Prius rattle noise under medium acceleration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by codycowgill, Jul 13, 2017.
  1. codycowgill
    codycowgill Junior Member
    Rexburg, ID
    My Prius makes a rattle noise under medium acceleration. Nothing is loose under the hood (prop, washer fluid reservoir ect.) Has always made the noise ever since I bought it 4 years ago with 150k miles. Now has 210k miles. Uses a Qt of oil every 1500 miles. I've heard a few theories like the oil control valve or the catalytic converter. But figured I would post my video of the noise and get some opinions. The check engine light is for the coolant sensor valve. No other codes have been thrown. Thanks.
  2. Igoryan
    Igoryan Junior Member
    28
    16
    Chicago, Illinois
    I've got the exact same noise.
    I also have 202K on mine.
    And I started getting error code for catalytic converter.
    P0420 - Catalyst System Efficiency Below Threshold
    It appears once in 1-2 weeks.
    Not sure when I will replace it, but I will update here if the noise is gone.
    codycowgill likes this.
  3. Bens04Prius
    Bens04Prius Junior Member
    New Jersey
    I have a similar noise but no codes - my car also vibrates heavily when idling in park. Did you ever figure out the problem?
    52,390
    look all the way down the exhaust line for a heat shield touching something.
    ChrisFaehrtPrius and Buffmatt12 like this.
  5. codycowgill
    Rexburg, ID
    Havent figured it out but will check the heat shields.
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    has the PCV valve ever been changed?
    no codes or warning lights just part over routine maintenance everyone overlooks..
    its about 8 bucks and there are videos on youtube how to change it
  7. Beachbummm
    1,160
    392
    always check youtube.. solved 98% of my fix it problems with info from there
    fiberoptx likes this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    The main factor is have you ever run the oil so low the check engine light came on?
    If so the engine is most likely damaged especially if there are no lights on the dash now and in your case is using oil like crazy.
    If lights on the dash it's showing a misfire and may very well be a cop.
    Start looking for a used engine.
  9. codycowgill
    Rexburg, ID
    Well Not sure if the sound had anything to do with it but I threw some bearing caps on my way back from California and made swiss cheese out of the bottom of the engine...
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    It likes to throw piston #3 thru the block.
    The death rattle in a Prius engine can either be a cop or the bottom internals are damaged usually piston wrist bearing. In your case it was probably the piston rod bearing.
    Blown bottom end is caused by oil starvation. Low oil poor oil splash and the upper part of the inside of the engine like piston chamber walls and piston/rod connection see no oil.
    If really starved the mains will fail. They take the most punishment in an engine.
    If low oil and no lubrication the oil control ring is quickly damaged first and will result in a lot of oil blowby
    Turning the engine into an oil eater.
  11. codycowgill
    Rexburg, ID
    Have another engine on the way, with around 100k on it. Came with the transaxle attached for a good deal. All in all there was 4 holes. 3 on the transaxle side of the engine underneath. The other one was hidden under the intake manifold.
    edthefox5 likes this.
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  13. codycowgill
    Rexburg, ID
    Small Update, noise was still there somewhat with "new motor/transaxle until i reset the computer (unhooked battery cables and shorted them for 10 min). After that the sound went away. Maybe the computer was still compensating for something from the old engine? Anyways smooth sailing now and Rarely uses any oil (compared to 1 Qt every 500 with old motor). Previous owner took poor care of motor apparently.
    fiberoptx and bisco like this.
  14. bisco
    52,390
    congrats, thanks for the update. all the best!(y)
  15. dolj
    dolj Senior Member
    8,557
    4,348
    Wellington, New Zealand
    Can you explain what you mean by "them"? What exactly is "them"? Did you connect the + and - battery cables together? Why did you do that?
  16. Sonat
    Sonat New Member
    London
    Anyone tried checking the water pump is working efficiently for that rattling metallic sound?
  17. ccamero
    ccamero New Member
    London
    i-Tech
    I have the same problem. I checked you tube and cleaned EGR cooling and valve using you tube Nutz and Bolts how to.
    I also changed the spark plug and checked the coils. The rattling noise was still there but not as bad. So figured that my injectors must be clogged or bad. I bought redex fuel treatment for hybrids from halfords and after 300 miles the rattling has gone.
    Driving now with no annoying rattling engine noise and the car is as smooth as ever and better MPG. I have 208k on on my mileage.
    I am also in the process of changing the transmission oil and cleaning the intake manifold.
    Hope this helps you.
  18. edthefox5
    10,096
    4,834
    Clearwater, Florida
    You are posting in a G2 forum.
  19. Lord Byron
    Lord Byron Member
    93
    Delaware
    I have the exact same noise.. been driving me nuts forever now! I just threw the Cat code today. Did you replace your Cat..? Was that what was causing the rattle?
  20. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Did you do the Injectors before the noise
