Prius recall... does it effect PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by vajratlr, Feb 12, 2014.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    I just thought since you are the only one with a plug-in that has received a letter for the recall you could confirm it a the owners site. At least make sure you have your dealer run your vin number and confirm that you really need the recall done! Just to double check, and let us know how it turns out.
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    You don't recall a product that is a different design and doesn't have the problem to "play it safe". Read the information in this recall documentation from Toyota to the National Highway Traffic Safety Administration. http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM450071/RCDNN-14V053-0945.pdf about the actual design problem.
  3. CharlesH
    2,798
    1,166
    Roseville, CA
  4. Dr Surfdog
    Dr Surfdog Junior Member
    Irvine CA
    2014 Prius Plug-in
    Yep, this is the same info in my recall letter. I'd imagine the module referred to is likely the same in PiP as the regular Prius. After all, except for the battery and associated software I suppose, a PiP is just a regular Prius once you're out of EV range. Makes perfect sense to me that the recall would impact both models.
  5. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    But it doesn't. It's a different design as stated above.
  6. CaliforniaBear
    1,180
    289
    Northern California
    The fix is a software change related to high electrical energy demand, no hardware change. The PiP provides higher energy demand levels and the software correctly handles it. One could guess is that the fix for the regular hybrid is to change the software to be more like the PiP (and or the V). Hence, no recall for the PiP.
  7. blkpriusgirl
    blkpriusgirl Junior Member
    29
    San Francisco, CA
    2014 Prius Plug-in
    It only affected the non-plug in Prius. My 2012 non plug in was part of that recall.
