Prius Prime sounds like in B gear at all times
Discussion in 'Prime Main Forum (2017-2022)' started by Markelli, May 9, 2023.
  1. Markelli
    Markelli Junior Member
    50
    South Florida
    So I just eliminated the possibility of tires. I put 4 new ones, did an alignment balance etc. whenever the car is in ev mode or regular ice mode it sounds like it’s in B mode. There isn’t any resistance or pullback while driving, it just sounds like the traction battery is charging downhill if you’re familiar. Dealship wants to charge me for a road test $100. I’m going to connect the OBD reader and run a full diagnostic, but anyone else have this issue or a similar one?
  2. ChapmanF
    16,028
    There are a couple different sounds that people associate with B mode.
    The charging of the traction battery is nearly soundless. (It also happens most times you use the brake, even not in B mode.) You can sometimes notice a faint gear whine from the transmission, just a smidge louder than in normal driving, because of the torque that regeneration is putting on the gears.
    The other sound people associate with B mode is the sound of the gasoline engine revving high. That sound is very much like the way any other car sounds if you downshift going down a hill. It is a much more noticeable sound than the faint gear whine when charging the battery. The engine sound comes when B mode is not charging the battery, but has decided to direct the recovered energy into twirling the engine instead, giving the battery a rest.
    Which of those sounds more like what you're hearing?
  3. PriusCamper
    PriusCamper Senior Member
    11,222
    4,578
    Pacific Northwest, USA
  4. Markelli
    50
    South Florida
    Thanks Chapman, even in full ev mode, it sounds l like it’s in the B mode gear inside the car. Not to be confused with the normal faint whistle pedestrians hear outside. I’m going to run a full diagnostic with my OBD reader. Normally in full EV mode it’s as quiet as a mouse in the car. Now it’s a whirr noise that sounds like it’s in b mode even in drive. I hope that helps. I’ll try and get a video of it later this morning. I’ve had this car for 3 years and know it’s not normal at all.
  5. Markelli
    50
    South Florida
    Tell me you hear this sound. It’s full ev but sounds awful.
    https://photos.app.goo.gl/zmMagqNTDRz695Wk7
    Watch/listen to that video
    it sounds awful in ev mode and it sounded like this before the new tires I put in. Interestingly, there was a a power steering fault I got last week but now show how that would effect the noise both in ev mode and hybrid
  6. Markelli
    50
    South Florida
    OBD diagnostic
  7. Markelli
    50
    South Florida
    Failed to check
  8. Markelli
    50
    South Florida
    To me it sounds anything but quiet in EV mode maybe I’m nuts ?
  9. Leadfoot J. McCoalroller
    7,298
    6,817
    Pennsylvania
    2018 Prius c
    Wheel bearing.
    Trollbait likes this.
  10. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    I agree that it sounds exactly like tire noise. But, you replace all 4 tires.
    So, then my guess is a wheel bearing that is going bad.
  11. Markelli
    50
    South Florida
    A wheel bearing? Is that covered under most extended warranties? What consequences of a wheel bearing could be? Safety? How would they fix that?
  12. Leadfoot J. McCoalroller
    7,298
    6,817
    Pennsylvania
    2018 Prius c
    No clue if there's warranty coverage, talk to whomever sold you the warranty.
    An extreme failure involves the wheel separating from the vehicle, but usually you get 100,000 miles of howling and groaning noise first. Lots of safety engineered into these. You'd be reading about it in the news otherwise.
    They are modular parts meant for relatively easy replacement.
    On the other hand they are notoriously difficult to diagnose. Sometimes you can put it up on the lift, roll each of the wheels by hand and it is plain as day. Other times you have to use special tools like Chassis Ears™ and even then it takes an hour of road testing to work out which one of the four has failed.
  13. Markelli
    50
    South Florida
    Eeep thanks! But you saw/heard the video? It sounds like a city bus in EV mode
  14. Leadfoot J. McCoalroller
    7,298
    6,817
    Pennsylvania
    2018 Prius c
    Those descriptions are new to me, but classic descriptions go like: worst tire noise ever, a WWII bomber taking off, just a loud horrible hum or whir... endless creativity in the linguistic end of it.
    The big hint here is that it doesn't matter whether your car is running on volts or gas, you're getting the same noise. That pretty much narrows it down to either wheel bearings or tires.
    There's a chance you got terrible tires, but there's a better chance you've got a bearing starting to go bad. Time to take it into the shop and let them work it.
    The good news is that tires and wheel bearings are exactly as they would be on an ordinary gas car. You don't need Toyota or anyone with hybrid experience to fix this. So if there's no warranty, just take it to the neighborhood mechanic and pocket the savings.
  15. Trollbait
    11,682
    Been some time, but that sounded like my HHR with a bad bearing. in addition to the noise, there could be reduced efficiency from more friction in the bearing.
    The classic test for a bearing is to jack up the wheel, and see if you can wiggle it in relation to other suspension parts. It didn't with my car though. Couldn't figure out any other causes. Replaced the bearings, and the sound went away. The job is pretty straight forward. If you are comfortable replacing brake rotors, you should be fine DIYing this.
    Like tires, its recommended to replace the bearings in pairs.
  16. ChapmanF
    16,028
    My experience with the ChassisEar involved not nearly so much road testing.
    Mind, I had already exhausted every other "just do this! it'll tell you which bearing for sure!" suggestion, then shopped online for a used ChassisEar getup and waited for delivery, and probably spent 20 minutes slithering under the car clipping the pickups to the different locations and making sure the wires wouldn't snag on anything.
    But after that prep work, finding the culprit took no longer than driving down the road and having my copilot press the four buttons on the receiver one after the other. May have taken all of ten seconds.
    Through the ChassisEar, the channel on the bad bearing sounded like a train derailment.
    I didn't replace bearings in pairs. I had two bearings go out on my Gen 1 in all the time I owned it, and those were three years and 50,000 miles apart, and I drove it three more years after that before insurance totaled it after a collision. So my experience doesn't suggest that one bearing wearing out means others are right around the corner. And the amount of work to change two is pretty much just twice the amount to change one, so it's not the kind of job where you say "may as well just do that other one while I'm here". It'll be about the same amount of work if you just do the next one when it needs it, and you might never see that day.
    #16 ChapmanF, May 10, 2023
    PriusCamper likes this.
  17. Leadfoot J. McCoalroller
    7,298
    6,817
    Pennsylvania
    2018 Prius c
    I haven't replaced bearings in pairs since the days of annual grease repacking, when you'd have them all apart anyway.
    "an hour of road testing" is what's likely to show up on a bill for a non-DIY, and I'd expect that to cover all the mic fitment & cleanup after.
  18. bisco
    49,811
    wheel bearing in fl kind of surprising, how many miles on her?
  19. Markelli
    50
    South Florida
    So update, both rear wheel bearings are bad and being replaced now. Talk about the wheels falling out from under you. Luckily it’s in my extended warranty
  20. Markelli
    50
    South Florida
    New question folks, how the heck did this happen? I live in Florida. The only thing I can think of is I have some redneck friends out in the sticks that don’t have paved roads but gravel roads? High speeds? What can I do to prevent this in the future?
