Prius Prime Plus - Trunk additional LED lighting
Discussion in 'Prime Accessories and Modifications' started by citiprius, Feb 25, 2018.
  1. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    The factory trunk light is too dark and not functional at all. It is a 12V 5W bulb. So I spent an hour to add a LED light on each side. It's both functional and beautiful :)
    Pictures: (will be uploaded later)
    1. Remove the trunk mat
    2. Remove the 4 pins from at the edge of the trunk cover (which will then expose the battery pack by usng a flat screw driver.
    3. Remove the 2 hocks on each side of the trunk (which use for holding the trunk privacy cover) by using a flat screw driver. It will then expose the screw underneath
    4. Remvoe the 2 screws using phillips screw driver on each side of the trunk.
    5. Remove the large flat cap plastic pin at the bottom of the each side wall near the rear seat. I use a piler to tuck underneath the cap and pivot / pull it out.
    6. Pull out the trunk light by using a flat screw driver.
    7. Pull out the side cover, it allows to run the wire from the trunk light to the bottom back of the rear seats.
    8. Open the tinny plastic black hidden panel door on each side of the trunk wall.
    9. Run the wire behind the side wall, then the edge of the battery pack, then to the other end, then throught the left side wall, then run the wire out to the left side panel square opening.
    10. Drill a hole and install the LED housing & light on each side.
    11. Connect the wires to the LED light and tab them to the factory trunk light wires.
    12. Test it by closing and opening the trunk door.
    13. Put everything back and done.
    Kayley, Bonobo.P., ice9 and 5 others like this.
  2. mhye01
    mhye01 Member
    57
    50
    Woodland Hills
    sooo....them pictures? lol, Im actually interested in this
    Shaunius and TGrracie like this.
  3. citiprius
    241
    238
    51
    2018 Prius Prime
  4. citiprius
    241
    238
    51
    2018 Prius Prime
    Just posted a link. enjoy
    Kayley, TGrracie and mhye01 like this.
  5. Gianni I
    Gianni I Member
    72
    40
    Long Island
    Wow...looks great.
  6. Prodigyplace
    12,710
    11,848
    Central Virginia
  7. Insighter
    Insighter Active Member
    409
    287
    SoCal
    I like what you've done with this. I've been looking at different alternatives for the lights themselves, but I think I like your choice best because they are so small and only require a small hole. I do have some questions, if you don't mind answering them:
    1. Where did you actually put the lights? I looked at your link, but I couldn't find a picture of the installed lights themselves.
    2. The way you have wired yours, do they come on whenever the hatch is open, or are they also controlled by the same switch that turns the OEM cargo light on and off?
    3. Is there anything you'd do differently if you were going to do the project over?
    Thanks!
  8. citiprius
    241
    238
    51
    2018 Prius Prime
    Thanks for your questions Insighter,
    1. My son took my car, but I'll take some more pictures and update the pictures later tonight.
    2. I tab into the OEM trunk light wire, so when the trunk is open, it turns on, when it close, it turns off. But it CANNOT be controlled by the switch of the trunk light as that switch is part of the assembly. Unless I solder my wires to the assembly, then the same switch can control all 3 lights.
    3. I might try different color LED light. Initially, I was looking for some tiny LED light which looks like a mini version of the deck/patio lighting and has a semi-sphere / round housing that projects the light to the floor, so that I can mount it on the side wall rather than on the ceiling of the 2 "caves". But I search for a long time and couldn't find one. End up I mount it at the current location but it looks great.
    #9 citiprius, Mar 8, 2018
  9. citiprius
    241
    238
    51
    2018 Prius Prime
    I've updated the doc with more pictures, please check it out.
    #10 citiprius, Mar 8, 2018
    Kayley, Mark57 and Insighter like this.
  10. Insighter
    409
    287
    SoCal
  11. citiprius
    241
    238
    51
    2018 Prius Prime
    Kayley and Insighter like this.
  12. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    I can play too? Decided to go the ez 5 minutes job rather than routing wires up on the hatch. Works for now :)
    JimboPalmer and citiprius like this.
  13. randomwalk101
    532
    271
    texas
    Comparison shot (without the extra light)
  14. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Great Mod. Thank you for sharing with us! (y)
  15. citiprius
    241
    238
    51
    2018 Prius Prime
    That looks easy and bright. But it might be blocked and to avoid that, you will need to stuff the left side of the trunk first. ;)
  16. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    I just came across this and the mod is very cool.. I still don't understand why a light isn't on the hatch so it would be shining down once the hatch is opened.
    GTprii likes this.
  17. robertjackson17
    robertjackson17 Junior Member
    17
    17
    Toronto, ON Canada
    2018 Prius Prime
    Technology
    Putting lights on the hatch facing down makes a huge difference. I added 4 LEDs to the hatch in addition to 2 side LEDs as described in this post. The pics show the hatch lights on and off (the 2 side LEDs are off).
    LEDs are
    Switches are
    (any similar switch should do). I used one switch for the 4 hatch LEDs and a second switch for the 2 side LEDs.
    Wire
    Wire Connector
    joins the wiring between the car body and the hatch. Allows the hatch trim to be removed and detached easily
    Wire Taps
    to connect the LEDs to the main wiring backbone and to tap into the power going to the factory-installed trunk light.
    I also needed some spacing washers from Home Depot to help hold the LEDs in place when they're in the hatch plastic.
    Possibly the hardest part of installing lights in the hatch is threading the wire through the flexible accordion hose between the car body and the hatch.
    3185699d-8eda-4604-9e90-a2c883a5c913.JPG bec7dec9-f958-41d3-98bf-2ec76c56e756.JPG
    [edit to add parts list]
    #18 robertjackson17, Nov 6, 2019
  18. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    Well done.
    I am curious though why you added switches. You don't want these to always come on when the trunk is opened?
  19. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
