Prius Rear Bumper Cover loose and gap?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prius_speed, Jun 29, 2013.
  1. CR94
    CR94 Senior Member
    2,786
    1,224
    Northwestern S.C.
    No, I didn't take any. I gather your attachment was on the rear, inside of the corner. My eyebolt is attached through a hole in the bottom edge on the side, only slightly in front of the corner. To do this, I had to remove the black plastic thing that's under the end of the bumper cover.
  2. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Anybody have a recommendation for Sheet Metal thickness in regards to this bumper repair? Looks like the standard thickness at Home Depot and Lowe's is around 30 gauge, but I'm thinking a thicker gauge in the 16 to 18 range would be stronger and less prone to bending at the 90° bend.
  3. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    I came up with what appears to be the definitive fix! I have never seen anyone doing this particular repair before, so I'm pretty sure it's my unique idea, which I'm happy to share. I bought some 3/4" neodymium magnets, and 3 of them fit perfectly inside the screw hole cutouts in the plastic retainers. Then, using 3m double back foam tape, I attached 2 pieces of sheet metal, each about 2" tall x 1.5" wide, with 90° flaps that sit on top of two pieces of 1/8" aluminum blocks placed as pictured. The magnets hold very strong and close the gap as well as possible, considering the bumper's fit is not perfect. I thought I would need more magnets toward the wheel well, but two sets nearest the rear seemed to suffice.
    IMG_20230405_140001.jpg IMG_20230405_135932.jpg IMG_20230405_140150.jpg IMG_20230405_135904.jpg
    #103 unigeezer, Apr 5, 2023
    Montgomery, burebista and CR94 like this.
  4. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    If the above repair had not worked out, this would have been Plan B:
    Matth Torrijos and Montgomery like this.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
  6. Matth Torrijos
    Matth Torrijos Active Member
    121
    213
    Poway
    I need to do this soon
  7. ASRDogman
    ASRDogman Senior Member
    7,947
    4,043
    The drivers side is "before"and the passenger side is "after". YOU'RE GOOD! (y):ROFLMAO:
    Khezekiah likes this.
  8. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Haha, you're correct. I hadn't yet applied this fix to the other side, but thought the pics would still basically suffice to illustrate the difference
    ASRDogman likes this.
  9. ASRDogman
    7,947
    4,043
    :whistle:(y)
  10. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    I devised an even better, more permanent fix by just removing the entire plastic retainer piece, (which was actually preventing the bumper cover from fitting correctly!) and replaced it with a piece of 1/8" thick aluminum flat bar, countersunk for machine screws that go through to the inside and secured with nuts and washers.
    Since the plastic retainer had been removed, I had to add a thin piece of wood under the alum strip so everything would be flush when pressed I to place.
    Then, with heavy duty 3m foam tape attached to the aluminum strip on the side facing the bumper cover, I simply pushed the bumper into place and held it for a minute or two. Done!
  11. Montgomery
    2,254
    2,242
    Orange County, CA
    Pictures?
  12. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Unfortunately no I put it all together before I thought about taking pictures. At some point when I have time I'll remove the inside panel, loosen the nuts so I can pull the bumper away and take some pictures from the inside and outside.
  13. Montgomery
    2,254
    2,242
    Orange County, CA
    No problem, but can you share photos of the finished product? How tight the lines look, etc?
  14. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    This is the closest fit possible due to the inherent misalignment. I wish I had before pictures which showed a gap of at least a quarter of an inch toward the back and a little less nearest the wheel well. IMG_20230422_172014.jpg
  15. Montgomery
    2,254
    2,242
    Orange County, CA
    This is great improvement over the gap that the stock thing has. I like what you did!
  16. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Thanks. Basically, by removing the plastic retainer thingy, which was just getting in the way of a clean fit, I was able to simply bolt the fender in to place. The trick was finding a way to attach the screws securely to the inside of the bumper. By countersinking them into the aluminum flat bar, the heads wouldn't stick out, so then the aluminum strip could be affixed evenly to the inside of the bumper cover.
  17. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Montgomery and ASRDogman like this.
  18. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    You should replace the wood with something else that won't rot or hold moisture against the metal it's mounted on. Maybe get a cheap polyethylene cutting board and cut and shape that material?
  19. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    It's actually 3 materials: 1/8" thick aluminum, 5/16" thick plastic and 1/4" thick foam board. No wood in final setup.
    #119 unigeezer, Apr 24, 2023
    Montgomery likes this.
  20. Montgomery
    2,254
    2,242
    Orange County, CA
    Now that's permanent! Even if you back into something, your bumper will stay in place. Now I get how you did it! Thanks for the pictures!
