2.
    These are close and my commute is ~10 miles. So an hour lunch and slow drive back to work and I have the effect of a work charger.
  4. bwilson4web
    16,554
    Another set of charging metrics:
    Rather than speculation on Prime charging performance, I prefer metrics.
    Prodigyplace likes this.
  5. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Yes, and if the EVSE in the shopping center (the charging point) allows lower than 16A current, the charging will be performed at this allowable current and will take longer than usual even if it is on a 240V line
  6. bwilson4web
    16,554
    It is important to test everything and fortunately my BMW i3-REx has been helpful. It turns out we only have one set of L2 EVSEs that are limited to 16A. All the rest support at least 31-32A per the rate of charge of the BMW i3-REx.
  7. bisco
    52,927
    i agree with testing, i'm just not set up for it. mentally.
    EV-ish likes this.
  8. bwilson4web
    16,554
    Preliminary testing suggests we are seeing 29.2 mi EV range in the morning vs 25 mi range after fully inflating tires. But I have also done 224 mi EV and there are learning factors too. I'll have to do an A-B-A test and road benchmarks to be sure.
    dalcon95 and thatoneraccoon like this.
  9. bwilson4web
    16,554
    Just finished seven days: 301 miles, all EV.
    Also, there was some evidence that descending a hill can exceed the pack ability to absorb power. The higher engine revs and slight increase in engine noise suggests "B" mode but there is no external indication of this mode.
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    The option on the Plus departure charge, and preclimate can be selected.
    priuscatprimeguy likes this.
  11. Andyprius1
    2,327
    859
    Cool CA
    I could use a assist on clock set, my time is good, I just want it to be about 2 minutes slow so my time of use charge is safely after midnight. thanks
  12. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    On the charge schedule you can set hours and minutes ( I think, but I haven't really tried to set the minutes portion)
  13. Andyprius1
    2,327
    859
    Cool CA
    That's true, I could change the charge start to 1202. But, I need to know how to change clock anyway. It's all the way over on right at Sun option, then I get lost.
  14. MNdriver
    MNdriver Senior Member
    549
    577
    Andy, none of the safety features prevented you from backing over Darth Vader?
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    That is the FRONT of his car, I believe.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    That looks like a flat Darth Vader in front of the car. He must have backed over him. :ROFLMAO:
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    Ah. I thought Vader was standing in front, like some of the commercials.
  18. bwilson4web
    16,554
    Judge Doom:
  19. bwilson4web
    16,554
    Ok, I am still investigating Prime performance but I am running out of questions. This means I am approaching a time when 'like' decides which car I take in the morning.
    I'm at 55:45 trending to the Prime. The Prime has 17 years of Prius history so everything is well integrated. The BMW feels like a cleverly done but hobbled hybrid. Granted I have 12 years of Prius Gen-1 and Gen-3 experience so I am not unbiased or inexperienced.
    thatoneraccoon and dalcon95 like this.
  20. bisco
    52,927
    bob, have you somewhere else posted about the comparison's of driving each car?
