Prius pulling an RV? What do you pull !!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by engerysaver, Jun 16, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    engerysaver
    I ordered one, but just got email from etrailer that they are out the stock and won't be able to get one in at the end of July, damm it, but I am needed so I have to wait, do you know any other sell them?? please let me know.
    V/r
    Khoi Nguyen
  2. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    Toyota does not recommend trailer towing; this is true. Toyota did no say, " Do not tow"; big difference!! bwilson4web and others have proved it can be done. What is the limit on weight, is the question? I admit, I went over on weight ( 800 + 1900 = 2700 pounds ). No bells sounding or lights coming on!! I'm sure that Toyota build safe guards in the system. This is my test, and time will tell.
    I want to hear from other Prius owners who pull trailers, and other things; and how much weight they pull?
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I saw an "unmodified" Tundra pull the Endeavor Space Shuttle on a commercial, but it was moving really slowly...
    SCH-R530M ? 2
    engerysaver likes this.
  4. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    For all the hype, IIRC I think it only pulled it over a bridge or something. I believe the rest of the move was done by some special moving equipment. Still impressive for the Tundra, but not the deal it was made out to be.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    - http://www.toyota.com/t3Portal/document/om/OM47784U/pdf/sec_02-05.pdf
  6. andreyco
    andreyco Member
    91
    27
    Just because it can be done does not mean it should be done. If you have problems with your transmission or engine sooner then a non-towing prius, guess who gets their warranty claim denied?
    As long as we're on word technicalities, Toyota only recommends using engine oil, it doesn't say you have to. I really wish you the best in your towing endeavors, but do realize that the car is not designed for this application - especially pulling more than its own weight up any kind of incline.
    Flyin2Low likes this.
  7. Former Member 68813
    3,524
    983
    US
    The question here is not if it is doable, but rather if it's worth doing. Any time one tows a trailer in any car or truck, there is increased wear and tear on drivetrain, brakes, suspension, etc. The thing with prius, as it's not intended for heavy towing, the delta could be very large here. One would have to drive slow, avoid hills, and constantly monitor MGs, inverters, tranny, and engine coolant and oil temps.
    andreyco likes this.
  8. FriarNurgle
    FriarNurgle Member
    138
    53
    Wow, and I'm sitting here worrying about getting a hitch and 4 bike carrier.
  9. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    I'm glad I found this thread. I'm thinking about getting rid of my 2005 Grand Caravan for a 2010 Prius with under 30k miles. One problem I had to solve was that of towing our Seadoo Speedster on the 1 or 2 camping trips we take it on each year. The boat weighs 1200lbs and the trailer weighs 400lbs. It sounds like towing it twice a year shouldn't cause an issue. The boat is far more aerodynamic than a trailer. The trailer for the boat does not have brakes. :-(
  10. andreyco
    andreyco Member
    91
    27
    ^ and now it's starting to sound dangerous. Adding 1200 lb of weight for your Prius brakes to stop is dangerous. I know I wouldn't want to be on the same highway as you. If something were to happen you can count on being liable for the damages.
    xpcman likes this.
  11. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    I want these part so bad, nobody have them in stock now, does anybody know who carry them had actual have them in hand, I would like to order ASAP.
    V/r
    Khoi Nguyen
  12. engerysaver
    426
    133
    Tyler, Texas ; USA
    We do things BIG in Texas; if we didn't, more than 1/2 of state would be a desert. Our speed limit on some roads is 80 MPH.; But I will not go over 55 pulling my RV. And yes, I might have engine or transmission problems ? .....Time will tell !!
    Listen up people !!
    This thread is about what your Prius pulls in total weight of your cargo and trailer. Please read post # 1.
  13. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    engerysaver
    I am with you.
    V/r
    Khoi Nguyen
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I and, I think, many others would like to hear what you learn from this. There isn't lot of info around about what happens when the HSD system is worked a little (OK, a lot) harder than intended.
    Are you monitoring temperatures? I think that if you keep coolant, and the electrical systems within reasonable temperature limits you should be OK.
  15. engerysaver
    426
    133
    Tyler, Texas ; USA
    Just do it !! ..... It can be done.
    Bernie Noonan likes this.
  16. engerysaver
    426
    133
    Tyler, Texas ; USA
    I am worried about 100 + degree days, here in Texas pulling my RV, you are mostly in the power mode. It's going to get HOT under the hood......HV inverter ?
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Inverter coolant and MG1 and MG2 temperatures should be monitored. A Scanguage II is one way to do it.
    Makes no difference whether you are in Power mode or not, all power mode does is keep you from needing to push the throttle pedal as far. If you are going up grade x at 50 mph, the load on the powertrain is the same in normal or power modes
    1prius likes this.
  18. engerysaver
    426
    133
    Tyler, Texas ; USA
    I have ordered linear-logic/scangauge 2 from Auto Zone $ 159.99 -20% off ( code " DAD20" ) + tax, free shipping = $ 136.64 ; for watching temps.
  19. WE0H
    WE0H Senior Member
    3,247
    528
    Awesome price ;)
    Mike
    Mobile on my SGH-i717
  20. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    WE0H likes this.
