Prius prime reliability
Discussion in 'Prime Main Forum (2017-2022)' started by bcretman, Mar 4, 2022.
  1. bcretman
    bcretman Junior Member
    Vancouver
    Looking at used Primes is there anything I should look out for? Are there any reliability issues for a particular year?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    No serious reliability issues have been reported, AFAIK. Here are some of the issues, mostly cosmetic or annoyance than mechanical/functional issues, that I and others have noticed. Those issues are with the new cars. If you are buying a used PP, then they will still apply but not necessarily big concerns, I would think.
    • Early 2017 and 2018 had an issue with a metal backing plate behind the hatch opening switch rusting early, especially in the "salt belt" states.
    • Ruttles in the dash or from the door panels have been reported.
    • Qi charger if equipped does not work on some phone models or even if it works, it is very weak.
    • The front windshield is prone to chip/crack easily.
    • The front acrylic facia, aka the glass jaw, can easily crack.
    • Infotainment system (especially with 11.6" screen) bugs, such as frequent re-booting.
    • Connected service malfunction or missing function or sometimes nonfunctioning
    • Low level of parasitic draw causing the early 12v battery demiss.
    • A few reported early brake corrosion issues but I think only very small numbers in the "salt belt"
    • Any accidental damage not covered by warranty will cost you $$$ (parts are very expensive).
    There may be some more complaints others have experienced, but overall, it is a super reliable car requiring minimal maintenance.
    #2 Salamander_King, Mar 4, 2022
    jerrymildred, Marine Ray and bisco like this.
  3. Mendel Leisk
    42,355
    Checked Open Road Toyota Port Moody yesterday, just for laughs: NO new cars. Been thus for months now.
  4. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Recent Consumer Reports. I believe 2018 is exception and not accurate. 2022 CR Used ranking.jpg
    Salamander_King likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    60,500 miles so far on my 2017 Prime. Reliable as gravity so far. Runs like a new car. Only regular maintenance.
    (Still on the original 12V, BTW, which is doing fine.)
  6. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Steering wheel cover and rear plastic panels near hatch have peeling issues (after 2-3 years). That's two minor ones I know off.
  7. Trollbait
    12,831
    The 2018 body hardware gets dinged by the rusting backing plate to the hatch latch.
  8. jerrymildred
    11,517
    14,170
    Tampa, FL
    2017 has the same issue.
  9. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    2020 Prius Prime I’ve used for grocery delivery, since retired but just flawless operation. No need for warranty coverage after 18 months. I use Apple CarPlay, and works fine for me. Just a well handling, smooth riding vehicle. Now that I drive less, it’s virtually all in EV mode, no need for the gas station most months.
  10. bcretman
    Vancouver
    Do you have a CR chart for the 2018 Volt?
  11. Trollbait
    12,831
    And that was the second worse year for body hardware on the CR chart. As a first year model, most of the 2017s probably went to California, or the respondants to the CR survey were in regions where rust is less of an issue.
    jerrymildred likes this.
  12. jerrymildred
    11,517
    14,170
    Tampa, FL
    My was originally from New Hampshire. I got it in march 2019 with about 22k on it and some light rust under the hood and, of course, on the hatch bracket. Rust has not worsened visibly.
  13. I'll just chime in since I still have my 2017: my responses in bold
    • Early 2017 and 2018 had an issue with a metal backing plate behind the hatch opening switch rusting early, especially in the "salt belt" states. (haven't thoroughly checked but definitely plausible)
    • Ruttles in the dash or from the door panels have been reported. (just started happening to me a month ago but it's minor)
    • Qi charger if equipped does not work on some phone models or even if it works, it is very weak. (yup, I don't use it anymore)
    • The front windshield is prone to chip/crack easily. (happened to me late last year, I didn't see what hit it and it went from a chip to a growing crack, insurance picked up everything beyond $50)
    • The front acrylic facia, aka the glass jaw, can easily crack. (yup)
    • Infotainment system (especially with 11.6" screen) bugs, such as frequent re-booting. (I have not seen this, but the green-yellow-red traffic forecasts rarely ever work)
    • Connected service malfunction or missing function or sometimes nonfunctioning (haven't needed SOS yet but I have had a few connection issues with RemoteConnect)
    • Low level of parasitic draw causing the early 12v battery demiss. (that happens with most cars these days)
    • A few reported early brake corrosion issues but I think only very small numbers in the "salt belt" (no comment, other than I have a 3rd party service do undercarriage coating plus touchup every year)
    • Any accidental damage not covered by warranty will cost you $$$ (parts are very expensive). (again seems to be common with many newer cars)
    • There may be some more complaints others have experienced, but overall, it is a super reliable car requiring minimal maintenance. (agreed)
    jerrymildred and Salamander_King like this.
  14. Marine Ray
    1,139
    949
    Sparks, NV
  15. jerrymildred
    11,517
    14,170
    Tampa, FL
