Prius Prime YTD sales vs Tesla
Discussion in 'Prime Main Forum (2017-2022)' started by Old Bear, Oct 21, 2018.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    But it does spin the reason for doing so.
  2. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    Veiled implications of a company lying on SEC documents is borderline crazy talk.
    Care to be more specific?
    Trollbait and bisco like this.
  3. john1701a
    12,840
    5,312
    58
    You are feeding a greenwash narrative by cherry-picking like that.
    Prime was clearly designed to for profitability. Compliance vehicles don't bother. Toyota's effort to deliver affordability is overwhelming evident that they are targeting mainstream sales.
    Choosing to only acknowlege the short-term perspective is intentionally misleading.
    #43 john1701a, Oct 26, 2018
  4. Zythryn
    6,412
    4,415
    Mainstream sales? I once asked you to define mainstream sales and you stated sales of 60,000/year.
    In the US market, Prime has not yet reached that level, the Model 3 has.
  5. john1701a
    12,840
    5,312
    58
    Why are you feeding a short-term narrative too?
    They set a target, then work toward it. When country-wide rollout is achieved, the count should rise.
  6. Zythryn
    6,412
    4,415
    This was your definition John, not mine.
    Care to expand on what you mean by "short term narrative", you may not realize it, but you use a lot of phrases and terms that don't relay your thoughts. It is often difficult to understand what you are actually saying.
    bisco and Trollbait like this.
  7. john1701a
    12,840
    5,312
    58
    2 years is widely accepted as short-term.
  8. bisco
    52,901
    cliche' speak
    if by 'designed for profitability', you mean shoehorning in an oversize battery at the last minute, i agree.
    #48 bisco, Oct 26, 2018
  9. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    That's exactly what I was referring to. I'm not spending thousands more on old tech where you are forced off the battery-only power when temps drop below 20 degrees. That's absurd IMHO. My commute is 4 miles each way, and I don't drive much outside of that. So for low-milage users in a cold weather state do we fill the gas tank up and let the car burn old gas? Or do we fill it 1/4 full and wonder if a mostly empty tank is ok in the cold weather?
    Their motors are not at all ready for all-electric. Just producing batteries doesn't automatically give you an electric car. As far as their "software", yeah....no. Anyone that spends 5 minutes with entune will come away with zero confidence in "toyota software".
  10. john1701a
    12,840
    5,312
    58
    Prime starts at $27,300 and the engine doesn't start until outside temperature is below 15 F degrees. Exaggerating is not constructive. So what if it is less than 10% of the year in the Twin Cities. Having more than 90% all-electric for your 4-mile commute is a great fit. As for "old tech", what does that even mean? Many EV offerings still use old resistance heaters. Prime is more advanced using a vapor-injected heat-pump for greater efficiency.
    Prime uses the least powerful motor configuration offered by Toyota. It works fine in EV up to 84 mph. Want more power, look at what has been delivered in Camry hybrid and the upcoming next-gen RAV4 hybrid.
    Again, I suggest you watch those videos. With such detailed readouts, tell us technically what supposedly falls short. With the power they deliver, the control software, and the liquid cooling, what merit is there for making that claim?
    #50 john1701a, Oct 28, 2018
  11. bisco
    52,901
    the engine starts below 40 degrees in many cases, simply reading priuschat will tell you that. please don't try to intimate that your experience is the same as everyone else's.
    even the o/m will tell you that
  12. john1701a
    12,840
    5,312
    58
    Anyone willing to turn a blind eye to reliability reputation and divert attention to an interface (which is changing) is clearly not critical thinking.
  13. john1701a
    12,840
    5,312
    58
    What are these supposed "many cases" you claim?
    Not being an owner yourself, there's no reason to accept such a statement without proof. That's why I have video after video showing a wide variety of driving conditions to debunk the spread of generalizations.
  14. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Maybe. But if someone is going to drive a vehicle for 10 years, unless Apple Car Play and Android Auto are rolled out to replace or augment future versions of the monumentally horrible Entune software, sales will suffer. Compatibility with those apps are driving more and more car sales. And as much I love the Prime in just about every other way, the thought of having Entune (as it currently is) for many more years does make me sad.
    #54 ziggy29, Oct 28, 2018
    benagi and bisco like this.
  15. john1701a
    12,840
    5,312
    58
    Maybe what? It was a red herring. That has nothing to do with the "zero confidence" comment made about the control software for the propulsion system.
    btw, look up Prius rollout history. You'll find interesting mid-cycle updates... or interesting early rollout holdouts... depending on your perspective. It's all audience & timing.
    #55 john1701a, Oct 28, 2018
  16. bisco
    52,901
    you can find them on your own, but only if you're so inclined. or you can bury your head in the sand.
    if you spent some time answering peoples questions, perhaps you could advise them on how to prevent the engine from starting
  17. john1701a
    12,840
    5,312
    58
    My wife and I drove all throughout the winter last year in our Primes without experiencing an engine start until temperatures dropped below 15 F degrees. You set the blower on the WINDOW & FEET (any warmth setting is fine) and the mode to ECO. That's it. Gas isn't used until it gets colder or you force a start by pushing the max-defrost button.
    Watch these videos I just shared. There is a lot of detail for you to draw your own conclusions with. Don't let vague statements mislead or contribute to assumptions...
    Electric Heating (winter driving with Prius Prime) | PriusChat
    benagi likes this.
  18. ssdesigner
    304
    241
    california
    2013 Aqua
    Ok, so 25% of my very early on the way to work commute would require gas then. No thanks.
    The fact that you continue to stick up for Toyota says it all. Had they continued to push forward to EV they would be light years ahead. They have buried their collective heads in the sand. When they come out with an EV they will also be years behind vs. the years ahead they should be.
    And absolutely NOTHING about their software should excite you. Entune is a complete train wreck, and anyone practicing any shred of critical thinking would agree.
  19. john1701a
    12,840
    5,312
    58
    Behind what? The market hasn't even emerged out of the early-adopter stage. Whether or not you accept the fact that Toyota is working to refine their already available EV drive, plus related components & software, is not their problem. They are busy setting the stage for dealer & salesperson, as well as building a process for traditional vehicle phaseout. It never ceases to amaze me how some feel "ahead" should be quantified based on short-term measure, even though production cost is still out of reach and energy-density still isn't quite there yet.
    As for where they should be, where exactly is that? There's no basis for a mass acceptance of plug-in vehicles yet. High-Volume sales without subsidy haven't even been attempted yet. Reliance on tax-credits is a problem Tesla is scrambling to avoid though, but it is not a legacy automaker. GM is and will inevitably pay the price from not having a competitive product prior to triggering phaseout. Toyota still has time and will smoothly pass by from having taken the slower path to adapt a system capable of sustainable profits with a clear path to a wide variety of plug offerings. They carefully studied the market, rather than rushing to it.
    It's like watching the Tortoise & Hare story playout right before our eyes...
    benagi and heiwa like this.
  20. Zythryn
    6,412
    4,415
    John will be here all week folks!:rolleyes:
    Remember, two drink minimum. Don't forget to tip your waitress :p
