Prius Prime Solar Roof
Discussion in 'Prime Main Forum (2017-2022)' started by Edward.Howard, Nov 17, 2016.
  1. Edward.Howard
    Edward.Howard Junior Member
    Charleston, SC
    When you Google why the US is not allowing the solar roof on the new Prius Prime, you will find over 15 articles that all say the same thing. It can not pass current safety standards for the US.
    "Initially the new technology will be offered only in the Europe and Japan versions, where it is named the Prius PHV.
    The United States roadblock has to do with meeting stringent Federal Motor Vehicle Safety Standards and Regulations. Toyota hasn’t been unable at this point to laminate the photovoltaic cells in a resin that won’t shatter during a rollover crash."
  2. Trollbait
    12,822
    And when asked at the Japan Prime event, Toyota says it was because they didn't think the market would pay the cost. It is a $3000 option in Japan, and we don't know about elsewhere yet. Add to that, that the ability to charge at home is more likely here.
    I've heard the safety standard reason. This could be false, and those 15 articles are all repeating the same bad info, which wouldn't be hard in the internet age. Or it could be true, and the fix would increase the price further.
  3. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    I'm leaning towards feasibility. You would need a high percentage of people to purchase this option and when you consider its usability, cost to repair, likelihood to fail or get damaged and how efficient it is, then I think it fails. If it charged your 25 mile electric range in an hour under the sun, then that's very different. Or if it was so efficient that it powered enough to sustain drive, then that would be a thing. Just my 2¢.
  4. Sunhawk95420
    Sunhawk95420 New Member
    Caspar, California
    We have the solar roof on our 2010 Prius ... and it's a nice amenity but probably not worth the added cost. I'm a PV guy, so it's a sort of Earth Flag for us ... and it's cool (literally) when it runs a fan to reduce cabin air temp when the car is parked in the sun. It takes a lot of PV to charge high voltage batteries meaningfully ... more than a car-roof full. I have 11kw on my roof, and they cover over 100 square feet. They'll *help* recharge my Prime when I get it (soon I hope.)
  5. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    I wanted to have that feature. Hot interiors be damned. I can be found opening all 4 doors, then going around to open all 4 windows and then once around again to close all the doors on hot day. If it's very hot, I'll start the car and turn on the AC, recirculate and max, before going around to close the door. Your car has a feature, which I thought was absolutely ingenious. I'm not sure I would pay 3k for it, as I am further north, but you're lucky. Great feature!
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Curiously, I just read (Tideland as I recall) that the GIII solar roof was supposed to charge the battery, but the regulator was too noisy (electrically), so they changed to just running the fan.
    To charge the battery the unit would have to take the output from the panel and boost it to 250+ volts as well as ensure regulation. I guess it wasn't ready soon enough for production, so they shelved that use and installed the smaller and simpler unit to run the fan.
    It may be it is still too noisy (FCC regs) and they are hiding that by saying the other reason(s). Certain other countries are not as stringent when it comes to radio noise. And Canada is VERY stringent! Being a HAM I support that! ;)
  7. Rmay635703
    Rmay635703 Senior Member
    2,699
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    If its "not passing crash standards " its more likely due to idiotic platform laws that should be repealed
    Aka if a car comes in multiple configurations, each configuration needs to be crashed and tested individually.
    This is why many us cars come without a manual xmsn option
    Or any engine choices. Even though neither has any significance affect on crash performance
    Pure stupidity
  8. Trollbait
    12,822
    Residential electric to many Japanese homes is less powerful than in the US. Level 1 charging the Prime will take 10hrs, and level 2 isn't possible. A solar charger on the car there might be worth the cost in light of that, and the fact that they drive shorter distances in general.
    The Prime solar option on the Prime includes a NiMH battery under the rear seat to buffer the system.
    CTorPrius? likes this.
  9. Tideland Prius
    16,678
    That's what I was told as well at the Prime event.
    Most new cars have windows that absorb or reflect heat. The Gen 4's side windows are noticeably darker in tint.
    In addition, there is the "remote windows down" function on the key fob (dealer-activated).
    Lastly, the Prius Prime will have a Remote A/C function that runs up to 10 minutes (The Gen 3's Remote A/C runs for 3 minutes but of course it had the solar panel to vent the interior while it was parked)
    That's correct. That's what I remember from the Gen 3 launch event. So we know Toyota has been working on it for at least 10 years (development of the Gen 3 started around 2006 IIRC).
    The Prius Prime has a small NiMH storage battery so I assume it just charges that and then the battery will then charge the HV battery and somehow step-up the voltage.
  10. Rmay635703
    2,699
    1,729
    2013 Chevy Volt
    Toyo has not tested the car with a solar roof, an exterior component shattering will not fail the test.
    It's a simple case of economics, even though the solar roof has ZERO effect on the test, Toyo would have to spend millions to test the option separately because "the car is different "
    This type of stupidity is why mericans get so little choice compared to the rest of the world.
  11. David Beale
    5,963
    1,990
    Edmonton Alberta
    Without getting into an all out political argument, I beg to differ. Putting a solar panel on the roof -does- change the way the car reacts to an impact. The windshield transfers force to the roof. If it's made of something other than the "standard" metal, or metal in some different configuration, then it WILL change the way the car reacts to impact. It's also heavier with the solar panel, and that also changes the way the car reacts. Even if the panel was somehow just "glued" on top of the existing metal, (it isn't), it would change the result, just due to the weight.
  12. Rmay635703
    2,699
    1,729
    2013 Chevy Volt
    There is metal under neith the panel the same as your normal car, if anything it would be harder to crush and definitely not worth re testing.
    It is pure ignorance that we waste money and remove choice from the market because it's slightly different.
  13. David Beale
    5,963
    1,990
    Edmonton Alberta
    And you know this because you tested?
  14. lwtrower
    lwtrower New Member
    Sonoma County
    This is a feature I have been interested in for a while and seen very few cars with it. Do you have any details about this, how it work, and how the dealers would activate it?
    Thanks!
  15. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Solar option will be avalable in Germany but it comes at a high price and I don't exactly mean financially.
    You miss out on HUD,Parking Sensors,RCTA,ICS ,IPA and BSM !
  16. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    It's in the user manual towards the end. I pulled the printed the pages off and marked the modifications I needed. I will be giving them to the dealer to modify and insist that they be complete PRIOR to possession.
  17. Tideland Prius
    16,678
    The feature includes:
    • key-in open/close of the windows and moonroof* (*if equipped). Insert key into the driver's door and turn and hold the key clockwise/anti-clockwise to close/open the windows.
    • remote-activated open only of windows and moonroof* (*if equipped). Press and hold unlock on the fob for a few seconds.
    It's off by default. You have to tell the dealer you want it turned on. (remote and/or key-in function. They're two separate options).
    Ahh, so I wonder if there's a weight issue again (like the Gen 3.. choose between solar roof and DRCC/PCS/LKA/17" alloys) or whether it's really to keep the price affordable.
  18. TexAmi
    TexAmi Junior Member
    16
    16
    I have a 2013 prius with the solar panel. The solar panel is the only thing that makes the car look and feel technologically advanced.
    I will not buy another prius until the solar panel returns.
    I have a white prius with the black glass/solar panel roof with looks just like the BMW M4, several upscale Mercedes models. White with the black glass is a sharp look!!
    Please Bring it Back!!!!
    dstrauss likes this.
  19. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    The problem is most people tend to crash cause they going over the speed limit . They probably blame the Solar roof for the crash. I like the Solar panel it a great ideal.
  20. EV Life
    EV Life Junior Member
    Columbia, MO
    Any idea on how to just buy flexible solar panels and install them on our own? I know it's a lot more difficult than that but I would be interested in giving it a shot.
