Prius rattle noise under medium acceleration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by codycowgill, Jul 13, 2017.
  1. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    If you did and the injector are loose add a washer to the top you will have to remove the rubber seal off the injector to get the washer over. Other Symptoms are poor slide and from the start of the engine on is rough. And odd noise Poor mpg by 10 mpg. O2 codes and misfire. Why no clue I tested size the same ordered OEM seals. Nothing changed.
    pushed on them while someone inside smooth right out. It not off much but I think air getting out or in. of the fuel injector seal
  2. Lord Byron
    Lord Byron Member
    93
    Delaware
    No.. I hadn’t done any work at all other than oil changes, filters etc.. after watching other videos of bad Cats, I pretty convinced that’s what it is. Will know more in a day or 2.
  3. oldtechaa
    oldtechaa Active Member
    336
    224
    NZ
    2013 Prius Alpha
    This is exactly the noise my 220k Prius makes under acceleration or uphill. It seems to happen more often when the engine compartment is warm, even when it hasn't been run but the sun has been shining brightly on the hood. Any conclusive ideas what this is?
    Of course, if it was the cat, it also could very well be dependent on temperature.
  4. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    I was getting the rattling upon acceleration and a very rough idle, but mine was also accompanied by engine misfire codes. I replaced injectors 1 and 2 and all is smooth sailing after that (once I got the injectors seated properly that is. :) )
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Have you touched the fuel injectors?
  6. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    Yes, I replaced Fuel Injector 1 and Fuel Injector 2 with cheap Amazon Fuel Injectors I bought for about $40 for a 4 pack.
    dave
  7. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    You have a air leak at the seals I had to a washer to the top of the fuel injector to push them in. Tried OEM seal and injectors still same but adding washer fixed it about $1 fix
  8. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    I actually had a fuel leak since I was able to see fuel leaking and could smell it while driving. I messed up the washers because I didn't seat them in the fuel rail properly and put little kinks in them. Bought replacement washers from Toyota (more than a $1) and all was good after that.
    dave
  9. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Add metal washer have to remove the rubber one to get the metal one one has to seat flat on the fuel injectors
  10. Lord Byron
    Lord Byron Member
    93
    Delaware
    Not at this point. The Cat code cleared, so I let it go. Still getting rattle here and there. I think the honeycomb in the Cat is broken. I don’t really have the money to replace at the moment. Will post results after I do it. At this point, I’ve had the rattle for 70,000 miles..ish, so a few more shouldn’t kill her.
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    After market $120 on eBay
  12. Lord Byron
    Lord Byron Member
    93
    Delaware
    I’m not sure that I want to put an after market Cat.
  13. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I did worked the same. O2 sensor little tight fit. Thought it would be louder but it wasn't
  14. Lord Byron
    Lord Byron Member
    93
    Delaware
    How many miles ago? My mechanic is against them. Says he’s never had one that lasted. He’s not one to waste $$ either.
  15. Getheavy
    Getheavy Junior Member
    Cluj-Napoca,Romania.
    Well I have the same noise sometimes I have 239 k no light no error just the P0420 but after few days the check engine is gone and come back , no problems with the hybrid battery I read here somebody sais could be the water pump I never change it ( yet ) I change in january the spark plugs and clear everything , must be the injectors ? Can I put some cleaner ( like Techron maybe ) or can I check them ? ( but how ) . Thanks in advance.
  16. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Odd rattle Mostly going up or down a Hill Sounds like a CV joint but it transmission fluid low fill on a 100% flat road remove bolt and fill with a tube
    Or fuel injector letting in air or leaking fuel
    Found the black riser cracked at the top looks like no big deal but it keep them straight. Replace with use one off ebay it sound like something really wrong like steel balls in side engine
    Check orange washer for cracks too
    #36 Jmack111, Sep 12, 2020
  17. Getheavy
    Thanks for reply, I puted a injector cleanner ,still got the P420 code after maybe 1000 km if I clear the code come back after another 1000 km , the cvt fluid is full and I changed every 60-70000 km but I will look after what you say thank you
  18. Ianmeister
    Ianmeister Active Member
    316
    318
    Meridian Idaho
    I get this loud rattle when the engine is spooling down after revving it up. It kinda sounds like the timing chain. Any guesses?
  19. Darth_Eric
    Darth_Eric Junior Member
    San antonio, texas
    Ok I found a similar post with the exact same problem. I guess it’s the EGR valve and intake manifold is getting clogged. So I will look into getting it cleaned. How much could I expect to pay generally at mechanic or dealership? Someone said something about a extended warranty but I’m sure that’s expired by now.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Hi Darth your in the wrong forum.
    This is the Gen 2 forum 2004 to 2009 Prius
    Your car is in the Gen 3 Forum 2010-2015.
    Many things don't translate like EGR for instance. A Gen 2 does not even have a EGR.
    Go to the top of the page see where it says Prius. Pull that down and select Gen3. Many many discussions about the EGR issue over there.
