prius rear coil upper
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by macksh, Apr 18, 2026.
  1. macksh
    macksh New Member
    korea
    “Is there a specific orientation when installing it?”
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    Part number text is right side up /
    The end with the smaller diameter (tapered) typically faces downward /
  3. macksh
    macksh New Member
    korea
    I want to know if there is an insulator direction.
  4. StarCaller
    1,284
    733
    The direction of the insulator is dictated by the hole in the lower arm and the end of the spring coil /
    If the tab isn't in the hole, or the coil isn't against the rubber stop, the installation is incorrect /
